| Snap >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
| Packages >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
- How do I upgrade my existing MAAS?
- How do I install and configure MAAS?
- How do I add machines to MAAS?
- How do I deploy and manage machines with MAAS?
Upgrade an existing MAAS
- How do I prepare to install MAAS?
- How do I install MAAS?
- How do I initialize MAAS?
- How do I configure MAAS and get it running?
Preparing to install MAAS
- What are the requirements for a test environment?
- What are the requirements for a production environment?
- What setup steps should I complete before installation?
MAAS host requirements
| Memory (MB) | CPU (GHz) | Disk (GB) | |
| Ubuntu Server (including logs) | 512 | 0.5 | 5 |
- the number of connecting clients (client activity)
- how you decide to distribute services
- whether or not you use high availability/load balancing.
- the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
Disable bind9 - If
bind9is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the commandps aux | grep named. - Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
- Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
- OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
- AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9 or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named to see if it’s running. The bind9 daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
Initialising MAAS
sudo maas init region+rack
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
MAAS URL
region: Used to create a new region controller. -
rack: Used to locate the region controller.
Shared secret
Reinitialising MAAS
Additional `init` options
sudo maas init --help
snap-ui-2-8 snap-cli-2-8 →
This page covers the obsoleted use of deb/APT packages to install MAAS. With the advent of MAAS 2.7.0, installation via snap is the recommended method to acquire MAAS. Please note that using this method with versions 2.8 and above is not recommended.
You may want to consider an installation within LXD containers. These containers allow MAAS nodes to also run as local containers and are ideal for testing and experimenting with MAAS.
Packages
There are three packages to consider when installing MAAS:
maas-region-controller- region API server, database, DNS, HTTP proxy, and web UI -
maas-rack-controller- rack controller and DHCP -
maas- a metapackage that installs both the above packages to provide a complete MAAS environment
Each of the above packages has its dependencies. That is, each will bring in other MAAS packages not listed above. You can see the full list of MAAS packages with the command:
apt-cache search maas
As an example, running this command might produce output that looks like this:
The ‘maas’ metapackage is the recommended way to install MAAS. See the Introduction for more detail on colocating all services on a single host. Note that high availability with MAAS involves installing multiple region/rack controllers. See MAAS HA for more information on this topic.
Package repositories
While MAAS is available in the normal Ubuntu archives, the available packages may be lagging non-archive, but still stable, versions. For example, you can check the available versions of MAAS by typing:
apt-cache madison maas
which produces output similar to this:
You can install a newer stable version via PPAs listed on the MAAS launchpad, including:
For example, to add the 2.7 PPA, type:
sudo apt-add-repository -yu ppa:maas/2.7
which produces output similar to:
If you check available versions again, you will see that the new repository is now available:
Installation scenarios
The recommended way to set up an initial MAAS environment is to put everything on one machine:
sudo apt install maas
Executing this command leads you to a list of dependent packages to be installed, and a summary prompt that lets you choose whether to continue with the install:
Choosing “Y” proceeds with a standard apt package install.
Distributed environment
and the rack controller (see Rack controller for details) on another:
sudo maas-rack register
These two steps will lead you through two similar apt install sequences.
Creating a MAAS user
Finally, you will need to create a MAAS administrator user to access the web UI:
For example, the process might go like this:
The username can be anything. You will also be prompted to supply a password for the user. The command option --password=$PASSWORD can be used to specify one but, depending on your environment, this may pose a security risk.
At this time, MAAS does not make use of the email address. However, it may do so in the future.
Finally, the createadmin option asks for an SSH key:
If you have an SSH key associated with your launchpad or github accounts, you can enter the username here to include the key. For launchpad, just enter lp:username, and for github, enter gp:username at the prompt. In both cases, the actual username has to be supplied after the lp: or gh: prefix.
If you don't have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you've started MAAS for the first time as part of the welcome screens.
Once all this is done, you’re ready to access MAAS from the web UI and begin your Configuration journey.
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
