MAAS logging (CLI)
MAAS has a robust logging capability, which presents several different views, including a number of node-specific log files, and several syslogd-style text logs. Each of these logs provides different information, or at the very least, different views of the same information. MAAS gathers logging information the various MAAS states and records both automated and user-driven actions.
The syslog logging path
Syslog data is kept in /var/log/maas/rsyslog/<machine-name><yyyy-mm-dd>/messages (/var/snap/maas/common/log/rsyslog/<machine-name><yyyy-mm-dd>/messages when using the snap). Every machine known to MAAS will have corresponding syslogs.
Using a remote syslog server
See MAAS CLI to learn how to add a remote syslog server using the CLI.
