MAAS Documentation
MAAS is Metal As A Service, a service that treats physical servers like virtual machines (instances) in the cloud.
No need to manage servers individually: MAAS turns bare metal into an elastic, cloud-like resource. Enlist and deploy standard or customised operating systems to hardware and virtual machines – remotely. Monitor, manage, and secure your metal infrastructure easily and efficiently.
MAAS comprehensively meets the need to rapidly deploy, destroy, and reconfigure constellations of bare metal. Any application that requires frequently rearranging the server topology will benefit.
MAAS is applicable to nearly any situation. It is currently deployed in banking, telecom, and industrial environments, as well as niche uses as diverse as national lotteries, supercomputer front-end validation, streaming music services, disaster recovery, and computer security risk analysis.
In this documentation
Tutorials
Get started - a hands-on introduction to MAAS for new users
How-to guides
Step-by-step guides covering key operations and common tasks
The landing pages for these How-to guides offer explain the theory behind the related topics
The API Reference
Detailed instructions for using the MAAS API
Reference
Technical information - specifications, APIs, architecture
Project and community
MAAS is a member of the Ubuntu family. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
Our roadmap
Here’s a view of our current roadmap:
Considering MAAS for your next project? Get in touch↗
Navigation
Home
Basic tutorials
How to get started with MAAS
How to set up networks
How to acquire images
How to tune controllers
How to deploy physical machines
How to deploy virtual machines
How to label and find machines
How to diagnose issues
How to work securely
How to protect your secrets
How to operate reliably
API reference
MAAS technical reference
URLs
Mapping table
TOPIC PATH
How to enable Vault /docs/how-to-enable-vault
How to unseal Vault /docs/how-to-unseal-vault
How to secure MAAS /docs/how-to-protect-your-secrets
https://discource.maas.io/t/-/6500 /docs/how-to-deploy-virtual-machines
How to manage controllers /docs/how-to-tune-controllers
https://discourse.maas.io/t/-/6346 /docs/what-is-new-with-maas-3-3
How to spin up MAAS with Ansible /docs/how-to-spin-up-maas-with-ansible
MAAS audit events /docs/understanding-maas-audit-events
Understanding MAAS events /docs/understanding-maas-events
MAAS settings reference /docs/how-to-change-maas-settings
MAAS Terraform reference /docs/maas-terraform-provider-reference
MAAS installation requirements /docs/maas-installation-requirements
MAAS Technical reference /docs/maas-technical-reference
How to get started with MAAS /docs/how-to-get-started-with-maas
How to operate MAAS /docs/how-to-operate-maas
How to label devices /docs/how-to-label-and-find-machines
How to manage machines /docs/how-to-deploy-physical-machines
How to use images /docs/how-to-acquire-images
About networks /docs/how-to-set-up-networks
MAAS performance /docs/maas-performance
About RBAC /docs/about-rbac
Explanation /docs/explanation
How-to guides /docs/how-to-guides
Reference /docs/general-reference
Create a custom image /docs/custom-image-tutorial
About custom images /docs/about-creating-custom-images
Get fancy CLI output /docs/using-jq-with-the-maas-cli
How to audit MAAS /docs/how-to-work-with-audit-event-logs
About customising machines /docs/about-customising-machines
Storage layouts reference /docs/storage-layouts-reference
Upgrade 2.3 to 2.4 from Ubuntu 16.04 /docs/upgrade-2-3-to-2-4-from-ubuntu-16-04
Upgrade from 1.9 to 2.x /docs/upgrade-from-1-9-to-2-x
TCP/IP primer /docs/about-tcp-ip-networks
It is always DHCP /docs/about-dhcp
About cloud networks /docs/about-cloud-networks
About MAAS (snap/2.7/CLI) /docs/snap/2.7/cli/about-maas
About MAAS (snap/2.7/UI) /docs/snap/2.7/ui/about-maas
About MAAS (deb/2.7/CLI) /docs/deb/2.7/cli/about-maas
About MAAS (deb/2.7/UI) /docs/deb/2.7/ui/about-maas
About MAAS (snap/2.8/CLI) /docs/snap/2.8/cli/about-maas
About MAAS (snap/2.8/UI) /docs/snap/2.8/ui/about-maas
About MAAS (deb/2.8/CLI) /docs/deb/2.8/cli/about-maas
About MAAS (deb/2.8/UI) /docs/deb/2.8/ui/about-maas
Adding a VM host (snap/2.7/CLI) /docs/snap/2.7/cli/adding-a-vm-host
Adding a VM host (snap/2.7/UI) /docs/snap/2.7/ui/adding-a-vm-host
Adding a VM host (snap/2.8/CLI) /docs/snap/2.8/cli/adding-a-vm-host
Adding a VM host (snap/2.8/UI) /docs/snap/2.8/ui/adding-a-vm-host
Adding a VM host (deb/2.7/CLI) /docs/deb/2.7/cli/adding-a-vm-host
Adding a VM host (deb/2.7/UI) /docs/deb/2.7/ui/addupgraing-a-vm-host
Adding a VM host (deb/2.8/CLI) /docs/deb/2.8/cli/adding-a-vm-host
https://discourse.maas.io/t/-/2295 /docs/deb/2.8/ui/adding-a-vm-host
https://discourse.maas.io/t/-/2274 /docs/snap/2.7/cli/add-machines
https://discourse.maas.io/t/-/2275 /docs/snap/2.7/ui/add-machines
https://discourse.maas.io/t/-/2276 /docs/snap/2.8/cli/add-machines
https://discourse.maas.io/t/-/2277 /docs/snap/2.8/ui/add-machines
https://discourse.maas.io/t/-/2280 /docs/deb/2.7/cli/add-machines
https://discourse.maas.io/t/-/2281 /docs/deb/2.7/ui/add-machines
https://discourse.maas.io/t/-/2282 /docs/deb/2.8/cli/add-machines
https://discourse.maas.io/t/-/2283 /docs/deb/2.8/ui/add-machines
https://discourse.maas.io/t/-/4268 /docs/deb/2.8/ui/air-gapped-maas
https://discourse.maas.io/t/-/4269 /docs/deb/2.8/cli/air-gapped-maas
https://discourse.maas.io/t/-/4271 /docs/snap/2.8/ui/air-gapped-maas
https://discourse.maas.io/t/-/4272 /docs/snap/2.8/cli/air-gapped-maas
https://discourse.maas.io/t/-/4285 /docs/snap/2.7/ui/air-gapped-maas
https://discourse.maas.io/t/-/4286 /docs/snap/2.7/cli/air-gapped-maas
https://discourse.maas.io/t/-/4287 /docs/deb/2.7/cli/air-gapped-maas
https://discourse.maas.io/t/-/4288 /docs/deb/2.7/ui/air-gapped-maas
https://discourse.maas.io/t/-/5212 /docs/how-to-set-up-an-air-gapped-maas
https://discourse.maas.io/t/-/5144 /docs/how-to-employ-vmware-images
https://discourse.maas.io/t/-/5333 /docs/how-to-troubleshoot-maas
https://discourse.maas.io/t/-/5927 /docs/how-to-mirror-images-locally
https://discourse.maas.io/t/-/5416 /docs/maas-glossary
https://discourse.maas.io/t/-/5236 /docs/try-out-the-maas-cli
https://discourse.maas.io/t/-/5314 /docs/test-log-reference
https://discourse.maas.io/t/-/5329 /docs/tips-and-tricks
https://discourse.maas.io/t/-/5404 /docs/python-api-client-reference
https://discourse.maas.io/t/-/4186 /docs/how-to-help-improve-the-doc
https://discourse.maas.io/t/-/5428 /docs/how-to-ask-for-help
https://discourse.maas.io/t/-/5116 /docs/how-to-enable-maas-native-tls
https://discourse.maas.io/t/-/5448 /docs/how-to-contact-us
https://discourse.maas.io/t/-/5256 /docs/audit-event-log-reference
https://discourse.maas.io/t/-/5375 /docs/commissioning-scripts-reference
https://discourse.maas.io/t/-/817/ /docs/intel-rack-scale-design-rsd-introduction
https://discourse.maas.io/t/-/2298 /docs/snap/2.7/cli/api-authentication
https://discourse.maas.io/t/-/2299 /docs/snap/2.7/ui/api-authentication
https://discourse.maas.io/t/-/2300 /docs/snap/2.8/cli/api-authentication
https://discourse.maas.io/t/-/2301 /docs/snap/2.8/ui/api-authentication
https://discourse.maas.io/t/-/2304 /docs/deb/2.7/cli/api-authentication
