As a MAAS administrator, you have the important responsibilty of hardening your installation to help repudiate attacks and malicious actors. While there are too many variables to make meaningful suggestions for your deployed machines, there are a number of steps you can take to improve the overall security of your MASS setup. This article provides a few suggestions.
- How do I setup a firewall for MAAS?
- How do I configure a TLS-terminating load balancer (and what’s the impact on my MAAS setup?)
- How do I use logs to identify security issues?
- How do I implement PostgreSQL security?
- What else can I do to harden MAAS?
- Whom do I contact for MAAS security consulting?
Use a firewall
Port(s) | Description |
5240 |
HTTP communication with each region controller. Note that port 80 is typically used in high-availability environments.
5241 - 5247
Reserved for internal MAAS services. |
5248 |
Reserved for rack HTTP communication. |
5250 - 5270
Reserved for region workers (RPC). |
Consider setting your firewall (external link) on your rack and region controllers to disallow communication on all ports except those used by MAAS. For example, assuming you have installed ufw
, you could execute:
sudo ufw enable
sudo ufw allow 5240
sudo ufw allow 5248
sudo ufw allow 5241:5247/tcp
sudo ufw allow 5241:5247/udp
sudo ufw allow 5250:5270/tcp
sudo ufw allow 5250:5270/udp
Recognize that your particular configuration and version may vary, so consult the appropriate firewall manual pages for your specific MAAS host system.
One of the best steps you can take to improve both security and availability of your MAAS installation is to install TLS-terminating load balancer. For MAAS, we recommend using HAProxy (external link). This section explains how to set one up.
In the context of MAAS, a load balancer (external link) distributes the incoming Web UI and API requests across multiple region controllers. This reduces both load on MAAS and wait times for user requests. Typically, this is known as a high-availability (HA) configuration, although there are two other HA configurations that can be enabled for MAAS: one for BMC access (for powering on machines), and one for DHCP, which enables primary and secondary DHCP instances that manage the same VLAN.
TLS is meant to provide privacy and data integrity between two or more applications. Privacy is provided by symmetric cryptography (external link), based on a shared secret and uniquely-generated keys negotiated at the start of a session (during the TLS handshake (external link)). Identity of each app can be authenticated, though this feature can be optional. Authenticity of messages is ensured by using message authentication codes (external link) to detect tampering.
PEM file
As a first step, you’ll need an SSL certificate (mysite.com.crt
) with a key pair (mysite.com.key
), combined into a PEM file:
sudo apt-get update
sudo apt-get install haproxy
Next, edit /etc/haproxy/haproxy.cfg
as follows. In the global
section of the file, add this line:
Next, in the defaults
section, add the following lines under mode http
option forwardfor
option http-server-close
The option forwardfor
tells HAProxy to add X-Forward-For headers to each request. The http-server-close
option reduces latency between HAProxy and your users by closing connections but maintaining a keep-alive.
frontend maas
retries 3
option redispatch
default_backend maas
This stanza defines a frontend name maas
; tells HAProxy to handle incoming traffic to port 443, providing SSL encryption, enabled by the certificates and keys you earlier concatenated into your PEM file; allows three retries and redispatch; and forwards these requests to maas
as the backend server, which is defined something like this:
backend maas
timeout server 90s
balance source
hash-type consistent
This stanza defines a backend server group named maas
; sets consistent hashing, 90 second timeout, and balanced sources; sets the server address and port (localhost:5240
); and engages two region controllers, named maas-api-1
and maas-api-2
. Note that the “1” and “2” designations are completely arbitrary, as there is no sense of “primary” or “secondary” associated with this configuration.
Note that you can also enable HAProxy logging (external link) if desired. This logging is an optional feature of the HAProxy tool and is thus left to your discretion.
- firewall logs
- Web server logs
- MAAS log files
- system log files
This section will offer some advice, as well as links to more detailed infromation on these categories.
