MAAS requirements (deb/2.7/UI)
Two questions you might have:
  1. What are the requirements for a test environment?
  2. What are the requirements for a production environment?
| | Memory (MB) | CPU (GHz) | Disk (GB) |
| Ubuntu Server (including logs)| 512 | 0.5 | 5 |
