Installation and configuration checklist (CLI)
This is a guide that you can use to achieve a working MAAS environment. Once you perform a step come back here (using the menu in the left pane) to continue on to the next one.
Software installation
Access the web UI
Zones
Networking
Import boot images
Access the MAAS CLI
Enable DHCP
Users and SSH keys
Add a machine
Edit power type
Commission a machine
Deploy a machine
SSH to the machine
