This page describes how to provide high availability (HA) for MAAS at both region and rack levels. In the context of MAAS, there are four types of HA:
- BMC (node power cycling)
- DHCP
- PostgreSQL
- API services
Nine questions you might have:
- How do I make rack controllers highly available?
- How do I enable highly-available BMC?
- How do I enable highly-available DHCP services?
- How do I make region controllers highly available?
- How do I enable highly-available PostgreSQL?
- How do I enable highly-available API services?
- How do I enable load balancing for API services?
- How do I move a rack controller from one MAAS instance to another?
- What are the potential dangers of moving a rack controller?
Enable highly-available BMC
Enable highly-available DHCP services
To reconfigure DHCP after adding a new rack controller, use the following sequence of commands:
vid=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.vid')
fabric_name=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.fabric')
query=".[] | select(.name == \"$fabric_name\") | .id"
fabric_id=$(maas maas fabrics read | jq "$query")
maas maas ipranges create type=reserved start_ip=10.0.0.3 end_ip=10.0.0.49
maas maas ipranges create type=dynamic start_ip=10.0.0.50 end_ip=10.0.0.99
maas maas vlan update ${fabric_id} ${vid} primary_rack=$(hostname) dhcp_on=true
Be sure to substitute the sample values for those of your own environment.
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /etc/maas/rackd.conf
. For example:
maas_url:
- http://<ip 1>:<port>/MAAS/
- http://<ip 2>:<port>/MAAS/
- PostgreSQL HA
- Secondary API server(s)
MAAS stores all state information in the PostgreSQL database. It is therefore recommended to run it in HA mode. Configuring HA for PostgreSQL is external to MAAS. You will, therefore, need to study the PostgreSQL documentation and implement the variant of HA that makes you feel most comfortable.
Each region controller uses up to 40 connections to PostgreSQL in high load situations. Running two region controllers requires no modifications to the max_connections
in postgresql.conf
. More than two region controllers require that max_connections
be adjusted to add 40 more connections per added region controller.
Please see Region controllers and Multiple region endpoints for more information about how to install and configure rack controllers for multiple region controllers.
You can add load balancing with HAProxy load-balancing software to support multiple API servers. In this setup, HAProxy provides access to the MAAS web UI and API.
If you happen to have Apache running on the same server where you intend to install HAProxy, you will need to stop and disable apache2
, because HAProxy binds to port 80.
Install
sudo apt install haproxy
Configure
Configure each API server’s load balancer by copying the following into /etc/haproxy/haproxy.cfg
(see the upstream configuration manual (external link) as a reference). Replace $PRIMARY_API_SERVER_IP and $SECONDARY_API_SERVER_IP with their respective IP addresses:
frontend maas
bind *:80
retries 3
option redispatch
option http-server-close
default_backend maas
backend maas
timeout server 90s
balance source
hash-type consistent
where maas-api-1
and maas-api-2
are arbitrary server labels.
where $PROFILE
is your admin profile name, and $SYSTEM_ID
can be found by examining the output of the command:
maas $PROFILE rack-controllers read
where the secret is found in /var/lib/maas/secret
Using the same system as a rack controller and a VM host: While not forbidden or inherently dangerous, using the same machine as both a rack controller and a VM host may cause resource contention and poor performance. If the resources on the system are not more than adequate to cover both tasks, you may see slowdowns (or even apparent “freeze” events) on the system.
Moving a rack controller from one version of MAAS to another: MAAS rack controller software is an integral part of each version of MAAS. If you delete a rack controller from, say, a 2.6 version of MAAS, and attempt to register that 2.6 version of the rack controller code to, say, a 2.9 version of MAAS, you may experience errors and potential data loss. Using the above example, if you are running both a VM host and a rack controller for MAAS 2.6 on one system, and you suddenly decide to delete that rack controller from 2.6 and attempt to register the same code to a 2.9 MAAS, the VM host may fail or disappear. This will possibly delete all the VMs you have created or connected to that VM host – which may result in data loss. This action is not supported.
Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behavior. It is not a supported configuration.
