MAAS installation (deb/2.8/UI)
  1. Prepare for MAAS installation
  2. Install and verify MAAS
  3. Configure MAAS
Note that all headings are hyperlinks that can be bookmarked.
You should take the following steps before installing MAAS for the first time on a new system:
  1. Make sure that the target system meets the minimum hardware requirements.
  2. Make sure you understand how support works currently, for MAAS 2.8.
  3. Make sure that the target system is running Ubuntu 18.04 LTS or higher, by executing the following command:
lsb_release -a
Distributor ID:	Ubuntu
Description:	Ubuntu xx.yy
Release:	xx.yy
Codename:	$RELEASE_NAME
The minimum “xx.yy” required for MAAS 2.8 is “18.04,” codenamed “bionic.”
If you are upgrading from MAAS 2.3 (or earlier) to MAAS 2.8, do not follow Step 4 below; instead, see Upgrading from MAAS 2.3, below.
  1. If you are currently running Ubuntu 16.04, you can upgrade to bionic 18.04 LTS with the following procedure:
a. Upgrade the release:
sudo do-release-upgrade --allow-third-parties
b. Accept the defaults for any questions asked by the upgrade script.
c. Reboot the machine when requested.
d. Check whether the upgrade was successful:
lsb_release -a
Description:	Ubuntu 18.04(.nn) LTS
Release:	18.04
Codename:	bionic
Upgrading from MAAS 2.3 - 2.8
If you’re upgrading from any version less than MAAS 2.7: While the following procedures should work, note that they are untested. Use at your own risk. Start by making a verifiable backup; see step 1, below.
Upgrading from MAAS 2.3 to 2.8
If you are running MAAS version 2.3 and you want to upgrade to MAAS 2.8, the following (untested) procedure may work for you:
  1. Back up your MAAS server completely; the tools and media are left entirely to your discretion. Just be sure that you can definitely restore your previous configuration, should this procedure fail to work correctly.
  2. Add the MAAS 2.7 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo add-apt-repository ppa:maas/2.8
  1. Run the release upgrade like this, answering any questions with the given default values:
  1. Check whether your upgrade has been successful by entering:
lsb_release -a
No LSB modules are available.
Release:	18.04
Codename:	bionic
  1. Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the latest stable 2.7 release.
  2. If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 2.8.
Upgrading from MAAS 2.4, 2.5, or 2.6 to MAAS 2.8
  2. Add the MAAS 2.8 PPA to your repository list with the following command, ignoring any apparent error messages:
  1. Run the MAAS upgrade like this:
sudo apt update
sudo apt upgrade maas
  1. Check whether your upgrade has been successful by looking at the information on the bottom of the machine list, in your running MAAS install, to make sure you’re running the latest stable 2.8 release.
Upgrading from MAAS 2.7 to MAAS 2.8
Upgrading from MAAS 2.7 to MAAS 2.8 is standard operating procedure, completed with the following steps:
  1. Back up your MAAS server completely; the tools and media are left entirely to your discretion. Just be sure that you can definitely restore your previous configuration, should this procedure unexpectedly fail.
sudo apt update
This section explains how to:
Upgrading from MAAS 2.7 to MAAS 2.8 is accomplished via the following command sequence:
sudo apt update
Install MAAS from packages
You can install a 2.8 stable version of MAAS via the PPA listed on the MAAS launchpad, specifically:
To add the 2.8 PPA, type:
sudo add-apt-repository -yu ppa:maas/2.8
Installation scenarios
The recommended way to set up an initial MAAS environment is to put everything on one machine:
sudo apt install maas
Executing this command leads you to a list of dependent packages to be installed, and a summary prompt that lets you choose whether to continue with the install:
Choosing “Y” proceeds with a standard apt package install.
Distributed environment
and the rack controller on another:
sudo maas-rack register
These two steps will lead you through two similar apt install sequences.
Creating a MAAS user
Finally, you will need to create a MAAS administrator user to access the web UI:
For example, the process might go like this:
The username can be anything. You will also be prompted to supply a password for the user. The command option --password=$PASSWORD can be used to specify one but, depending on your environment, this may pose a security risk.
At this time, MAAS does not make use of the email address. However, it may do so in the future.
Finally, the createadmin option asks for an SSH key:
If you have an SSH key associated with your launchpad or github accounts, you can enter the username here to use the associated key. For launchpad, just enter lp:username, and for github, enter gh:username at the prompt. In both cases, the actual username has to be supplied after the lp: or gh: prefix.
If you don't have a key associated with either of these services, you will have an opportunity to paste your public key into the MAAS SSH key list, after you've started MAAS for the first time as part of the welcome screens.
Next steps
Once you have installed your MAAS environment (region + rack controller) and any possible extra rack controllers(s), you are ready to begin your Configuration journey.
Reinitialising MAAS
sudo maas init region
The MAAS command takes additional init options.
snap-3-0-ui snap-3-0-cli -->
How to configure MAAS
http://${API_HOST}:5240/MAAS
Configuration
lp:<username>
gh:<username>
Enabling DHCP
Networking
