Storage (CLI)
UEFI
Layouts
There are three layout types:
  • Flat layout
  • LVM layout
  • bcache layout
Flat layout
sda - disk
sda2 rest of sda part ext4 /
boot_size: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem.
root_device: The block device on which to place the root partition. The default is the boot disk.
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM layout
sda - disk
lvroot rest of sda lvm ext4 /
vgroot rest of sda lvm
vg_name: Name of the created volume group. Default is vgroot.
lv_name: Name of the created logical volume. Default is lvroot.
lv_size: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
bcache layout
sda - disk
sdb (ssd) - disk
bcache0 per sda2 disk ext4 /
root_device: The block device upon which to place the root partition. The default is the boot disk.
cache_device: The block device to use as the cache device. Default is the smallest block device tagged ssd.
cache_mode: The cache mode to which MAAS should set the created bcache device. The default is writethrough.
cache_size: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device.
cache_no_part: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the given cache_size. If set to true, no partition will be created, and the raw cache device will be used as the cache.
VMFS6 layout
Name Size Type Use
sda - disk
sda1 3 MB part EFI
sda2 4 GB part Basic Data
sda4 - skipped
sda5 249 MB part Basic Data
sda6 249 MB part Basic Data
sda8 285 MB part Basic Data
root_device: The block device upon which to place the root partition. Default is the boot disk.
root_size: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
Blank layout
Setting layouts
Default layout
See Disk erasure for an explanation of the options related to the erasing of disks.
To change the default with the CLI see MAAS CLI - advanced tasks.
Machine layout
An administrator can change the layout for a single machine as well as customise that layout providing this is done while the machine has a status of ‘Ready’. This is only possible via the CLI at this time (see MAAS CLI - advanced tasks).
Final storage modifications
Disk erasure
You can erase machine storage in several ways. See Disk erasure for details.
