About MAAS (snap/2.7/UI)
Four questions you might have:
  1. What is MAAS?
  2. What does MAAS offer me?
  3. Can MAAS co-locate key components to conserve resources?
  4. How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
  1. web UI (optimised for mobile devices)
  2. Ubuntu, CentOS, Windows, and RHEL installation support
  3. open-source IP address management (IPAM)
  4. full API/CLI support
  5. high availability (optional)
  6. IPv6 support
  7. inventory of components
  8. DHCP and DNS for other devices on the network
  9. DHCP relay integration
  10. VLAN and fabric support
  11. NTP for the entire infrastructure
  12. hardware testing
  13. composable hardware support
Colocation of key components
How MAAS works
