- How do I add an availability zone?
- How do I edit an existing availability zone?
- How do I delete an existing availability zone?
- How do I assign a machine to an availability zone?
- How do I allocate a machine in a particular zone?
Add a zone
To create a zone, navigate to the ‘AZs’ page of the web UI and use the ‘Add AZ’ button. Enter a name for the zone and click ‘Add AZ’.
Edit a zone
To edit a zone, on the ‘AZs’ page, select a zone and use the ‘Edit’ button. This selection allows you to change the name and description for the added (or edited) zone.
Delete a zone
To delete a zone, on the ‘AZs’ page, select a zone and use the ‘Delete AZ’ button. Doing so will also move any potential machine associations to the default zone.
Assign a machine to a zone
To assign a machine to a zone, from the ‘Machines’ page, select a machine (or multiple machines) and choose ‘Set zone’ using the ‘Take action’ button. After selecting a zone hit the ‘Set zone…’ button to apply the change.
You can also edit a machine’s ‘Configuration’ page to change its zone.
Both ways are available in the API as well: edit an individual machine through a PUT request to the machine’s URI, or set the zone on multiple machines at once by calling the set_zone
operation on the machines endpoint.
Allocate a machine in a zone
To deploy in a particular zone, call the acquire
method in the region-controller API <region-controller-api> as before, but pass the zone
parameter with the name of the zone. This method will allocate a machine in that zone, or fail with an HTTP 409 (“conflict”) error if the zone has no machines available that match your request.
Alternatively, you may want to request a machine that is not in a particular zone or one that is not in any of several zones. To do that, specify the not_in_zone
parameter to acquire
. This parameter takes a list of zone names; the allocated machine will not be in any of them. Again, if that leaves no machines available that match your request, the call will return a “conflict” error.
It is possible, though not usually useful, to combine the zone
and not_in_zone
parameters. If your choice for zone
is also present in not_in_zone
, no machine will ever match your request. Or if it’s not, then the not_in_zone
values will not affect the result of the call at all.