https://discourse.maas.io/t/-/2305 /docs/deb/2.7/ui/api-authentication
https://discourse.maas.io/t/-/2306 /docs/deb/2.8/cli/api-authentication
https://discourse.maas.io/t/-/2307 /docs/deb/2.8/ui/api-authentication
https://discourse.maas.io/t/-/2310 /docs/snap/2.7/cli/audit-event-logs
https://discourse.maas.io/t/-/2311 /docs/snap/2.7/ui/audit-event-logs
https://discourse.maas.io/t/-/2312 /docs/snap/2.8/cli/audit-event-logs
https://discourse.maas.io/t/-/2313 /docs/snap/2.8/ui/audit-event-logs
https://discourse.maas.io/t/-/2316 /docs/deb/2.7/cli/audit-event-logs
https://discourse.maas.io/t/-/2317 /docs/deb/2.7/ui/audit-event-logs
https://discourse.maas.io/t/-/2318 /docs/deb/2.8/cli/audit-event-logs
https://discourse.maas.io/t/-/2319 /docs/deb/2.8/ui/audit-event-logs
https://discourse.maas.io/t/-/2322 /docs/snap/2.7/cli/availability-zones
https://discourse.maas.io/t/-/2323 /docs/snap/2.7/ui/availability-zones
https://discourse.maas.io/t/-/2324 /docs/snap/2.8/cli/availability-zones
https://discourse.maas.io/t/-/2325 /docs/snap/2.8/ui/availability-zones
https://discourse.maas.io/t/-/2328 /docs/deb/2.7/cli/availability-zones
https://discourse.maas.io/t/-/2329 /docs/deb/2.7/ui/availability-zones
https://discourse.maas.io/t/-/2330 /docs/deb/2.8/cli/availability-zones
https://discourse.maas.io/t/-/2331 /docs/deb/2.8/ui/availability-zones
https://discourse.maas.io/t/-/2334 /docs/snap/2.7/cli/backup
https://discourse.maas.io/t/-/2335 /docs/snap/2.7/ui/backup
https://discourse.maas.io/t/-/2336 /docs/snap/2.8/cli/backup
https://discourse.maas.io/t/-/2337 /docs/snap/2.8/ui/backup
https://discourse.maas.io/t/-/2340 /docs/deb/2.7/cli/backup
https://discourse.maas.io/t/-/2341 /docs/deb/2.7/ui/backup
https://discourse.maas.io/t/-/2342 /docs/deb/2.8/cli/backup
https://discourse.maas.io/t/-/2343 /docs/deb/2.8/ui/backup
https://discourse.maas.io/t/-/2346 /docs/snap/2.7/cli/block-devices
https://discourse.maas.io/t/-/2347 /docs/snap/2.7/ui/block-devices
https://discourse.maas.io/t/-/2348 /docs/snap/2.8/cli/block-devices
https://discourse.maas.io/t/-/2349 /docs/snap/2.8/ui/block-devices
https://discourse.maas.io/t/-/2352 /docs/deb/2.7/cli/block-devices
https://discourse.maas.io/t/-/2353 /docs/deb/2.7/ui/block-devices
https://discourse.maas.io/t/-/2354 /docs/deb/2.8/cli/block-devices
https://discourse.maas.io/t/-/2355 /docs/deb/2.8/ui/block-devices
https://discourse.maas.io/t/-/2478 /docs/snap/2.7/cli/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2479 /docs/snap/2.7/ui/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2480 /docs/snap/2.8/cli/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2481 /docs/snap/2.8/ui/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2484 /docs/deb/2.7/cli/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2485 /docs/deb/2.7/ui/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2486 /docs/deb/2.8/cli/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2487 /docs/deb/2.8/ui/commissioning-and-hardware-testing-scripts
https://discourse.maas.io/t/-/2490 /docs/snap/2.7/cli/commissioning-logs
https://discourse.maas.io/t/-/2491 /docs/snap/2.7/ui/commissioning-logs
https://discourse.maas.io/t/-/2492 /docs/snap/2.8/cli/commissioning-logs
https://discourse.maas.io/t/-/2493 /docs/snap/2.8/ui/commissioning-logs
https://discourse.maas.io/t/-/2496 /docs/deb/2.7/cli/commissioning-logs
https://discourse.maas.io/t/-/2497 /docs/deb/2.7/ui/commissioning-logs
https://discourse.maas.io/t/-/2498 /docs/deb/2.8/cli/commissioning-logs
https://discourse.maas.io/t/-/2499 /docs/deb/2.8/ui/commissioning-logs
https://discourse.maas.io/t/-/2526 /docs/snap/2.7/cli/configuration-journey
https://discourse.maas.io/t/-/2527 /docs/snap/2.7/ui/configuration-journey
https://discourse.maas.io/t/-/2528 /docs/snap/2.8/cli/configuration-journey
https://discourse.maas.io/t/-/2529 /docs/snap/2.8/ui/configuration-journey
https://discourse.maas.io/t/-/2532 /docs/deb/2.7/cli/configuration-journey
https://discourse.maas.io/t/-/2533 /docs/deb/2.7/ui/configuration-journey
https://discourse.maas.io/t/-/2534 /docs/deb/2.8/cli/configuration-journey
https://discourse.maas.io/t/-/2535 /docs/deb/2.8/ui/configuration-journey
https://discourse.maas.io/t/-/2538 /docs/snap/2.7/cli/configuring-tls-encryption
https://discourse.maas.io/t/-/2539 /docs/snap/2.7/ui/configuring-tls-encryption
https://discourse.maas.io/t/-/2540 /docs/snap/2.8/cli/configuring-tls-encryption
https://discourse.maas.io/t/-/2541 /docs/snap/2.8/ui/configuring-tls-encryption
https://discourse.maas.io/t/-/2544 /docs/deb/2.7/cli/configuring-tls-encryption
https://discourse.maas.io/t/-/2545 /docs/deb/2.7/ui/configuring-tls-encryption
https://discourse.maas.io/t/-/2546 /docs/deb/2.8/cli/configuring-tls-encryption
https://discourse.maas.io/t/-/2547 /docs/deb/2.8/ui/configuring-tls-encryption
https://discourse.maas.io/t/-/2718 /docs/snap/2.7/cli/controllers
https://discourse.maas.io/t/-/2719 /docs/snap/2.7/ui/controllers
https://discourse.maas.io/t/-/2720 /docs/snap/2.8/cli/controllers
https://discourse.maas.io/t/-/2721 /docs/snap/2.8/ui/controllers
https://discourse.maas.io/t/-/2724 /docs/deb/2.7/cli/controllers
https://discourse.maas.io/t/-/2725 /docs/deb/2.7/ui/controllers
https://discourse.maas.io/t/-/2726 /docs/deb/2.8/cli/controllers
https://discourse.maas.io/t/-/2727 /docs/deb/2.8/ui/controllers
https://discourse.maas.io/t/-/5072 /docs/about-controllers
https://discourse.maas.io/t/-/2563 /docs/snap/2.7/ui/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2564 /docs/snap/2.8/cli/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2565 /docs/snap/2.8/ui/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2568 /docs/deb/2.7/cli/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2569 /docs/deb/2.7/ui/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2570 /docs/deb/2.8/cli/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2571 /docs/deb/2.8/ui/creating-a-custom-ubuntu-image
https://discourse.maas.io/t/-/2574 /docs/snap/2.7/cli/creating-and-deleting-vms
https://discourse.maas.io/t/-/2575 /docs/snap/2.7/ui/creating-and-deleting-vms
https://discourse.maas.io/t/-/2576 /docs/snap/2.8/cli/creating-and-deleting-vms
https://discourse.maas.io/t/-/2577 /docs/snap/2.8/ui/creating-and-deleting-vms
https://discourse.maas.io/t/-/2580 /docs/deb/2.7/cli/creating-and-deleting-vms
https://discourse.maas.io/t/-/2581 /docs/deb/2.7/ui/creating-and-deleting-vms
https://discourse.maas.io/t/-/2582 /docs/deb/2.8/cli/creating-and-deleting-vms
https://discourse.maas.io/t/-/2583 /docs/deb/2.8/ui/creating-and-deleting-vms
https://discourse.maas.io/t/-/2586 /docs/snap/2.7/cli/custom-machine-setup
https://discourse.maas.io/t/-/2587 /docs/snap/2.7/ui/custom-machine-setup
https://discourse.maas.io/t/-/2588 /docs/snap/2.8/cli/custom-machine-setup
https://discourse.maas.io/t/-/2589 /docs/snap/2.8/ui/custom-machine-setup
https://discourse.maas.io/t/-/2592 /docs/deb/2.7/cli/custom-machine-setup
https://discourse.maas.io/t/-/2593 /docs/deb/2.7/ui/custom-machine-setup
https://discourse.maas.io/t/-/2594 /docs/deb/2.8/cli/custom-machine-setup
https://discourse.maas.io/t/-/2595 /docs/deb/2.8/ui/custom-machine-setup
https://discourse.maas.io/t/-/2598 /docs/snap/2.7/cli/deploy-machines
