As of MAAS 3.0 Beta1, this page has been deprecated and the content moved to the CLI sections of other, relevant MAAS documents. The contents may or may not diverge from the latest information over time.
This article is a list of advanced tasks you can perform with the MAAS CLI.
Thirteen questions you may have:
- How do I get started with the MAAS CLI?
How do I edit machine hostname and power parameters?
3.How do I relay DHCP? - How do I assign a network interface to a fabric?
- How do I change the IP assignment mode of a network interface?
- How do I install a rack controller?
- How do I list rack controllers?
- How do I set the default storage layout?
- How do I set a storage layout?
- How do I create an A or AAAA record in DNS?
- How do I create an alias (CNAME) record in DNS?
- How do I create a Mail Exchange pointer record in DNS?
- How do I add or update a remote syslog server?
Edit machine hostname and power parameters
To edit the hostname and power parameters of a machine:
maas $PROFILE machine update $SYSTEM_ID \
hostname=$HOSTNAME \
power_type=$POWER_TYPE \
power_parameters_power_address=$POWER_ADDRESS \
power_parameters_power_id=$HOSTNAME
For example, to configure a KVM-based machine:
power_type=virsh \
power_parameters_power_address=qemu+ssh://ubuntu@$KVM_HOST/system \
See Common CLI tasks for how to find a machine’s system id and BMC Power Types for details on different power types.
Relay DHCP
To relay DHCP traffic for a VLAN (source) through another VLAN (target):
See DHCP relay for more information.
sudo apt install jq
Example output:
Example output:
Example output:
Set the default storage layout
To set the default storage layout for all machines:
See Storage for more details on MAAS storage features.
Set a storage layout
maas $PROFILE dnsresources create fqdn=$HOSTNAME.$DOMAIN ip_addresses=$IPV4ADDRESS
maas $PROFILE dnsresources create fqdn=$HOSTNAME.$DOMAIN ip_addresses=$IPV6ADDRESS
maas $PROFILE dnsresource-records create fqdn=$HOSTNAME.$DOMAIN rrtype=cname rrdata=$ALIAS
Add or update a remote syslog server
For example:
