IP ranges (deb/2.8/UI)
Three questions you may have:
  1. How do I create an IP range?
  2. How do I edit an existing IP range?
  3. How do I delete an existing IP range?
Create a range
To create a range with the web UI, choose the “Subnets” option across the top:
In the “SUBNET” column, choose the subnet for which you want to create an IP range(s):
Scroll down to “Reserved ranges” on the subnet screen and click on the “Reserve range” drop-down:
Choose ‘Reserve range’ or ‘Reserve dynamic range’. If you choose the latter, MAAS will automatically provide DHCP for enlistment and commissioning provided that the associated VLAN has DHCP enabled. Read the DHCP page.
Edit a range
Delete a range
