Common CLI tasks (deb/2.7/CLI)
This page presents a list of common tasks that you can perform via the MAAS CLI. See MAAS CLI for instructions to help get you started with the CLI.
List nodes
To list all nodes (and their characteristics) in the MAAS:
maas $PROFILE nodes read
You can also specify various parameters to narrow your search. In the following example, MAAS will return any machines containing ‘node2’ in the hostname parameter.
maas $PROFILE machines read hostname=node2
To see a list of all available search parameters:
maas $PROFILE machines read --help
Determine a node system ID
You can uses jq to determine a node’s system ID. For example, here’s how to output just the hostname and system_id when searching for a particular hostname:
jq is a command-line JSON processor.
The output looks like this:
"node2"
"e8xa8m"
Commission a node
To commission a node:
To commission a node, it must have a status of ‘New’.
To commission all nodes in the ‘New’ state:
maas $PROFILE machines accept-all
See Commission nodes.
Acquire a node
To acquire/allocate a random node:
To acquire/allocate a specific node:
Deploy a node
To deploy a node:
To deploy with the CLI, the node must have a status of ‘Allocated’. See ‘Acquire a node’ above (or use the web UI).
See Deploy nodes.
Configure deployment timeout
By default, when you deploy a node, MAAS will consider the deployment a failure if it doesn’t complete within 30 minutes. However, this timeout is configurable:
Control subnet management
For example, to disable:
You can use the subnet’s ID in place of the CIDR address.
See Subnet management.
Create a reserved IP range
Determine a fabric ID
Enable DHCP
You will also need to set a default gateway (see below).
See DHCP for more on this subject.
Set a DNS forwarder
To set a DNS forwarder:
Configure proxying
Enabling and disabling proxying, in general, is done via a boolean option (‘true’ or ‘false’). The following command will disable proxying completely:
maas $PROFILE maas set-config name=enable_http_proxy value=false
To set an external proxy, ensure proxying is enabled (see above) and then define it:
maas $PROFILE maas set-config name=http_proxy value=$EXTERNAL_PROXY
For example,
maas $PROFILE maas set-config name=enable_http_proxy value=true
maas $PROFILE maas set-config name=http_proxy value=http://squid.example.com:3128/
Enabling and disabling proxying per subnet is done via a boolean option (‘true’ or ‘false’). Here is how you can disable proxying on a per-subnet basis:
maas $PROFILE subnet update $SUBNET_CIDR allow_proxy=false
For example,
maas $PROFILE subnet update 192.168.0.0/22 allow_proxy=false
See Proxy for detailed information on how proxying works with MAAS.
Set a default gateway
Set a DNS server
maas $PROFILE subnet update $SUBNET_CIDR dns_servers=$MY_NAMESERVER
Set a zone description
To set a description for a physical zone:
maas $PROFILE zone update default \
    description="This zone was configured by a script."
See Zones for more information on this topic.
Add a public SSH key
To add a public SSH key to a MAAS user account:
See SSH keys.
Determine a node hostname
To determine a node’s hostname based on it’s MAC address:
HOSTNAME=$(maas $PROFILE nodes read mac_address=$MAC \
    | grep hostname | cut -d '"' -f 4)
Create a regular user
To create a regular user:
maas $PROFILE users create username=$USERNAME \
    email=$EMAIL_ADDRESS password=$PASSWORD is_superuser=0
All the options are necessary. Note that stipulating a password on the CLI may be a security hazard, depending on your environment. If unsure, use the web UI. See User Accounts for the latter.
