Ubuntu kernels (snap/2.7/UI)
  4. Low latency kernels
This article explains each of these kernels, and offers instructions and further references regarding their use.
Seven questions you may have:
  1. What is a general availability kernel?
  2. What is a hardware enablement kernel?
  3. What is a pre-release hardware enablement kernel?
  4. What is a low latency kernel?
  5. How do I set a minimum kernel for enlistment and commissioning?
  6. How to I set a minimum deploy kernel for a machine?
  7. How do I set a specific kernel during machine deployment?
Low latency kernels
Using kernels
Set a default minimum kernel for enlistment and commissioning
To set the default minimum enlistment and commissioning kernel (based on Ubuntu release: GA kernel) for all machines visit the ‘General’ tab of the ‘Settings’ page and select a kernel in the ‘Default Minimum Kernel Version’ field of the Commissioning section. Don’t forget to click ‘Save’.
Set a minimum deploy kernel for a machine
To set the minimum deploy kernel on a machine basis, click on a machine from the ‘Machines’ page of the web UI and switch to its ‘Configuration’ page. Click ‘Edit’ in the ‘Machine configuration’ section, select a kernel in the ‘Minimum Kernel’ field followed by ‘Save changes’.
Set a specific kernel during machine deployment
To set a specific kernel during deployment, select a machine from the ‘Machines’ page and choose ‘Deploy’ under ‘Take action’. Then choose a kernel from the (third) kernel field. Hit ‘Deploy machine’ to initiate the deployment.
MAAS verifies that the specified kernel is available for the given Ubuntu release (series) before deploying the machine.
