This page presents a list of common tasks that you can perform via the MAAS CLI. See MAAS CLI for instructions to help get you started with the CLI.
- How can I list nodes?
- How can I determine a node system ID?
- How can I commission a node?
- How can I acquire a node?
- How can I deploy a node?
- How can I configure the deployment timeout?
- How can I control subnet management?
- How can I create a reserved IP range?
- How can I determine a fabric ID?
- How can I enable DHCP?
- How can I set a DNS forwarder?
- How can I configure proxying?
- How can I set a default gateway?
- How can I set a DNS server?
- How can I set a zone description?
- How can I add a public SSH key?
- How can I determine a node hostname?
- How can I create a regular user?
List nodes
To list all nodes (and their characteristics) in the MAAS:
maas $PROFILE nodes read
You can also specify various parameters to narrow your search. In the following example, MAAS will return any machines containing ‘node2’ in the hostname parameter.
maas $PROFILE machines read hostname=node2
To see a list of all available search parameters:
maas $PROFILE machines read --help
Determine a node system ID
You can uses jq to determine a node’s system ID. For example, here’s how to output just the hostname and system_id when searching for a particular hostname:
jq is a command-line JSON processor.
The output looks like this:
"node2"
"e8xa8m"
Commission a node
To commission a node:
To commission a node, it must have a status of ‘New’.
To commission all nodes in the ‘New’ state:
maas $PROFILE machines accept-all
See Commission nodes.
Acquire a node
To acquire/allocate a random node:
To acquire/allocate a specific node:
Deploy a node
To deploy a node:
To deploy with the CLI, the node must have a status of ‘Allocated’. See ‘Acquire a node’ above (or use the web UI).
See Deploy nodes.
Configure deployment timeout
By default, when you deploy a node, MAAS will consider the deployment a failure if it doesn’t complete within 30 minutes. However, this timeout is configurable:
Control subnet management
For example, to disable:
You can use the subnet’s ID in place of the CIDR address.
See Subnet management.
Create a reserved IP range
Determine a fabric ID
Enable DHCP
You will also need to set a default gateway (see below).
See DHCP for more on this subject.
Set a DNS forwarder
To set a DNS forwarder:
Configure proxying
Enabling and disabling proxying, in general, is done via a boolean option (‘true’ or ‘false’). The following command will disable proxying completely:
maas $PROFILE maas set-config name=enable_http_proxy value=false
To set an external proxy, ensure proxying is enabled (see above) and then define it:
maas $PROFILE maas set-config name=http_proxy value=$EXTERNAL_PROXY
For example,
maas $PROFILE maas set-config name=enable_http_proxy value=true
maas $PROFILE maas set-config name=http_proxy value=http://squid.example.com:3128/
Enabling and disabling proxying per subnet is done via a boolean option (‘true’ or ‘false’). Here is how you can disable proxying on a per-subnet basis:
maas $PROFILE subnet update $SUBNET_CIDR allow_proxy=false
For example,
maas $PROFILE subnet update 192.168.0.0/22 allow_proxy=false
See Proxy for detailed information on how proxying works with MAAS.
Set a default gateway
Set a DNS server
maas $PROFILE subnet update $SUBNET_CIDR dns_servers=$MY_NAMESERVER
Set a zone description
To set a description for a physical zone:
maas $PROFILE zone update default \
description="This zone was configured by a script."
See Zones for more information on this topic.
Add a public SSH key
To add a public SSH key to a MAAS user account:
See SSH keys.
Determine a node hostname
To determine a node’s hostname based on it’s MAC address:
HOSTNAME=$(maas $PROFILE nodes read mac_address=$MAC \
| grep hostname | cut -d '"' -f 4)
Create a regular user
To create a regular user:
maas $PROFILE users create username=$USERNAME \
email=$EMAIL_ADDRESS password=$PASSWORD is_superuser=0
All the options are necessary. Note that stipulating a password on the CLI may be a security hazard, depending on your environment. If unsure, use the web UI. See User Accounts for the latter.
