Two questions you may have:
Apply a hardware test
A default test will be selected (smartctl-validate
, a hard drive test) but you can choose others by clicking the ‘Select scripts’ label. Doing so will reveal the following choices:
Scripts available for testing
The following hardware testing scripts can be selected from the web UI:
Name | Category Tags | Description |
smartctl-short | storage | Run the short SMART self-test and validate SMART health on all drives in parallel |
smartctl-long | storage | Run the long SMART self-test and validate SMART health on all drives in parallel |
smartctl-conveyance | storage | Run the conveyance SMART self-test and validate SMART health on all drives in parallel |
memtester | memory | Run memtester against all available userspace memory. |
internet-connectivity | network, internet, node | Check if the system has access to the internet. |
stress-ng-cpu-long | cpu | Run stress-ng memory tests for 12 hours. |
stress-ng-cpu-short | cpu | Run stress-ng memory tests for 5 minutes. |
stress-ng-memory-long | memory | Run stress-ng memory tests for 12 hours. |
stress-ng-memory-short | memory | Run stress-ng memory tests for 5 minutes. |
ntp | network, ntp, node | Run ntp clock set to verify NTP connectivity. |
badblocks | storage | Run badblocks on disk in read-only mode. |
badblocks-destructive | destructive, storage | Run badblocks on a disk in read/write destructive mode. |
7z | cpu | Run 7zip CPU benchmarking. |
fio | storage, destructive | Run Fio benchmarking against selected storage devices. |
After either commissioning, testing, or installation has started, MAAS reports in real-time which script is running.
You can access the verbatim output from any test by selecting a machine, selecting the ‘Hardware tests’ page and clicking on the ‘Log view’ link in the ‘Results’ column for the specific test.
