Commission machines (snap/2.7/CLI)
Twelve questions you may have:
  1. Tell me about enlistment vs. commissioning.
  2. How are machines commissioned?
  3. How can I commission NUMA and SR-IOV nodes?
  4. What are MAAS commissioning scripts?
  5. What post-commission configuration is possible?
  6. What is a bond interface and how do I create one?
  7. What is a bridge interface and how do I create one?
  8. How do I assign an interface to a fabric?
  9. How do I discover interface identifiers?
  10. How do I delete an interface?
  11. How do I create a VLAN interface?
  12. How do I delete a VLAN interface?
Enlistment versus commissioning
When you configure a machine to netboot – and turn it on while connected to the network – MAAS will enlist it, giving it a status of “New.” You can also add a machine manually). In either case, the next step is commissioning, which boots the machine into an ephemeral Ubuntu kernel so that resource information can be gathered. This resource information includes (but isn’t limited to) information about CPUs, memory, and storage. You can also run custom commissioning scripts to meet your specific needs.
How machines are commissioned
  1. DHCP server is contacted
  3. machine boots
  5. cloud-init runs built-in and custom commissioning scripts
  6. machine shuts down
To commission a machine:
To commission all nodes in the “New” state:
maas $PROFILE machines accept-all
  1. enable_ssh: Optional integer. Controls whether to enable SSH for the commissioning environment using the user’s SSH key(s). ‘1’ == True, ‘0’ == False. Roughly equivalent to the Allow SSH access and prevent machine powering off in the web UI.
  2. skip_bmc_config: Optional integer. Controls whether to skip re-configuration of the BMC for IPMI based machines. ‘1’ == True, ‘0’ == False.
  3. skip_networking: Optional integer. Controls whether to skip re-configuring the networking on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain network configuration in the web UI.
  4. skip_storage: Optional integer. Controls hether to skip re-configuring the storage on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain storage configuration in the web UI.
  5. commissioning_scripts: Optional string. A comma separated list of commissioning script names and tags to be run. By default all custom commissioning scripts are run. Built-in commissioning scripts always run. Selecting update_firmware or configure_hba will run firmware updates or configure HBA’s on matching machines.
  6. testing_scripts: Optional string. A comma seperated list of testing script names and tags to be run. By default all tests tagged commissioning will be run. Set to none to disable running tests.
  7. parameters: Optional string. Scripts selected to run may define their own parameters. These parameters may be passed using the parameter name. Optionally a parameter may have the script name prepended to have that parameter only apply to that specific script.
Commission NUMA and SR-IOV nodes
  • 00-maas-00-support-info: MAAS gathers information that helps to identify and characterise the machine for debugging purposes, such as the kernel, versioning of various components, etc.
  • 00-maas-01-lshw: this script pulls system BIOS and vendor info, and generates user-defined tags for later use.
  • 00-maas-03-install-lldpd: this script installs the link layer discovery protocol (LLDP) daemon, which will later capture networking information about the machine. The lldpd needs to be installed early because it requires about a 60-second delay before running.
  • 00-maas-04-list-modaliases: this script figures out what hardware modules are loaded, providing a way to autorun certain scripts based on which modules are loaded.
  • 00-maas-05-dhcp-unconfigured-ifaces: MAAS will want to know all the ways the machine is connected to the network. Only PXE comes online during boot; this script brings all the other networks online so they can be recognised.
  • 00-maas-06-get-fruid-api-data: this script gathers information for the Facebook wedge power type.
  • 00-maas-08-serial-ports: this script lists what serial ports are available on the machine.
  • 40-maas-01-network-interfaces: this script is just used to get the IP address, which can then be associated with a VLAN/subnet.
  • 50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
  • 99-maas-01-capture-lldp: this script gathers LLDP network information to be presented on the logs page; this data is not used by MAAS at all.
  • 99-maas-05-kernel-cmdline: this script is used to update the boot devices; it double-checks that the right boot interface is selected.
Commissioning runs the same dozen or so scripts as enlistment, gathering all the same information, but with these two caveats:
  1. Commissioning also runs user-supplied commissioning scripts, if present. Be aware that these scripts run as root, so they can execute any system command.
  2. Commissioning runs test scripts which are not run during enlistment.
Post-commission configuration
Once commissioned, you can configure the machine’s network interface(s). Specifically, when a machine’s status is either “Ready” or “Broken”, interfaces can be added/removed, attached to a fabric and linked to a subnet, and provided an IP assignment mode. Tags can also be assigned to specific network interfaces (see Tags for network interfaces).
For instance, to have interface 58, with subnet link 146, on machine exqn37 use DHCP on subnet 192.168.1.0/24:
Bond interfaces and how to create one
A bond interface is used to aggregate two or more physical interfaces into a single logical interface. Combining multiple network connections in parallel can increase network throughput beyond what a single NIC will allow. It also provides some redundancy in case one of the NICs should fail. More information about the theory behind bonded NICs is found in the relevant IEEE standard.
A bond can be created with the following command:
Use the parents parameters to define which interfaces form the aggregate interface.
The bond_updelay and bond_downdelay parameters specify the number of milliseconds to wait before either enabling or disabling a slave after a failure has been detected.