https://discourse.maas.io/t/-/2599 /docs/snap/2.7/ui/deploy-machines
https://discourse.maas.io/t/-/2600 /docs/snap/2.8/cli/deploy-machines
https://discourse.maas.io/t/-/2601 /docs/snap/2.8/ui/deploy-machines
https://discourse.maas.io/t/-/2604 /docs/deb/2.7/cli/deploy-machines
https://discourse.maas.io/t/-/2605 /docs/deb/2.7/ui/deploy-machines
https://discourse.maas.io/t/-/2606 /docs/deb/2.8/cli/deploy-machines
https://discourse.maas.io/t/-/2607 /docs/deb/2.8/ui/deploy-machines
https://discourse.maas.io/t/-/2610 /docs/snap/2.7/cli/disk-erasure
https://discourse.maas.io/t/-/2611 /docs/snap/2.7/ui/disk-erasure
https://discourse.maas.io/t/-/2612 /docs/snap/2.8/cli/disk-erasure
https://discourse.maas.io/t/-/2613 /docs/snap/2.8/ui/disk-erasure
https://discourse.maas.io/t/-/2616 /docs/deb/2.7/cli/disk-erasure
https://discourse.maas.io/t/-/2617 /docs/deb/2.7/ui/disk-erasure
https://discourse.maas.io/t/-/2618 /docs/deb/2.8/cli/disk-erasure
https://discourse.maas.io/t/-/2619 /docs/deb/2.8/ui/disk-erasure
https://discourse.maas.io/t/-/3382 /docs/snap/2.7/cli/event-logs
https://discourse.maas.io/t/-/3383 /docs/snap/2.7/ui/event-logs
https://discourse.maas.io/t/-/3384 /docs/snap/2.8/cli/event-logs
https://discourse.maas.io/t/-/3385 /docs/snap/2.8/ui/event-logs
https://discourse.maas.io/t/-/3388 /docs/deb/2.7/cli/event-logs
https://discourse.maas.io/t/-/3389 /docs/deb/2.7/ui/event-logs
https://discourse.maas.io/t/-/3390 /docs/deb/2.8/cli/event-logs
https://discourse.maas.io/t/-/3391 /docs/deb/2.8/ui/event-logs
https://discourse.maas.io/t/-/2634 /docs/snap/2.7/cli/explore-maas
https://discourse.maas.io/t/-/2635 /docs/snap/2.7/ui/explore-maas
https://discourse.maas.io/t/-/2636 /docs/snap/2.8/cli/explore-maas
https://discourse.maas.io/t/-/2637 /docs/snap/2.8/ui/explore-maas
https://discourse.maas.io/t/-/2640 /docs/deb/2.7/cli/explore-maas
https://discourse.maas.io/t/-/2641 /docs/deb/2.7/ui/explore-maas
https://discourse.maas.io/t/-/2642 /docs/deb/2.8/cli/explore-maas
https://discourse.maas.io/t/-/2643 /docs/deb/2.8/ui/explore-maas
https://discourse.maas.io/t/-/2646 /docs/snap/2.7/cli/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2647 /docs/snap/2.7/ui/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2648 /docs/snap/2.8/cli/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2649 /docs/snap/2.8/ui/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2652 /docs/deb/2.7/cli/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2653 /docs/deb/2.7/ui/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2654 /docs/deb/2.8/cli/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2655 /docs/deb/2.8/ui/give-me-an-example-of-maas
https://discourse.maas.io/t/-/2658 /docs/snap/2.7/cli/hardening-your-maas-installation
https://discourse.maas.io/t/-/2659 /docs/snap/2.7/ui/hardening-your-maas-installation
https://discourse.maas.io/t/-/2660 /docs/snap/2.8/cli/hardening-your-maas-installation
https://discourse.maas.io/t/-/2661 /docs/snap/2.8/ui/hardening-your-maas-installation
https://discourse.maas.io/t/-/2664 /docs/deb/2.7/cli/hardening-your-maas-installation
https://discourse.maas.io/t/-/2665 /docs/deb/2.7/ui/hardening-your-maas-installation
https://discourse.maas.io/t/-/2666 /docs/deb/2.8/cli/hardening-your-maas-installation
https://discourse.maas.io/t/-/2667 /docs/deb/2.8/ui/hardening-your-maas-installation
https://discourse.maas.io/t/-/2670 /docs/snap/2.7/cli/hardware-testing
https://discourse.maas.io/t/-/2671 /docs/snap/2.7/ui/hardware-testing
https://discourse.maas.io/t/-/2672 /docs/snap/2.8/cli/hardware-testing
https://discourse.maas.io/t/-/2673 /docs/snap/2.8/ui/hardware-testing
https://discourse.maas.io/t/-/2676 /docs/deb/2.7/cli/hardware-testing
https://discourse.maas.io/t/-/2677 /docs/deb/2.7/ui/hardware-testing
https://discourse.maas.io/t/-/2678 /docs/deb/2.8/cli/hardware-testing
https://discourse.maas.io/t/-/2679 /docs/deb/2.8/ui/hardware-testing
https://discourse.maas.io/t/-/2682 /docs/snap/2.7/cli/high-availability
https://discourse.maas.io/t/-/2683 /docs/snap/2.7/ui/high-availability
https://discourse.maas.io/t/-/2684 /docs/snap/2.8/cli/high-availability
https://discourse.maas.io/t/-/2685 /docs/snap/2.8/ui/high-availability
https://discourse.maas.io/t/-/2688 /docs/deb/2.7/cli/high-availability
https://discourse.maas.io/t/-/2689 /docs/deb/2.7/ui/high-availability
https://discourse.maas.io/t/-/2690 /docs/deb/2.8/cli/high-availability
https://discourse.maas.io/t/-/2691 /docs/deb/2.8/ui/high-availability
https://discourse.maas.io/t/-/785/ /docs/network-tutorial
https://discourse.maas.io/t/-/745/ /docs/language-details-contributing-to-maas-docs
https://discourse.maas.io/t/-/2694 /docs/snap/2.7/cli/images
https://discourse.maas.io/t/-/2695 /docs/snap/2.7/ui/images
https://discourse.maas.io/t/-/2696 /docs/snap/2.8/cli/images
https://discourse.maas.io/t/-/2697 /docs/snap/2.8/ui/images
https://discourse.maas.io/t/-/2700 /docs/deb/2.7/cli/images
https://discourse.maas.io/t/-/2701 /docs/deb/2.7/ui/images
https://discourse.maas.io/t/-/2702 /docs/deb/2.8/cli/images
https://discourse.maas.io/t/-/2703 /docs/deb/2.8/ui/images
https://discourse.maas.io/t/-/5076 /docs/about-images
https://discourse.maas.io/t/-/839/ /docs/documentation-index
https://discourse.maas.io/t/-/3318 /docs/snap/2.7/cli/installation
https://discourse.maas.io/t/-/3319 /docs/snap/2.7/ui/installation
https://discourse.maas.io/t/-/3320 /docs/snap/2.8/cli/installation
https://discourse.maas.io/t/-/3321 /docs/snap/2.8/ui/installation
https://discourse.maas.io/t/-/3324 /docs/deb/2.7/cli/installation
https://discourse.maas.io/t/-/3325 /docs/deb/2.7/ui/installation
https://discourse.maas.io/t/-/3326 /docs/deb/2.8/cli/installation
https://discourse.maas.io/t/-/3327 /docs/deb/2.8/ui/installation
https://discourse.maas.io/t/-/5192 /docs/how-to-find-machines
https://discourse.maas.io/t/-/2754 /docs/snap/2.7/cli/ip-ranges
https://discourse.maas.io/t/-/2755 /docs/snap/2.7/ui/ip-ranges
https://discourse.maas.io/t/-/2756 /docs/snap/2.8/cli/ip-ranges
https://discourse.maas.io/t/-/2757 /docs/snap/2.8/ui/ip-ranges
https://discourse.maas.io/t/-/2760 /docs/deb/2.7/cli/ip-ranges
https://discourse.maas.io/t/-/2761 /docs/deb/2.7/ui/ip-ranges
https://discourse.maas.io/t/-/2762 /docs/deb/2.8/cli/ip-ranges
https://discourse.maas.io/t/-/2763 /docs/deb/2.8/ui/ip-ranges
https://discourse.maas.io/t/-/2766 /docs/snap/2.7/cli/ipv6-addressing
https://discourse.maas.io/t/-/2767 /docs/snap/2.7/ui/ipv6-addressing
https://discourse.maas.io/t/-/2768 /docs/snap/2.8/cli/ipv6-addressing
https://discourse.maas.io/t/-/2769 /docs/snap/2.8/ui/ipv6-addressing
https://discourse.maas.io/t/-/2772 /docs/deb/2.7/cli/ipv6-addressing
https://discourse.maas.io/t/-/2773 /docs/deb/2.7/ui/ipv6-addressing
https://discourse.maas.io/t/-/2774 /docs/deb/2.8/cli/ipv6-addressing
https://discourse.maas.io/t/-/2775 /docs/deb/2.8/ui/ipv6-addressing
https://discourse.maas.io/t/-/756/ /docs/install-from-iso
https://discourse.maas.io/t/-/2778 /docs/snap/2.7/cli/kernel-boot-options
https://discourse.maas.io/t/-/2779 /docs/snap/2.7/ui/kernel-boot-options
https://discourse.maas.io/t/-/2780 /docs/snap/2.8/cli/kernel-boot-options
