Enabling MAAS 2.8 (packages/CLI)
|2.7|2.8
Snap |UICLI |UI CLI
Packages |UI/2.7 UI/2.8| CLI/2.7 CLI/2.8
Upgrade an existing MAAS
Preparing to install MAAS
MAAS host requirements
PostgreSQL 512 0.5 5
Rack controller 512 0.5 5
PostgreSQL 2048 2.0 20
Rack controller 2048 2.0 20
  • A region controller (including PostgreSQL) installed on one host, with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A duplicate region controller (including PostgreSQL) on a second host, also with 4.5 GB memory, 4.5 GHz CPU, and 45 GB of disk space.
  • A rack controller installed on a third host, with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • A duplicate rack controller on a fourth host, also with 2.5 GB memory, 2.5 GHz CPU, and 40 GB of disk space.
  • the number of connecting clients (client activity)
  • how you decide to distribute services
  • whether or not you use high availability/load balancing.
  • the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
  • Disable bind9 - If bind9 is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the command ps aux | grep named.
  • Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
  • Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
  • OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
  • AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9 or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named to see if it’s running. The bind9 daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
Initialising MAAS
sudo maas init region+rack
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
MAAS URL
Shared secret
Reinitialising MAAS
Additional `init` options
sudo maas init --help
snap-ui-2-8 snap-cli-2-8 →
Snap is the preferred method of installing MAAS. Fully-confined snap installs begin with version 2.7.0. For completeness, this page offers package installation instructions. There is also a more detailed page about installing from packages that may be useful for installing packages for versions 2.7 and below.
Install MAAS from packages
This section covers the obsoleted use of deb/APT packages to install MAAS. With the advent of MAAS 2.7.0, installation via snap is the recommended method to acquire MAAS. You may want to consider an installation within LXD containers. These containers allow MAAS nodes to also run as local containers and are ideal for testing and experimenting with MAAS.
You can install a newer stable version via PPAs listed on the MAAS launchpad, including:
For example, to add the 2.8 PPA, type:
sudo apt-add-repository -yu ppa:maas/2.8
There is also a “transitional” PPA:
This PPA contains the same transitional deb packages that are available in 20.04. It’s designed to help people running deb-based MAAS on 18.04 to migrate to the snap even before upgrading to 20.04.
Installation scenarios
The recommended way to set up an initial MAAS environment is to put everything on one machine:
sudo apt install maas
Executing this command leads you to a list of dependent packages to be installed, and a summary prompt that lets you choose whether to continue with the install:
Choosing “Y” proceeds with a standard apt package install.
Distributed environment
and the rack controller (see Rack controller for details) on another:
sudo maas-rack register
These two steps will lead you through two similar apt install sequences.
Creating a MAAS user
Finally, you will need to create a MAAS administrator user to access the web UI:
For example, the process might go like this:
apt-create-admin-sequence
The username can be anything. You will also be prompted to supply a password for the user. The command option --password=$PASSWORD can be used to specify one but, depending on your environment, this may pose a security risk.
At this time, MAAS does not make use of the email address. However, it may do so in the future.
Finally, the createadmin option asks for an SSH key:
create-admin-ssh-key-prompt
If you have an SSH key associated with your launchpad or github accounts, you can enter the username here to include the key. For launchpad, just enter lp:username, and for github, enter gp:username at the prompt. In both cases, the actual username has to be supplied after the lp: or gh: prefix.
If you don't have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you've started MAAS for the first time as part of the welcome screens.
Once all this is done, you’re ready to access MAAS from the web UI and begin your Configuration journey.
Next steps
Once you have installed your MAAS environment (region + rack controller) and any possible extra rack controllers(s), you are ready to begin your Configuration journey.
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