The following is an example of create-bond in action:
There are a wide range of bond parameters you can choose when creating a bond:
Parameter Type and description
mac_address Optional string. MAC address of the interface.
tags Optional string. Tags for the interface.
vlan Optional string. VLAN the interface is connected to. If not provided then the interface is considered disconnected.
parents Required integer. Parent interface ids that make this bond.
bond_miimon Optional integer. The link monitoring freqeuncy in milliseconds. (Default: 100).
bond_downdelay Optional integer. Specifies the time, in milliseconds, to wait before disabling a slave after a link failure has been detected.
bond_updelay Optional integer. Specifies the time, in milliseconds, to wait before enabling a slave after a link recovery has been detected.
bond_lacp_rate Optional string. Option specifying the rate at which to ask the link partner to transmit LACPDU packets in 802.3ad mode. Available options are fast or slow. (Default: slow).
bond_xmit_hash_policy Optional string. The transmit hash policy to use for slave selection in balance-xor, 802.3ad, and tlb modes. Possible values are: layer2, layer2+3, layer3+4, encap2+3, encap3+4. (Default: layer2)
bond_num_grat_arp Optional integer. The number of peer notifications (IPv4 ARP or IPv6 Neighbour Advertisements) to be issued after a failover. (Default: 1)
mtu Optional integer. Maximum transmission unit.
accept_ra Optional boolen. Accept router advertisements. (IPv6 only)
autoconf Optional boolean. Perform stateless autoconfiguration. (IPv6 only)
bond_mode Optional string. The operating mode of the bond. (Default: active-backup).
Supported bonding modes include:
Mode Behavior
balance-rr: Transmit packets in sequential order from the first available slave through the last. This mode provides load balancing and fault tolerance.
active-backup Only one slave in the bond is active. A different slave becomes active if, and only if, the active slave fails. The bond’s MAC address is externally visible on only one port (network adapter) to avoid confusing the switch.
balance-xor Transmit based on the selected transmit hash policy. The default policy is a simple [(source MAC address XOR’d with destination MAC address XOR packet type ID) modulo slave count].
broadcast Transmits everything on all slave interfaces. This mode provides fault tolerance.
802.3ad IEEE 802.3ad dynamic link aggregation. Creates aggregation groups that share the same speed and duplex settings. Uses all slaves in the active aggregator according to the 802.3ad specification.
balance-tlb Adaptive transmit load balancing: channel bonding that does not require any special switch support.
balance-alb Adaptive load balancing: includes balance-tlb plus receive load balancing (rlb) for IPV4 traffic, and does not require any special switch support. The receive load balancing is achieved by ARP negotiation.
parent=$IFACE_ID
Use parent to define the primary interface used for the bridge:
The following parameters may be applied when creating a bridge:
  1. name: Optional string. Name of the interface.
  2. mac_address: Optional string. MAC address of the interface.
  3. tags: Optional string. Tags for the interface.
  4. vlan: Optional string. VLAN the interface is connected to.
  5. parent: Optional integer. Parent interface id for this bridge interface.
  6. bridge_type: Optional string. The type of bridge to create. Possible values are: standard, ovs.
  7. bridge_stp: Optional boolean. Turn spanning tree protocol on or off. (Default: False).
  8. bridge_fd: Optional integer. Set bridge forward delay to time seconds. (Default: 15).
  9. mtu: Optional integer. Maximum transmission unit.
  10. accept_ra: Optional boolean. Accept router advertisements. (IPv6 only)
  11. autoconf: Optional boolean. Perform stateless autoconfiguration. (IPv6 only)
Delete a bridge interface
The “delete” command can be used to delete a bridge interface, a bond interface or a physical interface:
For example:
Note that while the label is presented, there is no machine-readable output expected after the successful execution of the delete command.
Bridge interfaces and how to create one
parent=$IFACE_ID
Use ‘parent’ to define the primary interface used for the bridge:
sudo apt install jq
Example output:
Example output:
Example output:
Interface identifiers
"id": 15,
"name": "ens9",
Delete an interface
The ‘delete’ command can be used to delete a bridge interface, a bond interface or a physical interface:
For example:
There is no machine-readable output after the successful execution of the delete command.
Create a VLAN interface
    "vid": 100,
    "mtu": 1500,
    "dhcp_on": false,
    "external_dhcp": null,
    "relay_vlan": null,
    "name": "Storage network",
    "space": "undefined",
    "fabric": "fabric-0",
    "id": 5004,
    "primary_rack": null,
    "fabric_id": 0,
    "secondary_rack": null,
parent=$IFACE_ID
    "tags": [],
    "type": "vlan",
    "enabled": true,
    "system_id": "4efwb4",
    "id": 21,
    "children": [],
    "params": {},
    "vlan": {
        "vid": 100,
        "mtu": 1500,
        "dhcp_on": false,
        "relay_vlan": null,
        "id": 5004,
        "fabric_id": 0,
    "parents": [
        "ens3"
    "effective_mtu": 1500,
    "links": [
            "id": 55,
            "mode": "link_up"
    "discovered": null,
    "name": "ens3.100",
Delete a VLAN interface
maas admin vlan delete 0 100
