This page explains how to use availability zones with MAAS. You can learn about availability zones elsewhere in this documentation set.
List availability zones
To see a list of availability zones:
In the MAAS UI, select AZs from the top tab bar.
Via the MAAS CLI, enter the following command:
maas $PROFILE zones read \ | jq -r '(["ZONE","NAME","DESCRIPTION"] | (., map(length*"-"))), (.[] | [.id, .name, .description]) | @tsv' | column -t
which produces output similar to:
ZONE NAME DESCRIPTION ---- ---- ----------- 5 BizOffice 1 default 4 Inventory 2 Medications 3 Payroll 6 ProServ
Add an availability zone
To create an availability zone:
In the MAAS UI, select AZs > Add AZ > enter Name,Description > Add AZ.
Via the CLI, enter the following command:
maas $PROFILE zones create name=$ZONE_NAME description=$ZONE_DESCRIPTION
Edit an availability zone
To edit an availability zone:
In the MAAS UI, select AZs > > Edit > Update Name,Description > Update AZ.
Via the MAAS CLI, enter a command similar to the following:
maas $PROFILE zone update $OLD_ZONE_NAME name=$NEW_ZONE_NAME \ description=$ZONE_DESCRIPTION
Delete an availability zone
To delete an availability zone:
In the MAAS UI, select AZs > > Delete AZ > Delete AZ.
Via the MAAS CLI, enter a command like this:
maas $PROFILE zone delete $ZONE_NAME
Assign a machine to an availability zone
To assign a machine to an availability zone:
In the MAAS 3.4 UI, select Machines > choose machines > Categorise > Set zone > choose Zone > Set zone for machine.
With the UI for all other MAAS versions, select Machines > choose machines > Take action > Set zone > choose Zone > Set zone for machine.
Via the MAAS CLI, first retrieve the machine’s system ID like this:
maas PROFILE machines read | jq '.[] | .hostname, .system_id'
Then enter the following command, using the system ID you just retrieved:
maas admin machine update $SYSTEM_ID zone=$ZONE_NAME
Deploy a machine in a particular zone (CLI)
To deploy in a particular zone:
First acquire the machine, assigning it to the particular zone:
maas $PROFILE machines allocate zone=$ZONE_NAME system_id=$SYSTEM_ID
Then deploy the machine as normal:
maas $PROFILE machine deploy system_id=$SYSTEM_ID