https://discourse.maas.io/t/-/2781 /docs/snap/2.8/ui/kernel-boot-options
https://discourse.maas.io/t/-/2784 /docs/deb/2.7/cli/kernel-boot-options
https://discourse.maas.io/t/-/2785 /docs/deb/2.7/ui/kernel-boot-options
https://discourse.maas.io/t/-/2786 /docs/deb/2.8/cli/kernel-boot-options
https://discourse.maas.io/t/-/835/ /docs/historical-release-notes
https://discourse.maas.io/t/-/2802 /docs/snap/2.7/cli/local-image-mirror
https://discourse.maas.io/t/-/2803 /docs/snap/2.7/ui/local-image-mirror
https://discourse.maas.io/t/-/2804 /docs/snap/2.8/cli/local-image-mirror
https://discourse.maas.io/t/-/2805 /docs/snap/2.8/ui/local-image-mirror
https://discourse.maas.io/t/-/2808 /docs/deb/2.7/cli/local-image-mirror
https://discourse.maas.io/t/-/2809 /docs/deb/2.7/ui/local-image-mirror
https://discourse.maas.io/t/-/2810 /docs/deb/2.8/cli/local-image-mirror
https://discourse.maas.io/t/-/2811 /docs/deb/2.8/ui/local-image-mirror
https://discourse.maas.io/t/-/2814 /docs/snap/2.7/cli/maas-cli
https://discourse.maas.io/t/-/2815 /docs/snap/2.7/ui/maas-cli
https://discourse.maas.io/t/-/2816 /docs/snap/2.8/cli/maas-cli
https://discourse.maas.io/t/-/2817 /docs/snap/2.8/ui/maas-cli
https://discourse.maas.io/t/-/2820 /docs/deb/2.7/cli/maas-cli
https://discourse.maas.io/t/-/2821 /docs/deb/2.7/ui/maas-cli
https://discourse.maas.io/t/-/2822 /docs/deb/2.8/cli/maas-cli
https://discourse.maas.io/t/-/2823 /docs/deb/2.8/ui/maas-cli
https://discourse.maas.io/t/-/2826 /docs/snap/2.7/cli/maas-communication
https://discourse.maas.io/t/-/2827 /docs/snap/2.7/ui/maas-communication
https://discourse.maas.io/t/-/2828 /docs/snap/2.8/cli/maas-communication
https://discourse.maas.io/t/-/2829 /docs/snap/2.8/ui/maas-communication
https://discourse.maas.io/t/-/2832 /docs/deb/2.7/cli/maas-communication
https://discourse.maas.io/t/-/2833 /docs/deb/2.7/ui/maas-communication
https://discourse.maas.io/t/-/2834 /docs/deb/2.8/cli/maas-communication
https://discourse.maas.io/t/-/2835 /docs/deb/2.8/ui/maas-communication
https://discourse.maas.io/t/-/2838 /docs/snap/2.7/cli/maas-documentation
https://discourse.maas.io/t/-/2839 /docs/snap/2.7/ui/maas-documentation
https://discourse.maas.io/t/-/2840 /docs/snap/2.8/cli/maas-documentation
https://discourse.maas.io/t/-/2841 /docs/snap/2.8/ui/maas-documentation
https://discourse.maas.io/t/-/2842 /docs/snap/2.9/cli/maas-documentation
https://discourse.maas.io/t/-/2843 /docs/snap/2.9/ui/maas-documentation
https://discourse.maas.io/t/-/2844 /docs/deb/2.7/cli/maas-documentation
https://discourse.maas.io/t/-/2845 /docs/deb/2.7/ui/maas-documentation
https://discourse.maas.io/t/-/2846 /docs/deb/2.8/cli/maas-documentation
https://discourse.maas.io/t/-/2847 /docs/deb/2.8/ui/maas-documentation
https://discourse.maas.io/t/-/25 /docs/maas-documentation
https://discourse.maas.io/t/-/2850 /docs/snap/2.7/cli/maas-image-builder
https://discourse.maas.io/t/-/2851 /docs/snap/2.7/ui/maas-image-builder
https://discourse.maas.io/t/-/2852 /docs/snap/2.8/cli/maas-image-builder
https://discourse.maas.io/t/-/2853 /docs/snap/2.8/ui/maas-image-builder
https://discourse.maas.io/t/-/2856 /docs/deb/2.7/cli/maas-image-builder
https://discourse.maas.io/t/-/2857 /docs/deb/2.7/ui/maas-image-builder
https://discourse.maas.io/t/-/2858 /docs/deb/2.8/cli/maas-image-builder
https://discourse.maas.io/t/-/2859 /docs/deb/2.8/ui/maas-image-builder
https://discourse.maas.io/t/-/2862 /docs/snap/2.7/cli/maas-logging
https://discourse.maas.io/t/-/2863 /docs/snap/2.7/ui/maas-logging
https://discourse.maas.io/t/-/2864 /docs/snap/2.8/cli/maas-logging
https://discourse.maas.io/t/-/2865 /docs/snap/2.8/ui/maas-logging
https://discourse.maas.io/t/-/2868 /docs/deb/2.7/cli/maas-logging
https://discourse.maas.io/t/-/2869 /docs/deb/2.7/ui/maas-logging
https://discourse.maas.io/t/-/2870 /docs/deb/2.8/cli/maas-logging
https://discourse.maas.io/t/-/2871 /docs/deb/2.8/ui/maas-logging
https://discourse.maas.io/t/-/2874 /docs/snap/2.7/cli/maas-requirements
https://discourse.maas.io/t/-/2875 /docs/snap/2.7/ui/maas-requirements
https://discourse.maas.io/t/-/2876 /docs/snap/2.8/cli/maas-requirements
https://discourse.maas.io/t/-/2877 /docs/snap/2.8/ui/maas-requirements
https://discourse.maas.io/t/-/2880 /docs/deb/2.7/cli/maas-requirements
https://discourse.maas.io/t/-/2881 /docs/deb/2.7/ui/maas-requirements
https://discourse.maas.io/t/-/2882 /docs/deb/2.8/cli/maas-requirements
https://discourse.maas.io/t/-/2883 /docs/deb/2.8/ui/maas-requirements
https://discourse.maas.io/t/-/2730 /docs/snap/2.7/cli/machines
https://discourse.maas.io/t/-/2731 /docs/snap/2.7/ui/machines
https://discourse.maas.io/t/-/2732 /docs/snap/2.8/cli/machines
https://discourse.maas.io/t/-/2733 /docs/snap/2.8/ui/machines
https://discourse.maas.io/t/-/2736 /docs/deb/2.7/cli/machines
https://discourse.maas.io/t/-/2737 /docs/deb/2.7/ui/machines
https://discourse.maas.io/t/-/2738 /docs/deb/2.8/cli/machines
https://discourse.maas.io/t/-/2739 /docs/deb/2.8/ui/machines
https://discourse.maas.io/t/-/2466 /docs/snap/2.7/cli/manage-machine-interfaces
https://discourse.maas.io/t/-/2467 /docs/snap/2.7/ui/manage-machine-interfaces
https://discourse.maas.io/t/-/2468 /docs/snap/2.8/cli/manage-machine-interfaces
https://discourse.maas.io/t/-/2469 /docs/snap/2.8/ui/manage-machine-interfaces
https://discourse.maas.io/t/-/2472 /docs/deb/2.7/cli/manage-machine-interfaces
https://discourse.maas.io/t/-/2473 /docs/deb/2.7/ui/manage-machine-interfaces
https://discourse.maas.io/t/-/2474 /docs/deb/2.8/cli/manage-machine-interfaces
https://discourse.maas.io/t/-/2475 /docs/deb/2.8/ui/manage-machine-interfaces
https://discourse.maas.io/t/-/2898 /docs/snap/2.7/cli/managing-dhcp
https://discourse.maas.io/t/-/2899 /docs/snap/2.7/ui/managing-dhcp
https://discourse.maas.io/t/-/2900 /docs/snap/2.8/cli/managing-dhcp
https://discourse.maas.io/t/-/2901 /docs/snap/2.8/ui/managing-dhcp
https://discourse.maas.io/t/-/2904 /docs/deb/2.7/cli/managing-dhcp
https://discourse.maas.io/t/-/2905 /docs/deb/2.7/ui/managing-dhcp
https://discourse.maas.io/t/-/2906 /docs/deb/2.8/cli/managing-dhcp
https://discourse.maas.io/t/-/2907 /docs/deb/2.8/ui/managing-dhcp
https://discourse.maas.io/t/-/2910 /docs/snap/2.7/cli/managing-stp
https://discourse.maas.io/t/-/2911 /docs/snap/2.7/ui/managing-stp
https://discourse.maas.io/t/-/2912 /docs/snap/2.8/cli/managing-stp
https://discourse.maas.io/t/-/2913 /docs/snap/2.8/ui/managing-stp
https://discourse.maas.io/t/-/2916 /docs/deb/2.7/cli/managing-stp
https://discourse.maas.io/t/-/2917 /docs/deb/2.7/ui/managing-stp
https://discourse.maas.io/t/-/2918 /docs/deb/2.8/cli/managing-stp
https://discourse.maas.io/t/-/2919 /docs/deb/2.8/ui/managing-stp
https://discourse.maas.io/t/-/2922 /docs/snap/2.7/cli/network-discovery
https://discourse.maas.io/t/-/2923 /docs/snap/2.7/ui/network-discovery
https://discourse.maas.io/t/-/2924 /docs/snap/2.8/cli/network-discovery
https://discourse.maas.io/t/-/2925 /docs/snap/2.8/ui/network-discovery
https://discourse.maas.io/t/-/2928 /docs/deb/2.7/cli/network-discovery
https://discourse.maas.io/t/-/2929 /docs/deb/2.7/ui/network-discovery
https://discourse.maas.io/t/-/2930 /docs/deb/2.8/cli/network-discovery
https://discourse.maas.io/t/-/2931 /docs/deb/2.8/ui/network-discovery
