- How does UEFI booting work?
- What kind of storage layouts are available?
- How do I set storage layouts?
- What storage modifications can I make at the filesystem level?
- How can I erase a disk?
UEFI
Layouts
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
Flat layout
| Name | Size | Type | Filesystem | Mount point |
| sda | - | disk | ||
| sda1 | 512 MB | part | FAT32 | /boot/efi |
| sda2 | rest of sda | part | ext4 | / |
boot_size: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem.
root_device: The block device on which to place the root partition. The default is the boot disk.
root_size: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM layout
| sda | - | disk | ||
| sda2 | rest of sda | part | lvm-pv(vgroot) | |
| lvroot | rest of sda | lvm | ext4 | / |
| vgroot | rest of sda | lvm |
vg_name: Name of the created volume group. Default is vgroot.
lv_name: Name of the created logical volume. Default is lvroot.
lv_size: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
bcache layout
| sda | - | disk | ||
| sda2 | rest of sda | part | bc-backing | |
| sdb (ssd) | - | disk | ||
| sdb1 | 100% of sdb | part | bc-cache | |
| bcache0 | per sda2 | disk | ext4 | / |
root_device: The block device upon which to place the root partition. The default is the boot disk.
cache_device: The block device to use as the cache device. Default is the smallest block device tagged ssd.
cache_mode: The cache mode to which MAAS should set the created bcache device. The default is writethrough.
cache_size: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device.
cache_no_part: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the given cache_size. If set to true, no partition will be created, and the raw cache device will be used as the cache.
VMFS6 layout
| Name | Size | Type | Use |
| sda | - | disk | |
| sda1 | 3 MB | part | EFI |
| sda2 | 4 GB | part | Basic Data |
| sda3 | Remaining | part | VMFS Datastore 1 |
| sda4 | - | skipped | |
| sda5 | 249 MB | part | Basic Data |
| sda6 | 249 MB | part | Basic Data |
| sda7 | 109 MB | part | VMware Diagnostic |
| sda8 | 285 MB | part | Basic Data |
| sda9 | 2.5 GB | part | VMware Diagnostic |
root_device: The block device upon which to place the root partition. Default is the boot disk.
root_size: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
Blank layout
Setting layouts
Default layout
See Disk erasure for an explanation of the options related to the erasing of disks.
To change the default with the CLI see MAAS CLI - advanced tasks.
Machine layout
An administrator can change the layout for a single machine as well as customise that layout providing this is done while the machine has a status of ‘Ready’. This is only possible via the CLI at this time (see MAAS CLI - advanced tasks).
Final storage modifications
Disk erasure
You can erase machine storage in several ways. See Disk erasure for details.
