The following variables are used on this page:
- PRIMARY_PG_IP: The IP address of the host that contains the primary database.
- SECONDARY_PG_IP: The IP address of the host that contains the secondary database.
- REP_USER: The internal database user that manages replication on the primary.
- REP_USER_PW: The password of the replication user.
- REP_ARCHIVE: The directory where the database will place files to be replicated.
Primary
Create internal database user
sudo mkdir -p $REP_ARCHIVE
host replication $REP_USER $SECONDARY_PG_IP/32 md5
Configure for replication
listen_addresses = '*'
wal_level = hot_standby
archive_mode = on
max_wal_senders = 3
Restart the database
Secondary
- CPU architecture
- OS type and version
- PostgreSQL version
sudo apt install postgresql
Password:
hot_standby = on
Configure for recovery
standby_mode = on
Start the database
Start the database:
Verification of replication
hostname | status | power_state
pmatulis-imp-maas | 0 | unknown
node3 | 4 | off
node1 | 6 | on
node2 | 4 | off
node4 | 6 | on
(5 rows)