https://discourse.maas.io/t/-/2946 /docs/snap/2.7/cli/networking
https://discourse.maas.io/t/-/2947 /docs/snap/2.7/ui/networking
https://discourse.maas.io/t/-/2948 /docs/snap/2.8/cli/networking
https://discourse.maas.io/t/-/2949 /docs/snap/2.8/ui/networking
https://discourse.maas.io/t/-/2952 /docs/deb/2.7/cli/networking
https://discourse.maas.io/t/-/2953 /docs/deb/2.7/ui/networking
https://discourse.maas.io/t/-/2954 /docs/deb/2.8/cli/networking
https://discourse.maas.io/t/-/2955 /docs/deb/2.8/ui/networking
https://discourse.maas.io/t/-/2934 /docs/snap/2.7/cli/network-testing
https://discourse.maas.io/t/-/2935 /docs/snap/2.7/ui/network-testing
https://discourse.maas.io/t/-/2936 /docs/snap/2.8/cli/network-testing
https://discourse.maas.io/t/-/2937 /docs/snap/2.8/ui/network-testing
https://discourse.maas.io/t/-/2940 /docs/deb/2.7/cli/network-testing
https://discourse.maas.io/t/-/2941 /docs/deb/2.7/ui/network-testing
https://discourse.maas.io/t/-/2942 /docs/deb/2.8/cli/network-testing
https://discourse.maas.io/t/-/2943 /docs/deb/2.8/ui/network-testing
https://discourse.maas.io/t/-/2958 /docs/snap/2.7/cli/ntp-services
https://discourse.maas.io/t/-/2959 /docs/snap/2.7/ui/ntp-services
https://discourse.maas.io/t/-/2960 /docs/snap/2.8/cli/ntp-services
https://discourse.maas.io/t/-/2961 /docs/snap/2.8/ui/ntp-services
https://discourse.maas.io/t/-/2964 /docs/deb/2.7/cli/ntp-services
https://discourse.maas.io/t/-/2965 /docs/deb/2.7/ui/ntp-services
https://discourse.maas.io/t/-/2966 /docs/deb/2.8/cli/ntp-services
https://discourse.maas.io/t/-/2967 /docs/deb/2.8/ui/ntp-services
https://discourse.maas.io/t/-/2976 /docs/deb/2.7/cli/package-repositories
https://discourse.maas.io/t/-/2977 /docs/deb/2.7/ui/package-repositories
https://discourse.maas.io/t/-/2978 /docs/deb/2.8/cli/package-repositories
https://discourse.maas.io/t/-/2979 /docs/deb/2.8/ui/package-repositories
https://discourse.maas.io/t/-/2980 /docs/deb/2.9/cli/package-repositories
https://discourse.maas.io/t/-/2981 /docs/deb/2.9/ui/package-repositories
https://discourse.maas.io/t/-/4059 /docs/deb/3.0/cli/package-repositories
https://discourse.maas.io/t/-/4060 /docs/deb/3.0/ui/package-repositories
https://discourse.maas.io/t/-/2982 /docs/snap/2.7/cli/partitions
https://discourse.maas.io/t/-/2983 /docs/snap/2.7/ui/partitions
https://discourse.maas.io/t/-/2984 /docs/snap/2.8/cli/partitions
https://discourse.maas.io/t/-/2985 /docs/snap/2.8/ui/partitions
https://discourse.maas.io/t/-/2988 /docs/deb/2.7/cli/partitions
https://discourse.maas.io/t/-/2989 /docs/deb/2.7/ui/partitions
https://discourse.maas.io/t/-/2990 /docs/deb/2.8/cli/partitions
https://discourse.maas.io/t/-/2991 /docs/deb/2.8/ui/partitions
https://discourse.maas.io/t/-/2994 /docs/snap/2.7/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/2995 /docs/snap/2.7/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/2996 /docs/snap/2.8/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/2997 /docs/snap/2.8/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/2998 /docs/snap/2.9/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/2999 /docs/snap/2.9/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3000 /docs/deb/2.7/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3001 /docs/deb/2.7/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3002 /docs/deb/2.8/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3003 /docs/deb/2.8/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3004 /docs/deb/2.9/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3005 /docs/deb/2.9/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/4065 /docs/snap/3.0/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/4066 /docs/snap/3.0/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/4067 /docs/deb/3.0/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/4068 /docs/deb/3.0/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/5307 /docs/snap/3.1/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/5308 /docs/snap/3.1/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/5309 /docs/deb/3.1/ui/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/5310 /docs/deb/3.1/cli/postgresql-ha-hot-standby
https://discourse.maas.io/t/-/3006 /docs/snap/2.7/cli/power-management
https://discourse.maas.io/t/-/3007 /docs/snap/2.7/ui/power-management
https://discourse.maas.io/t/-/3008 /docs/snap/2.8/cli/power-management
https://discourse.maas.io/t/-/3009 /docs/snap/2.8/ui/power-management
https://discourse.maas.io/t/-/3012 /docs/deb/2.7/cli/power-management
https://discourse.maas.io/t/-/3013 /docs/deb/2.7/ui/power-management
https://discourse.maas.io/t/-/3014 /docs/deb/2.8/cli/power-management
https://discourse.maas.io/t/-/3015 /docs/deb/2.8/ui/power-management
https://discourse.maas.io/t/-/5246 /docs/power-management-reference
https://discourse.maas.io/t/-/3018 /docs/snap/2.7/cli/prometheus-metrics
https://discourse.maas.io/t/-/3019 /docs/snap/2.7/ui/prometheus-metrics
https://discourse.maas.io/t/-/3020 /docs/snap/2.8/cli/prometheus-metrics
https://discourse.maas.io/t/-/3021 /docs/snap/2.8/ui/prometheus-metrics
https://discourse.maas.io/t/-/3024 /docs/deb/2.7/cli/prometheus-metrics
https://discourse.maas.io/t/-/3025 /docs/deb/2.7/ui/prometheus-metrics
https://discourse.maas.io/t/-/3026 /docs/deb/2.8/cli/prometheus-metrics
https://discourse.maas.io/t/-/3027 /docs/deb/2.8/ui/prometheus-metrics
https://discourse.maas.io/t/-/5204 /docs/how-to-observe-a-live-maas
https://discourse.maas.io/t/-/3030 /docs/snap/2.7/cli/proxy
https://discourse.maas.io/t/-/3031 /docs/snap/2.7/ui/proxy
https://discourse.maas.io/t/-/3032 /docs/snap/2.8/cli/proxy
https://discourse.maas.io/t/-/3033 /docs/snap/2.8/ui/proxy
https://discourse.maas.io/t/-/3036 /docs/deb/2.7/cli/proxy
https://discourse.maas.io/t/-/3037 /docs/deb/2.7/ui/proxy
https://discourse.maas.io/t/-/3038 /docs/deb/2.8/cli/proxy
https://discourse.maas.io/t/-/3039 /docs/deb/2.8/ui/proxy
https://discourse.maas.io/t/-/4077 /docs/snap/3.0/cli/proxy-log
https://discourse.maas.io/t/-/4078 /docs/snap/3.0/ui/proxy-log
https://discourse.maas.io/t/-/4079 /docs/deb/3.0/cli/proxy-log
https://discourse.maas.io/t/-/4080 /docs/deb/3.0/ui/proxy-log
https://discourse.maas.io/t/-/3054 /docs/snap/2.7/cli/rack-controllers
https://discourse.maas.io/t/-/3055 /docs/snap/2.7/ui/rack-controllers
https://discourse.maas.io/t/-/3056 /docs/snap/2.8/cli/rack-controllers
https://discourse.maas.io/t/-/3057 /docs/snap/2.8/ui/rack-controllers
https://discourse.maas.io/t/-/3060 /docs/deb/2.7/cli/rack-controllers
https://discourse.maas.io/t/-/3061 /docs/deb/2.7/ui/rack-controllers
https://discourse.maas.io/t/-/3062 /docs/deb/2.8/cli/rack-controllers
https://discourse.maas.io/t/-/3063 /docs/deb/2.8/ui/rack-controllers
https://discourse.maas.io/t/-/3066 /docs/snap/2.7/cli/region-controllers
https://discourse.maas.io/t/-/3067 /docs/snap/2.7/ui/region-controllers
https://discourse.maas.io/t/-/3068 /docs/snap/2.8/cli/region-controllers
https://discourse.maas.io/t/-/3069 /docs/snap/2.8/ui/region-controllers
https://discourse.maas.io/t/-/3072 /docs/deb/2.7/cli/region-controllers
https://discourse.maas.io/t/-/3073 /docs/deb/2.7/ui/region-controllers
https://discourse.maas.io/t/-/3074 /docs/deb/2.8/cli/region-controllers
