| Standard | UI-only | CLI-only |
MAAS is an open-source tool that lets you build a data centre from bare-metal servers. You can discover, commission, deploy, and dynamically reconfigure a large network of individual units. MAAS converts your hardware investment into a cohesive, flexible, distributed data centre, with a minimum of time and effort.
- What is MAAS?
- What does MAAS offer me?
- Can MAAS colocate key components to conserve resources?
- How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
MAAS integrates all the tools you need into a smooth system-management experience. It includes:
- web UI (optimised for mobile devices)
- Ubuntu, CentOS, Windows, and RHEL installation support
- open-source IP address management (IPAM)
- high availability (optional)
- IPv6 support
- inventory of components
- DHCP and DNS for other devices on the network
- DHCP relay integration
- VLAN and fabric support
- NTP for the entire infrastructure
- hardware testing
- composable hardware support
Colocation of key components
MAAS relies on two key components: the region controller and the rack controller. The region controller handles operator requests; the rack controller provides high-bandwidth services to multiple racks. In essence, rack controllers manage racks, while the region controller manages the data centre. See Concepts and terms for a deeper understanding of these components.
We generally recommended installing both controllers on the same system. The default MAAS install delivers this colocated configuration automatically. This all-in-one solution also provides DHCP.
In special cases, such as high availability or load balancing, you will want to install multiple region and rack controllers. You should also review your existing network design to determine whether MAAS-managed DHCP will cause problems.
How MAAS works
Note that Juju is designed to work with MAAS. MAAS becomes a backend Juju resource pool with all functionality fully available. For instance, if Juju removes a machine, then MAAS will release that machine to the pool. With Juju, MAAS can become an integral part of your data centre strategy and operations.
