CLI advanced tasks (snap/2.7/CLI)
This article is a list of advanced tasks you can perform with the MAAS CLI.
Edit machine hostname and power parameters
To edit the hostname and power parameters of a machine:
maas $PROFILE machine update $SYSTEM_ID \
    hostname=$HOSTNAME \
    power_type=$POWER_TYPE \
    power_parameters_power_address=$POWER_ADDRESS \
    power_parameters_power_id=$HOSTNAME
For example, to configure a KVM-based machine:
    power_type=virsh \
    power_parameters_power_address=qemu+ssh://ubuntu@$KVM_HOST/system \
See Common CLI tasks for how to find a machine’s system id and BMC Power Types for details on different power types.
Relay DHCP
To relay DHCP traffic for a VLAN (source) through another VLAN (target):
See DHCP relay for more information.
sudo apt install jq
Example output:
Example output:
Example output:
Change the IP assignment mode of a network interface
For instance, to have interface ‘58’, with subnet link ‘146’, on machine ‘exqn37’ use DHCP on subnet ‘192.168.1.0/24’:
For a summary of IP assignment modes see Post-commission configuration.
Install a rack controller
sudo maas-rack register
MAAS will ask for the URL of the region API server. If you provide a hostname, ensure it is resolvable. Next, MAAS will prompt you for the secret key, stored in file /var/lib/maas/secret on the API server.
You can get the above information from the web UI by visiting the ‘Controllers’ page and clicking the button ‘Add rack controller’. Here is an example of what you may see:
Based on the above, then, we could have also entered:
sudo maas-rack register --url http://10.5.1.5:5240/MAAS \
    --secret fa847000e7cb681101d26e3477e6e39e
See Rack controller for an overview.
List rack controllers
To list all rack controllers registered with the region:
Set the default storage layout
To set the default storage layout for all machines:
See Storage for more details on MAAS storage features.
Set a storage layout
Add or update a remote syslog server
For example:
