VM host networking (deb/2.7/UI)
Four questions you may have:
  1. How do I set up a VM host bridge with the web UI?
  2. How do I set up a VM host bridge with netplan?
  3. How do I set up a VM host bridge with libvirt?
  4. How do I set up SSH for use by libvirt?
Set up VM host bridge with MAAS UI
Select the machine you want to use as a VM host, switch to the “Network” tab. Select the network where you want to create the bridge and click “Create bridge:”
Then you can deploy Ubuntu.
network:
    bridges:
        br0:
            addresses:
            - 10.0.0.101/24
            gateway4: 10.0.0.1
            interfaces:
            - enp1s0
            macaddress: 52:54:00:39:9d:f9
            mtu: 1500
            nameservers:
                addresses:
                - 10.0.0.2
                search:
                - maas
            parameters:
                forward-delay: 15
                stp: false
    ethernets:
        enp1s0:
            match:
            mtu: 1500
            set-name: enp1s0
        enp2s0:
            match:
                macaddress: 52:54:00:df:87:ac
            mtu: 1500
            set-name: enp2s0
        enp3s0:
            match:
                macaddress: 52:54:00:a7:ac:46
            mtu: 1500
            set-name: enp3s0
    version: 2
  1. Disable DHCP on libvirt’s default network, or
  2. Create a new libvirt network maas with DHCP disabled.
cat << EOF > maas.xml
<network>
 <name>maas</name>
 <forward mode='nat'>
   <nat>
   </nat>
 </forward>
 <dns enable="no" />
 <domain name='testnet'/>
 </ip>
</network>
EOF
virsh net-define maas.xml
Set up SSH
Set up SSH (libvirt only)
$ sudo -i
