Storage (deb/2.8/UI)
Six questions you may have:
  1. How does UEFI booting work?
  2. What kind of storage layouts are available?
  3. How do I set global storage layouts?
  4. How do I set per-machine storage layouts?
  5. What storage modifications can I make at the filesystem level?
  6. How can I erase a disk?
UEFI
Layouts
There are three layout types:
  1. Flat layout
  2. LVM layout
  3. bcache layout
Flat layout
sda - disk
sda2 rest of sda part ext4 /
LVM layout
sda - disk
lvroot rest of sda lvm ext4 /
vgroot rest of sda lvm
bcache layout
sda - disk
sdb (ssd) - disk
bcache0 per sda2 disk ext4 /
VMFS6 layout
Name Size Type Use
sda - disk
sda1 3 MB part EFI
sda2 4 GB part Basic Data
sda4 - skipped
sda5 249 MB part Basic Data
sda6 249 MB part Basic Data
sda8 285 MB part Basic Data
Blank layout
Setting layouts
Machine layout
Final storage modifications
