High availability
This page describes how to provide high availability (HA) for MAAS at both region and rack levels. In the context of MAAS, there are four types of HA: BMC (node power cycling); DHCP; PostgreSQL; and API services.
Enable highly-available BMC
Enable highly-available DHCP services?
Access the appropriate VLAN (via the ‘Subnets’ page) and choose action ‘Reconfigure DHCP’. There, you will see the second rack controller in the ‘Secondary controller’ field. All you should have to do is press the ‘Reconfigure DHCP’ button:
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /etc/maas/rackd.conf. For example:
maas_url:
  - http://<ip 1>:<port>/MAAS/
  - http://<ip 2>:<port>/MAAS/
  • PostgreSQL HA
  • Secondary API server(s)
MAAS stores all state information in the PostgreSQL database. It is therefore recommended to run it in HA mode. Configuring HA for PostgreSQL is external to MAAS. You will, therefore, need to study the PostgreSQL documentation (external link) and implement the variant of HA that makes you feel most comfortable.
Please see Region controllers and Multiple region endpoints for more information about how to install and configure rack controllers for multiple region controllers.
You can add load balancing with HAProxy (external link) load-balancing software to support multiple API servers. In this setup, HAProxy provides access to the MAAS web UI and API.
Install
sudo apt install haproxy
Configure
frontend maas
    bind    *:80
    retries 3
    option  redispatch
    option  http-server-close
    default_backend maas
backend maas
    timeout server 90s
    balance source
    hash-type consistent
Enable HA in a snap
Setting up high-availability using snaps is relatively easy. To use snaps instead of a package distribution of MAAS:
  1. Set up PostgreSQL for high-availability as explained above. PostgreSQL should run outside of the snap.
  2. Install the MAAS snap on each machine you intend to use as a rack or region controller. You’ll need the MAAS shared secret, located here, /var/snap/maas/common/maas/secret, on the first region controller you set up.
  3. Initialise the snap as a rack or region controller. Note that if you intend to use a machine as a region controller, you’ll need to tell MAAS how to access your PostgreSQL database host with the following arguments:
    • --database-host DATABASE_HOST
    • --database-name DATABASE_NAME
    • --database-user DATABASE_USER
    • --database-pass DATABASE_PASS
High availability (snap)
Concepts and terms (UI)
MAAS requirements
MAAS requirements (UI)
Introduction to controllers
About MAAS (UI Version)
MAAS installation from packages
MAAS communication
About MAAS (CLI)
Hardening your MAAS installation (UI)
High availability (UI)
Concepts and terms (CLI)
Configuring TLS encryption (CLI)
Hardening your MAAS installation (CLI)
High availability (CLI)
Introduction to controllers (CLI)
MAAS communication (CLI)
MAAS requirements (CLI)
Introduction to controllers (UI)
About MAAS
MAAS communication (UI)
Rack controllers (UI)
Region controllers (UI)
Enabling MAAS 2.8 (snap/CLI)
Hardening your MAAS installation (snap)
Hardening your MAAS installation (packages)
High availability (packages)
Enabling MAAS 2.8 (packages/CLI)
Concepts and terms (snap/2.7/CLI)
Concepts and terms (snap/2.7/UI)
Concepts and terms (snap/2.8/CLI)
Concepts and terms (deb/2.8/UI)
Concepts and terms (snap/2.8/UI)
Concepts and terms (snap/2.9/UI)
Concepts and terms (snap/2.9/CLI)
Concepts and terms (deb/2.7/CLI)
Concepts and terms (deb/2.7/UI)
Concepts and terms (deb/2.8/CLI)
Concepts and terms (deb/2.9/CLI)
Concepts and terms (deb/2.9/UI)
Enabling MAAS (snap/2.7/UI)
Enabling MAAS (snap/2.7/CLI)
Enabling MAAS (deb/2.7/UI)
Enabling MAAS (snap/2.8/CLI)
Enabling MAAS (snap/2.8/UI)
Enabling MAAS (deb/2.7/CLI)
Enabling MAAS (snap/2.9/CLI)
Enabling MAAS 2.7 (snap/CLI)
Enabling MAAS (deb/2.9/CLI)
Enabling MAAS (deb/2.8/CLI)
Enabling MAAS (deb/2.9/UI)
Enabling MAAS (deb/2.8/UI)
Enabling MAAS 2.7 (packages/CLI)
Enabling MAAS 2.8 (packages/UI)
Enabling MAAS 2.7 (packages/UI)
Enabling MAAS (snap/2.9/UI)
Rack controllers (CLI)
Enabling MAAS 2.7 (snap/UI)
Region controllers (CLI)
Enabling MAAS 2.8 (snap/UI)
About MAAS (UI)
Configuring TLS encryption (UI)
On the referenced document, on adding a secondary API server, it specifies:
The question is what happens in the event of failure of the primary MAAS region controller? should it point to the hot_standby database? a.k.a localhost ?
Thanks
a wonderful side effect to use a rack controller together a region one is also the (HA) DNS, in fact you can pass rack and region as a DNS pool to clients
you have to tell us more! :slight_smile:
sorry,
but dns HA is impossible until rackd works as a dns forwarder and not as a secondary dns server.
The former has the(terrible) side-effect to not resolve when the regiond is unavailable.
A good improvement could be to set the rackd as a secondary dns server, so if the regiond is unavailable, the rackd continues to resolve dns queries.
