What would you like to do?
- Migrate an existing snap installation to use a local PostgreSQL server
- Manually export the MAAS database
- Network boot an IBM Power server
- Try jq recipes using the CLI
If you’re currently running MAAS from a snap in all
mode, you can easily migrate your database to a local PostgreSQL server with the following command:
This will produce a binary dump in maasdb-dump.tar
. You can then stop the MAAS snap via
sudo snap stop maas
sudo -u postgres \
Also, make sure that remote access is set up for the newly created maas
user in /etc/postgresql/10/main/pg_hba.conf
. The file should contain a line similar to:
host maasdb maas 0/0 md5
Be sure to replace 0/0
, above, with the proper CIDR to restrict access to a specific subnet. Finally, you can import the database dump with:
- update the database config in
with the properdatabase_host
anddatabase_pass
- change the content of
/var/snap/maas/common/snap_mode
fromall
toregion+rack
Here are some jq
recipes to get some human-readable output from the MAAS CLI.
Basic machine list
This recipe, which we keep in a file called jqml.sh
, prints a basic machine list
#!/bin/bash
It’s a good idea to keep your most important machine tag first, as it’s the first one you’ll see. It makes scanning your list (UI or CLI/jq) much more efficient. Here’s a recipe that adds the first tag to the console-printed machine list. We keep it in jqmltag.sh
, but of course, you can call it whatever you want.
#!/bin/bash