https://discourse.maas.io/t/-/3075 /docs/deb/2.8/ui/region-controllers
https://discourse.maas.io/t/-/3078 /docs/snap/2.7/cli/resource-pools
https://discourse.maas.io/t/-/3079 /docs/snap/2.7/ui/resource-pools
https://discourse.maas.io/t/-/3080 /docs/snap/2.8/cli/resource-pools
https://discourse.maas.io/t/-/3081 /docs/snap/2.8/ui/resource-pools
https://discourse.maas.io/t/-/3082 /docs/snap/2.9/cli/resource-pools
https://discourse.maas.io/t/-/3083 /docs/snap/2.9/ui/resource-pools
https://discourse.maas.io/t/-/3084 /docs/deb/2.7/cli/resource-pools
https://discourse.maas.io/t/-/3085 /docs/deb/2.7/ui/resource-pools
https://discourse.maas.io/t/-/3086 /docs/deb/2.8/cli/resource-pools
https://discourse.maas.io/t/-/3087 /docs/deb/2.8/ui/resource-pools
https://discourse.maas.io/t/-/3088 /docs/deb/2.9/cli/resource-pools
https://discourse.maas.io/t/-/3089 /docs/deb/2.9/ui/resource-pools
https://discourse.maas.io/t/-/4097 /docs/snap/3.0/cli/resource-pools
https://discourse.maas.io/t/-/4098 /docs/snap/3.0/ui/resource-pools
https://discourse.maas.io/t/-/4099 /docs/deb/3.0/cli/resource-pools
https://discourse.maas.io/t/-/4100 /docs/deb/3.0/ui/resource-pools
https://discourse.maas.io/t/-/3090 /docs/snap/2.7/cli/select-and-import-images
https://discourse.maas.io/t/-/3091 /docs/snap/2.7/ui/select-and-import-images
https://discourse.maas.io/t/-/3092 /docs/snap/2.8/cli/select-and-import-images
https://discourse.maas.io/t/-/3093 /docs/snap/2.8/ui/select-and-import-images
https://discourse.maas.io/t/-/3096 /docs/deb/2.7/cli/select-and-import-images
https://discourse.maas.io/t/-/3097 /docs/deb/2.7/ui/select-and-import-images
https://discourse.maas.io/t/-/3098 /docs/deb/2.8/cli/select-and-import-images
https://discourse.maas.io/t/-/3099 /docs/deb/2.8/ui/select-and-import-images
https://discourse.maas.io/t/-/3102 /docs/snap/2.7/cli/storage
https://discourse.maas.io/t/-/3103 /docs/snap/2.7/ui/storage
https://discourse.maas.io/t/-/3104 /docs/snap/2.8/cli/storage
https://discourse.maas.io/t/-/3105 /docs/snap/2.8/ui/storage
https://discourse.maas.io/t/-/3106 /docs/snap/2.9/cli/storage
https://discourse.maas.io/t/-/3107 /docs/snap/2.9/ui/storage
https://discourse.maas.io/t/-/3108 /docs/deb/2.7/cli/storage
https://discourse.maas.io/t/-/3109 /docs/deb/2.7/ui/storage
https://discourse.maas.io/t/-/3110 /docs/deb/2.8/cli/storage
https://discourse.maas.io/t/-/3111 /docs/deb/2.8/ui/storage
https://discourse.maas.io/t/-/3112 /docs/deb/2.9/cli/storage
https://discourse.maas.io/t/-/3113 /docs/deb/2.9/ui/storage
https://discourse.maas.io/t/-/4105 /docs/snap/3.0/cli/storage
https://discourse.maas.io/t/-/4106 /docs/snap/3.0/ui/storage
https://discourse.maas.io/t/-/4107 /docs/deb/3.0/cli/storage
https://discourse.maas.io/t/-/4108 /docs/deb/3.0/ui/storage
https://discourse.maas.io/t/-/3114 /docs/snap/2.7/cli/subnet-management
https://discourse.maas.io/t/-/3115 /docs/snap/2.7/ui/subnet-management
https://discourse.maas.io/t/-/3116 /docs/snap/2.8/cli/subnet-management
https://discourse.maas.io/t/-/3117 /docs/snap/2.8/ui/subnet-management
https://discourse.maas.io/t/-/3120 /docs/deb/2.7/cli/subnet-management
https://discourse.maas.io/t/-/3121 /docs/deb/2.7/ui/subnet-management
https://discourse.maas.io/t/-/3122 /docs/deb/2.8/cli/subnet-management
https://discourse.maas.io/t/-/3123 /docs/deb/2.8/ui/subnet-management
https://discourse.maas.io/t/-/2886 /docs/snap/2.7/cli/tags-and-annotations
https://discourse.maas.io/t/-/2887 /docs/snap/2.7/ui/tags-and-annotations
https://discourse.maas.io/t/-/2888 /docs/snap/2.8/cli/tags-and-annotations
https://discourse.maas.io/t/-/2889 /docs/snap/2.8/ui/tags-and-annotations
https://discourse.maas.io/t/-/2892 /docs/deb/2.7/cli/tags-and-annotations
https://discourse.maas.io/t/-/2893 /docs/deb/2.7/ui/tags-and-annotations
https://discourse.maas.io/t/-/2894 /docs/deb/2.8/cli/tags-and-annotations
https://discourse.maas.io/t/-/2895 /docs/deb/2.8/ui/tags-and-annotations
https://discourse.maas.io/t/-/3126 /docs/snap/2.7/cli/test-logs
https://discourse.maas.io/t/-/3127 /docs/snap/2.7/ui/test-logs
https://discourse.maas.io/t/-/3128 /docs/snap/2.8/cli/test-logs
https://discourse.maas.io/t/-/3129 /docs/snap/2.8/ui/test-logs
https://discourse.maas.io/t/-/3132 /docs/deb/2.7/cli/test-logs
https://discourse.maas.io/t/-/3133 /docs/deb/2.7/ui/test-logs
https://discourse.maas.io/t/-/3134 /docs/deb/2.8/cli/test-logs
https://discourse.maas.io/t/-/3135 /docs/deb/2.8/ui/test-logs
https://discourse.maas.io/t/-/3150 /docs/snap/2.7/cli/tips-tricks-and-traps
https://discourse.maas.io/t/-/3151 /docs/snap/2.7/ui/tips-tricks-and-traps
https://discourse.maas.io/t/-/3152 /docs/snap/2.8/cli/tips-tricks-and-traps
https://discourse.maas.io/t/-/3153 /docs/snap/2.8/ui/tips-tricks-and-traps
https://discourse.maas.io/t/-/3156 /docs/deb/2.7/cli/tips-tricks-and-traps
https://discourse.maas.io/t/-/3157 /docs/deb/2.7/ui/tips-tricks-and-traps
https://discourse.maas.io/t/-/3158 /docs/deb/2.8/cli/tips-tricks-and-traps
https://discourse.maas.io/t/-/3159 /docs/deb/2.8/ui/tips-tricks-and-traps
https://discourse.maas.io/t/-/3162 /docs/snap/2.7/cli/troubleshooting
https://discourse.maas.io/t/-/3163 /docs/snap/2.7/ui/troubleshooting
https://discourse.maas.io/t/-/3164 /docs/snap/2.8/cli/troubleshooting
https://discourse.maas.io/t/-/3165 /docs/snap/2.8/ui/troubleshooting
https://discourse.maas.io/t/-/3168 /docs/deb/2.7/cli/troubleshooting
https://discourse.maas.io/t/-/3169 /docs/deb/2.7/ui/troubleshooting
https://discourse.maas.io/t/-/3170 /docs/deb/2.8/cli/troubleshooting
https://discourse.maas.io/t/-/3171 /docs/deb/2.8/ui/troubleshooting
https://discourse.maas.io/t/-/3174 /docs/snap/2.7/cli/ubuntu-kernels
https://discourse.maas.io/t/-/3175 /docs/snap/2.7/ui/ubuntu-kernels
https://discourse.maas.io/t/-/3176 /docs/snap/2.8/cli/ubuntu-kernels
https://discourse.maas.io/t/-/3177 /docs/snap/2.8/ui/ubuntu-kernels
https://discourse.maas.io/t/-/3180 /docs/deb/2.7/cli/ubuntu-kernels
https://discourse.maas.io/t/-/3181 /docs/deb/2.7/ui/ubuntu-kernels
https://discourse.maas.io/t/-/3182 /docs/deb/2.8/cli/ubuntu-kernels
https://discourse.maas.io/t/-/3183 /docs/deb/2.8/ui/ubuntu-kernels
https://discourse.maas.io/t/-/5706 /docs/how-to-upgrade-older-maas-installs
https://discourse.maas.io/t/-/3198 /docs/snap/2.7/cli/user-accounts
https://discourse.maas.io/t/-/3199 /docs/snap/2.7/ui/user-accounts
https://discourse.maas.io/t/-/3200 /docs/snap/2.8/cli/user-accounts
https://discourse.maas.io/t/-/3201 /docs/snap/2.8/ui/user-accounts
https://discourse.maas.io/t/-/3204 /docs/deb/2.7/cli/user-accounts
https://discourse.maas.io/t/-/3205 /docs/deb/2.7/ui/user-accounts
https://discourse.maas.io/t/-/3206 /docs/deb/2.8/cli/user-accounts
https://discourse.maas.io/t/-/3207 /docs/deb/2.8/ui/user-accounts
https://discourse.maas.io/t/-/4324 /docs/snap/2.7/cli/using-image-streams
https://discourse.maas.io/t/-/4325 /docs/snap/2.7/ui/using-image-streams
https://discourse.maas.io/t/-/4326 /docs/snap/2.8/cli/using-image-streams
https://discourse.maas.io/t/-/4327 /docs/snap/2.8/ui/using-image-streams
https://discourse.maas.io/t/-/4330 /docs/deb/2.7/cli/using-image-streams
https://discourse.maas.io/t/-/4331 /docs/deb/2.7/ui/using-image-streams
https://discourse.maas.io/t/-/4332 /docs/deb/2.8/cli/using-image-streams
