- How do machines communicate with the rack controller?
- How do rack and region controllers communicate?
- What are rack controller port requirements?
The rack controller installs and configures bind
as a forwarder. All machines communicate via the rack controller directly.
- An operator makes a request of MAAS, either via the Web UI or the API.
- MAAS translates this to an API request to the region controller.
- The region controller locates the rack controller that has BMC access to the machine in question, that is, the rack controller that can power on that machine.
- That same rack controller powers on the machine via IPMI request.
- The rack controller tasked with providing DHCP handles assigning an IP address to the machine via the DORA sequence (Discover, Offer, Request, Acknowledge). Note that this rack controller doesnt have to be the same one that powers on the machine.
- The DHCP-managing rack controller inserts itself as the DHCP “next-server” and requests a network boot.
- (Still) the same rack controller RPCs the region controller to get what’s needed to boot an ephemeral Ubuntu kernel, namely the kernel, any kernel parameters, an initrd daemon, and a squashfs load.
- That same rack controller transforms the RPC response from the region controller into a valid PXE config and tells the machine to come get its files.
- The booting machine loads the kernel and initrd, boots with that initrd, and then loads the squashfs, eventually making its way up to an ephemeral Ubuntu instance.
- The booted machine pulls cloud-init metadata from the region controller, proxying through the rackd.
- cloud-init uses this metadata to gather resource information about the machine and pass it back to the region controller, again proxied by the rackd.
- The region controller (regiond or “region daemon”) stores this machine information in a postgres database that is accessible only to the regiond, making MAAS truly stateless with respect to machines.
The next-server
directive is used to specify the host address from which an initial boot file is to be loaded, usually a TFTP server. In the case of MAAS, the rack controller providing DHCP actually inserts itself, since it can proxy (broker) the delivery of boot bits to the machine in question.
