Snap >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
Packages >>> | UI/2.7 | UI/2.8 | CLI/2.7 | CLI/2.8 |
- How do I upgrade my existing MAAS?
- How do I install and configure MAAS?
- How do I add machines to MAAS?
- How do I deploy and manage machines with MAAS?
Upgrade an existing MAAS
- How do I prepare to install MAAS?
- How do I install MAAS?
- How do I initialize MAAS?
- How do I configure MAAS and get it running?
Preparing to install MAAS
- What are the requirements for a test environment?
- What are the requirements for a production environment?
- What setup steps should I complete before installation?
MAAS host requirements
Memory (MB) | CPU (GHz) | Disk (GB) | |
Region controller (minus PostgreSQL) | 512 | 0.5 | 5 |
PostgreSQL | 512 | 0.5 | 5 |
Rack controller | 512 | 0.5 | 5 |
Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Region controller (minus PostgreSQL) | 2048 | 2.0 | 5 |
PostgreSQL | 2048 | 2.0 | 20 |
Rack controller | 2048 | 2.0 | 20 |
- the number of connecting clients (client activity)
- how you decide to distribute services
- whether or not you use high availability/load balancing.
- the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
Setting up for MAAS
Disable bind9 - If
bind9
is running on the system where you’re going to host MAAS, you need to disable it. The bind9 daemon interferes with MAAS, producing some unusual and hard-to-debug errors. You can see if it’s running with the commandps aux | grep named
. - Set your machines to netboot - MAAS uses PXE to remotely boot your machines via their NICs, so you’ll need to have your machines set to netboot, or MAAS can’t access and use them.
- Turn on machines that should auto-enlist - If you want MAAS to find and enlist your machines automatically, you need to turn them on.
- OR gather the UUIDs and MAC addresses for your machines - If you’re going to manually enroll machines, you’ll need this information.
- AND determine the power type - If you’re manually enrolling machines, you’ll also want to be able to tell MAAS how power them up. Follow the link to learn more about power types.
If you have installed bind9
or have it running, you will need to uninstall it before installing MAAS. You can check with ps aux | grep named
to see if it’s running. The bind9
daemon interferes with MAAS operation and creates a number of unusual, hard-to-debug errors – but don’t worry, MAAS provides DNS and can work with existing DNS servers.
Installing MAAS
Initialising MAAS
The following demonstrates the region+rack
mode, a popular initialisation choice for MAAS:
sudo maas init region+rack
maas
will ask for the MAAS URL:
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
MAAS URL
All run modes (except none
) prompt for a MAAS URL, interpreted differently depending on the mode:
region
: Used to create a new region controller. -
rack
: Used to locate the region controller.
Shared secret
Reinitialising MAAS
It is also possible to re-initialise MAAS to switch modes. For example, to switch from rack
to region
Additional `init` options
The init
command can takes optional arguments. To list them, as well as read a brief description of each, you can enter:
sudo maas init --help
snap-ui-2-8 snap-cli-2-8 -->
sudo snap install maas --channel=2.7
After entering your password, the snap will download and install from the 2.7.0 channel. However, MAAS needs initialising before it’s ready to go.
Initialisation
The next step involves initialising MAAS with a run mode. Selecting one of the following modes dictates what services will run on the local system:
Mode | Region | Rack | Database | Description |
all * |
X | X | X | All services (see warning below) |
region |
X | Region API server only | ||
rack |
X | Rack controller only | ||
region+rack |
X | X | Region API server and rack controller | |
none |
Deinitializes MAAS and stops services |
all mode being deprecated: Configuring the MAAS snap in “all” mode will be deprecated in MAAS version 2.8.0 and removed in MAAS version 2.9.0.
To initialise MAAS and select a run mode, use the maas init
command with the –mode argument.
Example
The following demonstrates the all
sudo maas init --mode all
A dialog will appear that will gather some basic information:
Username: admin
Password: ******
Again: ******
You will use the username and password to access the web UI. If you enter a Launchpad or GitHub account name with associated SSH key, MAAS will import them automatically.
MAAS URL
all
,region+rack
: Used to create a new region controller as well as to tell the rack controller how to find the region connntroller. -
region
rack
Shared secret
Reinitialising MAAS
To re-initialise MAAS, for example, to switch from rack
to region
sudo maas init --mode region
The init
command can take a number of optional arguments. To list them all as well as read a brief description of each:
Configuration verification
After a snap installation of MAAS, you can verifiy the currently-running configuration with:
sudo maas config
Sample output (for mode ‘all’):
Mode: all
Settings:
maas_url=http://192.168.122.1:5240/MAAS
Service statuses
sudo maas status
bind9 RUNNING pid 7999, uptime 0:09:17
dhcpd STOPPED Not started
dhcpd6 STOPPED Not started
ntp RUNNING pid 8598, uptime 0:05:42
postgresql RUNNING pid 8001, uptime 0:09:17
proxy STOPPED Not started
rackd RUNNING pid 8000, uptime 0:09:17
regiond:regiond-0 RUNNING pid 8003, uptime 0:09:17
regiond:regiond-1 RUNNING pid 8008, uptime 0:09:17
regiond:regiond-2 RUNNING pid 8005, uptime 0:09:17
regiond:regiond-3 RUNNING pid 8015, uptime 0:09:17
tgt RUNNING pid 8040, uptime 0:09:15
Logging in to MAAS
Adding admin SSH keys to MAAS
Setting up MAAS networking
Adding physical machines
Adding virtual machines
Commissioning machines
Acquiring machines
Deploying machines
Releasing deployed machines
Marking machines as broken
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