https://discourse.maas.io/t/-/4333 /docs/deb/2.8/ui/using-image-streams
https://discourse.maas.io/t/-/4157 /docs/snap/3.0/cli/using-rbac-with-maas
https://discourse.maas.io/t/-/4158 /docs/snap/3.0/ui/using-rbac-with-maas
https://discourse.maas.io/t/-/4159 /docs/deb/3.0/cli/using-rbac-with-maas
https://discourse.maas.io/t/-/4160 /docs/deb/3.0/ui/using-rbac-with-maas
https://discourse.maas.io/t/-/2742 /docs/snap/2.7/cli/vm-hosting
https://discourse.maas.io/t/-/2743 /docs/snap/2.7/ui/vm-hosting
https://discourse.maas.io/t/-/2744 /docs/snap/2.8/cli/vm-hosting
https://discourse.maas.io/t/-/2745 /docs/snap/2.8/ui/vm-hosting
https://discourse.maas.io/t/-/2748 /docs/deb/2.7/cli/vm-hosting
https://discourse.maas.io/t/-/2749 /docs/deb/2.7/ui/vm-hosting
https://discourse.maas.io/t/-/2750 /docs/deb/2.8/cli/vm-hosting
https://discourse.maas.io/t/-/2751 /docs/deb/2.8/ui/vm-hosting
https://discourse.maas.io/t/-/3210 /docs/snap/2.7/cli/vm-host-networking
https://discourse.maas.io/t/-/3211 /docs/snap/2.7/ui/vm-host-networking
https://discourse.maas.io/t/-/3212 /docs/snap/2.8/cli/vm-host-networking
https://discourse.maas.io/t/-/3213 /docs/snap/2.8/ui/vm-host-networking
https://discourse.maas.io/t/-/3216 /docs/deb/2.7/cli/vm-host-networking
https://discourse.maas.io/t/-/3217 /docs/deb/2.7/ui/vm-host-networking
https://discourse.maas.io/t/-/3218 /docs/deb/2.8/cli/vm-host-networking
https://discourse.maas.io/t/-/3219 /docs/deb/2.8/ui/vm-host-networking
https://discourse.maas.io/t/-/3222 /docs/snap/2.7/cli/vm-host-storage-pools
https://discourse.maas.io/t/-/3223 /docs/snap/2.7/ui/vm-host-storage-pools
https://discourse.maas.io/t/-/3224 /docs/snap/2.8/cli/vm-host-storage-pools
https://discourse.maas.io/t/-/3225 /docs/snap/2.8/ui/vm-host-storage-pools
https://discourse.maas.io/t/-/3228 /docs/deb/2.7/cli/vm-host-storage-pools
https://discourse.maas.io/t/-/3229 /docs/deb/2.7/ui/vm-host-storage-pools
https://discourse.maas.io/t/-/3230 /docs/deb/2.8/cli/vm-host-storage-pools
https://discourse.maas.io/t/-/3231 /docs/deb/2.8/ui/vm-host-storage-pools
https://discourse.maas.io/t/-/3234 /docs/snap/2.7/cli/vmware-images
https://discourse.maas.io/t/-/3235 /docs/snap/2.7/ui/vmware-images
https://discourse.maas.io/t/-/3236 /docs/snap/2.8/cli/vmware-images
https://discourse.maas.io/t/-/3237 /docs/snap/2.8/ui/vmware-images
https://discourse.maas.io/t/-/3240 /docs/deb/2.7/cli/vmware-images
https://discourse.maas.io/t/-/3241 /docs/deb/2.7/ui/vmware-images
https://discourse.maas.io/t/-/3242 /docs/deb/2.8/cli/vmware-images
https://discourse.maas.io/t/-/3243 /docs/deb/2.8/ui/vmware-images
https://discourse.maas.io/t/-/3246 /docs/snap/2.7/cli/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3247 /docs/snap/2.7/ui/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3248 /docs/snap/2.8/cli/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3249 /docs/snap/2.8/ui/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3252 /docs/deb/2.7/cli/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3253 /docs/deb/2.7/ui/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3254 /docs/deb/2.8/cli/vmware-vmfs-datastores
https://discourse.maas.io/t/-/3255 /docs/deb/2.8/ui/vmware-vmfs-datastores
https://discourse.maas.io/t/-/4292 /docs/deb/2.8/cli/whats-new-in-maas
https://discourse.maas.io/t/-/4293 /docs/deb/2.8/ui/whats-new-in-maas
https://discourse.maas.io/t/-/4294 /docs/deb/2.7/cli/whats-new-in-maas
https://discourse.maas.io/t/-/4295 /docs/deb/2.7/ui/whats-new-in-maas
https://discourse.maas.io/t/-/4298 /docs/snap/2.8/cli/whats-new-in-maas
https://discourse.maas.io/t/-/4299 /docs/snap/2.8/ui/whats-new-in-maas
https://discourse.maas.io/t/-/4300 /docs/snap/2.7/cli/whats-new-in-maas
https://discourse.maas.io/t/-/4301 /docs/snap/2.7/ui/whats-new-in-maas
https://discourse.maas.io/t/-/5292 /docs/what-is-new-with-maas
https://discourse.maas.io/t/-/3258 /docs/snap/2.7/cli/writing-guide
https://discourse.maas.io/t/-/3259 /docs/snap/2.7/ui/writing-guide
https://discourse.maas.io/t/-/3260 /docs/snap/2.8/cli/writing-guide
https://discourse.maas.io/t/-/3261 /docs/snap/2.8/ui/writing-guide
https://discourse.maas.io/t/-/3264 /docs/deb/2.7/cli/writing-guide
https://discourse.maas.io/t/-/3265 /docs/deb/2.7/ui/writing-guide
https://discourse.maas.io/t/-/3266 /docs/deb/2.8/cli/writing-guide
https://discourse.maas.io/t/-/3267 /docs/deb/2.8/ui/writing-guide
https://discourse.maas.io/t/-/3270 /docs/snap/2.7/cli/zone-examples
https://discourse.maas.io/t/-/3271 /docs/snap/2.7/ui/zone-examples
https://discourse.maas.io/t/-/3272 /docs/snap/2.8/cli/zone-examples
https://discourse.maas.io/t/-/3273 /docs/snap/2.8/ui/zone-examples
https://discourse.maas.io/t/-/3276 /docs/deb/2.7/cli/zone-examples
https://discourse.maas.io/t/-/3277 /docs/deb/2.7/ui/zone-examples
https://discourse.maas.io/t/-/3278 /docs/deb/2.8/cli/zone-examples
https://discourse.maas.io/t/-/3279 /docs/deb/2.8/ui/zone-examples
https://discourse.maas.io/t/report-a-bug/4446 /docs/how-to-report-a-bug
https://discourse.maas.io//t/-/4447 /docs/how-to-request-a-feature
https://discourse.maas.io/t/request-a-feature/4447 /docs/request-a-feature
https://discourse.maas.io/t/-/25/ /docs
https://discourse.maas.io/t/-/815/ /docs/add-an-rsd-host
https://discourse.maas.io/t/-/793/ /docs/advanced-cli-tasks
https://discourse.maas.io/t/-/5392 /docs/hardware-test-scripts-reference
https://discourse.maas.io/t/-/744/ /docs/building-the-docs
https://discourse.maas.io/t/-/2218/ /docs/cli-cookbook
https://discourse.maas.io/t/-/797/ /docs/cli-image-management
https://discourse.maas.io/t/-/798/ /docs/cli-interface-management
https://discourse.maas.io/t/-/799/ /docs/cli-kernel-management
https://discourse.maas.io/t/-/832/ /docs/cli-testing-scripts
https://discourse.maas.io/t/-/832 /docs/cli-testing-scripts
https://discourse.maas.io/t/-/794/ /docs/common-cli-tasks
https://discourse.maas.io/t/-/795/ /docs/composable-hardware
https://discourse.maas.io/t/-/3771/ /docs/supported-versions
https://discourse.maas.io/t/-/782/ /docs/web-ui
https://discourse.maas.io/t/-/835/ /docs/whats-new-in-2-6
https://discourse.maas.io/t/-/746/ /docs/working-with-git-and-github
https://discourse.maas.io/t/whats-new-in-2-6/788/ /docs/whats-new-in-2-6
https://discourse.maas.io/t/maas-projects/4460 /docs/maas-projects
https://discourse.maas.io/t/-/818/ /docs/rsd-storage
https://discourse.maas.io/t/-/1112 /docs/image-builder
https://discourse.maas.io/t/-/4478 /docs/maas-project-tutorial
https://discourse.maas.io/t/-/5436 /docs/how-to-upgrade-maas
https://discourse.maas.io/t/-/5232 /docs/how-to-use-storage-tags
https://discourse.maas.io/t/-/5252 /docs/event-log-reference
https://discourse.maas.io/t/-/5228 /docs/how-to-use-network-tags
https://discourse.maas.io/t/-/5084 /docs/about-networking
https://discourse.maas.io/t/-/5104 /docs/how-to-build-custom-images
https://discourse.maas.io/t/-/5152 /docs/how-to-manage-availability-zones
https://discourse.maas.io/t/-/5928 /docs/how-to-tag-machines
https://discourse.maas.io/t/-/5929 /docs/how-to-annotate-machines
https://discourse.maas.io/t/-/5216 /docs/how-to-use-controller-tags
https://discourse.maas.io/t/-/5208 /docs/how-to-set-up-lxd
https://discourse.maas.io/t/-/5224 /docs/how-to-use-machine-tags