Firewall logs
The Ubuntu firewall, UFW (external link), is a front-end for iptables (external link), so the UFW log output is very similar to what you’ll encounter in iptables itself. If you want to secure your MAAS installation, it’s very important to periodically review your UFW logs, found in /var/log/ufw*
Learning to recognize issues in the UFW/iptables log is an art form, so we’re not going to give an extended tutorial here. Still, there are some key indicators that might help you spot security issues.
You can also compare attempts on unusual port numbers against well-known hacker tools (external link). For instance, repeated attempts against port 12361 might mean that someone is attempting to attack with the Whack-a-mole exploit.
Also suspicious are repeated, unsuccessful access attempts, against the same port or service, from the same domain, IP address, or subnet. These attempts may be spread out in time (grep
is your friend, here). For example, a group of login attempts that look like this may indicate that an attacker is trying to disguise port scans by switching IP addresses within a block of addresses available to them:
Review the IP addresses that are being rejected and dropped. Try to identify them with a ping -a <IP address>
. Spoofed addresses won’t have an owner (and you can block them). Real addresses have a whois (external link) entry, so it’s possible you can contact the ISP to report and resolve this issue.
There are many other firewall log analysis techniques, and a number of good open-source and commercial log analysis programs. If you decide to analyze directly, though, you’re basically looking for blocked connection issues, connections to (potentially) open ports you’re not using, and suspicious-looking outbound connections.
Web server logs
Detecting malicious activity directed toward your Web server is best done with a log analysis tool. If you want to review the raw logs directly, you can look for them in:
/var/log/httpd/
,/var/log/apache
, or/var/log/apache2
(in the case of Apache), or -
the path given in
/etc/nginx/nginx.conf
or given in your site configuration file, which itself is found at the path/etc/nginx/sites-available
(in the case of nginx – look for theaccess_log
directive).
multiple requests in less than one second, or some other appropriate timeframe.
multiple secure/login page accesses in a one-minute window, especially when they fail.
attempts to access non-existent pages using different paths or query parameters (e.g.,
135.25.48.19:5250/maas/index.html
look out for SQL injection attacks, for example:
3.5.30729)” -
attempts to run a Web shell, for instance:
MAAS log files
Presently, your primary use of MAAS log files to improve security is to periodically check log files for login failures. You can check for this activity in the regiond.log
file. For reference, a valid login request looks like this entry:
Safari/537.36)````
Safari/537.36)````
System log files
You can also use the standard system logs to detect malicious activity, though this subject is largely beyond the scope of this document. As a simple example, consider using journalctl
to detect and source an SSH brute force attack:
From here, you can either use whois
to locate the attacker and work with the ISP to block them, or simply use your UFW firewall to block them directly.
As mentioned, this subject is far too complex for a detailed tutorial in this section. For more information, try the Ubuntu journalctl manpage (external link) or another, similar source (external link).
Implement PostgreSQL security
PostgreSQL contains secrets, and should be encrypted for maximum protection. You should consider full disk encryption (external link). Also recommended is TLS encryption between MAAS and PostgreSQL (external link).
Good passwords
You should pick good passwords and store them securely (e.g. in a KeePassX password database). Perform user administration only via the web UI. Only share the maas
and root
user passwords with administrators.
File permissions
MAAS configuration files should be set to have permission 640
: readable by logins belonging to the maas
group and writeable only by the root
user. Currently, the regiond.conf
file contains the login credentials for the PostgreSQL database used by MAAS to keep track of all machines, networks, and configuration.
After:
-rw-r----- 1 root maas 90 Sep 27 14:13 rackd.conf
-rw-r----- 1 root maas 157 Sep 27 14:14 regiond.conf
Shared secrets
About snap security
Since snaps are fully confined or “sandboxed,” they bring a lot of inherent security to the contained application. More detailed information can be found in this snap blog (external link).
If you need help implementing MAAS security, please contact us (external link). We will be happy to assist you in arranging security consulting appropriate to your needs.
