Rack controllers (snap/2.8/CLI)
Seven questions you may have:
  1. How does MAAS communication work?
  2. How do I install a rack controller?
  3. How do I list rack controllers?
  4. How do I configure MAAS for multiple API servers?
  5. How do I unregister a rack controller?
  6. How do I move a rack controller from one MAAS instance to another?
  7. What are the potential dangers of moving a rack controller?
Install a rack controller
sudo snap install maas
sudo maas init rack --maas-url $MAAS_URL --secret $SECRET
The $SECRET is stored in file /var/lib/maas/secret on the API server.
List rack controllers
You can also list and confirm all registered rack controllers:
Note that you will need multiple rack controllers to achieve specific high availability configurations.
Unregister a rack controller
  • Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behavior. It is not a supported configuration.
