MAAS installation (snap/2.7/UI)
2.9 3.0
Snap CLI ~ UI CLI ~ UI
Packages CLI ~ UI CLI ~ UI
  1. Prepare for MAAS installation
  2. Install and verify MAAS
  3. Configure MAAS
Note that all headings are hyperlinks that can be bookmarked.
You should take the following steps before installing MAAS for the first time on a new system:
  1. Make sure that the target system meets the minimum hardware requirements.
  2. Make sure you understand how support works currently, for MAAS 2.7.
  1. Make sure you uninstall bind9, if it’s running on your system:
a. Check to see if bind9 is running:
ps aux | grep named
b. If bind9 is running, remove it with the following command:
sudo apt-get remove --auto-remove bind9
This section explains how to:
Install MAAS
The following command will give you a clean install of MAAS 2.7:
sudo snap install maas --channel=2.7
MAAS must be initialised prior to use.
Initialise MAAS
To initialise MAAS with a run mode:
  1. use the maas init command with the specified –mode argument region, rack, or region+rack:
sudo maas init --mode region+rack
  1. Answer the prompts in the dialog that appears:
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
If you enter a Launchpad or GitHub account name with associated SSH key, MAAS will import them automatically.
The MAAS URL sets the API address of one or more controllers. You will use the username and password to access the web UI.
Some modes will additionally ask for a shared secret that will allow the new rack controller to register with the region controller.
Re-initialise MAAS
To re-initialise MAAS, use the following command:
Verify MAAS installation
After a snap installation of MAAS, you can verify that the installation was successful with the following command:
sudo maas config
This command should return a sequence similar to the following if MAAS is operating propery:
Mode: region+rack
Settings:
maas_url=http://192.168.122.1:5240/MAAS
Check service statuses
sudo maas status
Sample output should look something like this:
Reinitialising MAAS
sudo maas init region
The MAAS command takes additional init options; see the MAAS installation technical reference for details.
snap-3-0-ui snap-3-0-cli -->
How to configure MAAS
http://${API_HOST}:5240/MAAS
Configuration
lp:<username>
gh:<username>
Enabling DHCP
Networking
