This page describes basic MAAS logging operations. For more details, refer to these reference pages:
Remote syslog (3.4 UI)
To enable remote logging, choose Settings > Network > Syslog, and enter your syslog server’s IP/URL under Remote syslog server to forward machine logs.
Remote syslog (3.3-- UI)
To enable remote logging, choose Settings > Network services > Syslog; add your syslog server’s IP/UL; and click Save.
Remote syslog (CLI)
# Example for setting syslog server to 192.168.100.11:
# To reset to default (sending syslog to MAAS region controllers):
Note: Only machine syslog information is forwarded, not MAAS controllers’ syslogs.
Direct log access
Logs can be found at the following paths depending on your installation type (snap or package):
Snap installation:
- /var/snap/maas/common/log/maas.log
- /var/snap/maas/common/log/regiond.log
- /var/snap/maas/common/log/rackd.log
- /var/snap/maas/common/log/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
Package installation:
- /var/log/maas/maas.log
- /var/log/maas/regiond.log
- /var/log/maas/rackd.log
- /var/log/maas/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
Logs can be extensive and challenging to search. The MAAS web UI does not categorise events by type.
Events query (CLI)
The most efficient way to review events is using the events query
CLI sub-command. This command allows filtering and summarising events. Use jq
and various filters to simplify output interpretation.
Basic queries
maas $PROFILE events query
This command returns a lengthy JSON output, which can be simplified using jq
and various filters, making it more readable.
Using jq with events
A jq
command example for readable output:
maas $PROFILE events query limit=20 | jq -r '(["USERNAME","NODE","HOSTNAME","LEVEL","DATE","TYPE","EVENT"] | (., map(length*"-"))), (.events[] | [.username,.node,.hostname,.level,.created,.type,.description]) | @tsv' | column -t -s$'\t'
Filter parameters
The events query
command supports multiple filters:
- hostname: Events for a specific node hostname.
- mac_address: Events for nodes with specified MAC addresses.
- id: Events for nodes with specific system IDs.
- zone: Events for nodes in a particular zone.
- level: Filter by event level (AUDIT, CRITICAL, DEBUG, ERROR, INFO, WARNING).
- limit: Maximum number of events to return.
- before/after: Start returning events before or after a specific event ID.
Example usage of these filters can narrow down event listings significantly.
Auditing finesse
Audit events, tagged with AUDIT
, record MAAS configuration changes and machine state transitions. They’re essential for tracking user actions and system updates, especially in multi-user environments.
Use audit events alongside jq
and command-line text tools to analyse actions like machine deletions, configuration changes, and user activities. This can provide insights into system changes and help identify areas for attention or improvement.
