A rack controller can connect to multiple VLANs, each from a different network interface. This configuration provides a scaling factor that can help as a network architecture grows in size.
- How does MAAS communication work?
- How do I install a rack controller?
- How do I configure MAAS for multiple API servers?
- How do I unregister a rack controller?
Install a rack controller
Installing a rack controller consists of installing the rack controller software and then registering the rack controller with the region API server. When MAAS installs a rack controller on the same host as the region API server, registration occurs automatically. Rack controllers can also be added and registered manually.
Once registered, this extra rack controller will appear immediately alongside the primary controller in the web UI and begin to sync with it:
You can also list and confirm all registered rack controllers via the CLI. Note that you will need multiple rack controllers to achieve specific high availability configurations.
Unregister a rack controller
To do so, navigate to the ‘Controllers’ page of the web UI. Enter the controller’s page by clicking on the machine you want to delete and select ‘Delete’ from the dropdown (and then ‘Delete controller’). MAAS will do the right thing if the controller is used for DHCP HA; that is, the DHCP HA needs to be disabled.
