Disk erasure (snap/2.7/CLI)
Erasure types
The three types of erasure types are:
  1. Standard erase
  2. Secure erase
  3. Quick erase
Standard erase
Secure erase
Quick erase
Erasure procedure
and not:
Specifying both erasure types
