High availability (snap)
This page describes how to provide high availability (HA) for MAAS at both region and rack levels. In the context of MAAS, there are four types of HA: BMC (node power cycling); DHCP; PostgreSQL; and API services.
Enable highly-available BMC
Enable highly-available DHCP services?
Access the appropriate VLAN (via the ‘Subnets’ page) and choose action ‘Reconfigure DHCP’. There, you will see the second rack controller in the ‘Secondary controller’ field. All you should have to do is press the ‘Reconfigure DHCP’ button:
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /etc/maas/rackd.conf. For example:
maas_url:
  - http://<ip 1>:<port>/MAAS/
  - http://<ip 2>:<port>/MAAS/
  • PostgreSQL HA
  • Secondary API server(s)
MAAS stores all state information in the PostgreSQL database. It is therefore recommended to run it in HA mode. Configuring HA for PostgreSQL is external to MAAS. You will, therefore, need to study the PostgreSQL documentation (external link) and implement the variant of HA that makes you feel most comfortable.
Please see Region controllers and Multiple region endpoints for more information about how to install and configure rack controllers for multiple region controllers.
You can add load balancing with HAProxy (external link) load-balancing software to support multiple API servers. In this setup, HAProxy provides access to the MAAS web UI and API.
Install
sudo apt install haproxy
Configure
frontend maas
    bind    *:80
    retries 3
    option  redispatch
    option  http-server-close
    default_backend maas
backend maas
    timeout server 90s
    balance source
    hash-type consistent
Enable HA in a snap
Setting up high-availability using snaps is relatively easy. To use snaps instead of a package distribution of MAAS:
  1. Set up PostgreSQL for high-availability as explained above. PostgreSQL should run outside of the snap.
  2. Install the MAAS snap on each machine you intend to use as a rack or region controller. You’ll need the MAAS shared secret, located here, /var/snap/maas/common/maas/secret, on the first region controller you set up.
  3. Initialise the snap as a rack or region controller. Note that if you intend to use a machine as a region controller, you’ll need to tell MAAS how to access your PostgreSQL database host with the following arguments:
    • --database-host DATABASE_HOST
    • --database-name DATABASE_NAME
    • --database-user DATABASE_USER
    • --database-pass DATABASE_PASS
