This article delves into these issues and offers guidance on how to set up and manage your DHCP configuration.
- What are reserved IP ranges?
- What is post-commission configuration
- How and why should I enable MAAS-managed DHCP?
- How do I resolve IP conflicts?
- How can I extend a reserved dynamic IP range?
- How and why should I configure external DHCP?
- How and why should I use a DHCP relay?
- How and why should I customize MAAS with DHCP snippets?
Enabling DHCP
MAAS-managed DHCP needs a reserved dynamic IP range enlist and commission machines. You should create such a range when you are enabling DHCP with the web UI. See MAAS CLI for instructions for doing this with the CLI.
- Under the ‘Take action’ button select ‘Provide DHCP’. A new window will appear.
- Select the primary rack controller. For DHCP HA, select both the primary and the secondary.
- Create a reserved, dynamic IP range. Fill in the fields ‘Dynamic range start IP’ and ‘Dynamic range end IP’.
- Apply your changes with the ‘Provide DHCP’ button.
Resolving IP conflicts
In some cases, MAAS manages a subnet that is not empty, which could result in MAAS assigning a duplicate IP address. For users of MAAS versions below 2.7, you need to tell MAAS about IP addresses that are already assigned on that subnet to avoid an IP conflict. MAAS version 2.7 is capable of detecting IPs in use on a subnet. Be aware that there are a couple of caveats:
If a previously-assigned NIC is in a quiescent state or turned off, MAAS may not detect it before duplicating an IP address.
At least one rack controller must have access to the IP-assigned machine in order for this feature to work.
MAAS 2.7 also recognizes when the subnet ARP cache is full, so that it can re-check the oldest IPs added to the cache to search for free IP addresses.
Extending a reserved dynamic IP range
External DHCP and a reserved IP range
DHCP relay
Ensure the target VLAN has DHCP enabled.
Set up the external relay. This relay is set up independently from MAAS. See DHCP relay for software suggestions.
Configure MAAS-managed DHCP. Navigate to the source VLAN page and select the ‘Relay DHCP’ action. Fill in the fields in the resulting form. The crucial setting is the target VLAN (‘Relay VLAN’). Press the ‘Relay DHCP’ button to finish. See MAAS CLI for how to do this with the CLI.
DHCP Snippets
See MAAS CLI for doing this with the CLI.
