Enabling MAAS (snap/2.7/UI)
Upgrade an existing MAAS
Preparing to install MAAS
MAAS host requirements
| | Memory (MB) | CPU (GHz) | Disk (GB) |
| Ubuntu Server (including logs)| 512 | 0.5 | 5 |
  • A region controller (including PostgreSQL) installed on one host, with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A duplicate region controller (including PostgreSQL) on a second host, also with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A rack controller installed on a third host, with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • A duplicate rack controller on a fourth host, also with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • the number of connecting clients (client activity)
  • how you decide to distribute services
  • whether or not you use high availability/load balancing.
  • the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
  • Disable bind9 - If bind9 is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the command ps aux | grep named.
  • Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
  • Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
  • OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
  • AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9 or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named to see if it’s running. The bind9 daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
Initialising MAAS
sudo maas init region+rack
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
MAAS URL
Shared secret
Reinitialising MAAS
Additional `init` options
sudo maas init --help
snap-ui-2-8 snap-cli-2-8 -->
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