https://discourse.maas.io/t/-/5148 /docs/how-to-create-and-manage-vms
https://discourse.maas.io/t/-/5132 /docs/how-to-enable-dhcp
https://discourse.maas.io/t/-/5064 /docs/about-maas
https://discourse.maas.io/t/-/5080 /docs/about-machines
https://discourse.maas.io/t/-/5060 /docs/api-authentication-reference
https://discourse.maas.io/t/-/5096 /docs/how-to-keep-maas-backed-up
https://discourse.maas.io/t/-/5248 /docs/commissioning-log-reference
https://discourse.maas.io/t/-/5196 /docs/how-to-improve-maas-security
https://discourse.maas.io/t/-/5120 /docs/how-to-enable-high-availability
https://discourse.maas.io/t/-/5108 /docs/how-to-customise-machines
https://discourse.maas.io/t/-/5112 /docs/how-to-put-machines-to-work
https://discourse.maas.io/t/-/5160 /docs/how-to-make-machines-available
https://discourse.maas.io/t/-/5164 /docs/how-to-connect-maas-networks
https://discourse.maas.io/t/-/5140 /docs/how-to-create-vm-hosts
https://discourse.maas.io/t/-/5128 /docs/how-to-install-maas
https://discourse.maas.io/t/-/5240 /docs/how-to-work-with-log-files
https://discourse.maas.io/t/-/5172 /docs/how-to-adjust-your-controllers
https://discourse.maas.io/t/-/5124 /docs/how-use-standard-images
https://discourse.maas.io/t/-/5184 /docs/how-to-manage-user-accounts
https://discourse.maas.io/t/-/5068 /docs/about-vm-hosting
https://discourse.maas.io/t/-/5961 /docs/what-is-new-with-maas-2-9
https://discourse.maas.io/t/-/5963 /docs/what-is-new-with-maas-3-0
https://discourse.maas.io/t/-/5964 /docs/what-is-new-with-maas-3-1
https://discourse.maas.io/t/-/5962 /docs/what-is-new-with-maas-3-2
https://discourse.maas.io/t/-/5993 /docs/what-is-new-with-maas-2-7
https://discourse.maas.io/t/-/5994 /docs/what-is-new-with-maas-2-8
https://discourse.maas.io/t/-/6140 /docs/basic-tutorials
https://discourse.maas.io/t/-/5092 /docs/maas-bootstrap-tutorial
Redirects
Mapping table
PATH LOCATION
/docs/about-rbac /docs/how-to-protect-your-secrets
/docs/maas-terraform-provider /docs/maas-terraform-provider-reference
/docs/commissioning-script-reference /docs/commissioning-scripts-reference
/docs/technical-reference /docs/maas-technical-reference
/docs/how-to-set-up-maas-metrics /docs/how-to-observe-a-live-maas
/docs/how-to-back-up-maas /docs/how-to-keep-maas-backed-up
/docs/how-to-use-maas-in-an-air-gapped-environment /docs/how-to-set-up-an-air-gapped-maas
/docs/how-to-enable-tls-encryption /docs/how-to-enable-maas-native-tls
/docs/how-to-secure-maas /docs/how-to-improve-maas-security
/docs/maas-logging-reference /docs/how-to-work-with-log-files
/docs/how-to-search-maas /docs/how-to-find-machines
/docs/how-to-work-with-annotations /docs/how-to-annotate-machines
/docs/how-to-work-with-tags /docs/how-to-tag-machines
/docs/how-to-use-tags /docs/how-to-label-and-find-machines
/docs/how-to-manage-vms /docs/how-to-create-and-manage-vms
/docs/how-to-manage-vm-hosts /docs/how-to-create-vm-hosts
/docs/how-to-use-lxd /docs/how-to-set-up-lxd
/docs/how-to-deploy-machines /docs/how-to-put-machines-to-work
/docs/how-to-manage-machines /docs/how-to-make-machines-available
/docs/how-to-deploy-maas /docs/how-to-deploy-physical-machines
/docs/how-to-manage-controllers /docs/how-to-adjust-your-controllers
/docs/how-to-manage-vmware-images /docs/how-to-employ-vmware-images
/docs/how-to-create-custom-images /docs/how-to-build-custom-images
/docs/how-to-import-images /docs/how-use-standard-images
/docs/how-to-choose-images /docs/how-to-acquire-images
/docs/how-to-manage-ip-addresses /docs/how-to-enable-dhcp
/docs/how-to-manage-networks /docs/how-to-connect-maas-networks
/docs/how-to-configure-networking /docs/how-to-set-up-networks
/docs/report-a-bug /docs/how-to-report-a-bug
/docs/request-a-feature /docs/how-to-request-a-feature
/docs/how-to-get-help /docs/how-to-ask-for-help
/docs/configuration-settings-reference /docs/how-to-change-maas-settings
/docs/ansible-playbooks-reference /docs/how-to-spin-up-maas-with-ansible
/docs/how-to-get-maas-running /docs/how-to-get-started-with-maas
/docs/create-a-custom-image /docs/custom-image-tutorial
/docs/how-to-use-the-maas-cli /docs/try-out-the-maas-cli
/docs/maas-bootstrap-tutorial /docs/get-started-with-maas
/docs/tutorials /docs/basic-tutorials
/docs/maas-concepts-and-terms-reference /docs/maas-glossary
/docs/installation-requirements /docs/maas-installation-requirements
/docs/whats-new-in-maas /docs/what-is-new-with-maas
/docs/vmware-images /docs/how-to-employ-vmware-images
/docs/about-tags /docs/how-to-label-and-find-machines
/docs/ssl /docs/how-to-enable-maas-native-tls
/docs/stp /docs/how-to-connect-maas-networks
/docs/subnet-management /docs/how-to-connect-maas-newtorks
/docs/deploy-nodes /docs/how-to-put-machines-to-work
/docs/storage /docs/about-machines#heading–machine-storage
/docs/how-to-manage-regions /docs/how-to-adjust-your-controllers
/docs/how-to-manage-racks /docs/how-to-adjust-your-controllers
/docs/how-to-create-a-custom-ubuntu-image /docs/how-to-build-custom-images
/docs/how-to-build-maas-images/docs/how-to-build-custom-images
/docs/how-to-use-image-streams /docs/how-use-standard-images
/docs/how-to-manage-dhcp /docs/how-to-enable-dhcp
/docs/how-to-manage-ip-ranges /docs//docs/how-to-enable-dhcp
/docs/how-to-set-up-ntp-services /docs/how-to-connect-maas-networks
/docs/how-to-manage-machine-interfaces /docs/how-to-connect-maas-networks
/docs/how-to-manage-proxies /docs/how-to-connect-maas-networks
/docs/deb/3.0/cli/how-to-work-with-tags /docs/how-to-tag-machines
/docs/deb/3.0/ui/how-to-work-with-tags /docs/how-to-tag-machines
/docs/deb/3.1/cli/how-to-work-with-tags /docs/how-to-tag-machines
/docs/deb/3.1/ui/how-to-work-with-tags /docs/how-to-tag-machines
/docs/snap/2.7/cli/how-to-upgrade-maas /docs/how-to-upgrade-maas
/docs/snap/2.7/cli/installation-tech-reference /docs/how-to-install-maas
/docs/snap/2.7/cli/interactive-search /docs/how-to-find-machines
/docs/snap/2.7/ui/how-to-upgrade-maas /docs/how-to-upgrade-maas
/docs/snap/2.7/ui/installation-tech-reference /docs/how-to-install-maas
/docs/snap/2.7/ui/interactive-search /docs/how-to-find-machines
/docs/snap/2.8/cli/how-to-upgrade-maas /docs/how-to-upgrade-maas
/docs/snap/2.8/cli/installation-tech-reference /docs/how-to-install-maas
/docs/snap/2.8/cli/interactive-search /docs/how-to-find-machines
/docs/snap/2.8/ui/how-to-upgrade-maas /docs/how-to-upgrade-maas
/docs/snap/2.8/ui/installation-tech-reference /docs/how-to-install-maas
/docs/snap/2.8/ui/interactive-search /docs/how-to-find-machines
/docs/snap/2.9/cli/how-to-work-with-tags /docs/how-to-tag-machiness
/docs/snap/2.9/ui/how-to-work-with-tags /docs/how-to-tag-machines
/docs/snap/3.0/cli/how-to-work-with-tags /docs/how-to-tag-machines
/docs/snap/3.0/ui/how-to-work-with-tags /docs/how-to-tag-machines
/docs/snap/3.1/cli/how-to-work-with-tags /docs/how-to-tag-machines
/docs/snap/3.1/ui/how-to-work-with-tags /docs/how-to-tag-machines
The links below are broken:
On page: https://maas.io/docs
  1. What is MAAS – and what does it really do for me?
  2. Can you show me an example data centre using MAAS?
Regards.
@jcbeppler, thanks. we just switched to new format and are still debugging, but those are very good catches. fixed now, lmk if you see other mistakes.
