By default, every MAAS machine is tested with the smartctl-validate
script, which is a script prepared by Canonical using the smartmontools kit. This is a disk integrity test. Typical output includes the following:
Device Model: QEMU HARDDISK
Serial Number: QM00001
Firmware Version: 2.5+
User Capacity: 5,368,709,120 bytes [5.36 GB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA/ATAPI-7, ATA/ATAPI-5 published, ANSI NCITS 340-2000
Local Time is: Wed Sep 2 22:29:12 2020 UTC
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Unavailable
Write cache is: Enabled
ATA Security is: Unavailable
Wt Cache Reorder: Unavailable
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 0) The previous self-test routine completed
been run.
data collection: ( 288) seconds.
capabilities: (0x19) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Error logging capability: (0x01) Error logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 54) minutes.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO---- 100 100 006 - 0
3 Spin_Up_Time PO---- 100 100 000 - 16
4 Start_Stop_Count -O---- 100 100 020 - 100
5 Reallocated_Sector_Ct PO---- 100 100 036 - 0
9 Power_On_Hours PO---- 100 100 000 - 1
12 Power_Cycle_Count PO---- 100 100 000 - 0
190 Airflow_Temperature_Cel PO---- 069 069 050 - 31 (Min/Max 31/31)
|______ P prefailure warning
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SCT Commands not supported
