Tips and tricks
What would you like to do?
Migrate an existing test database
It’s not recommended to migrate a maas-test-db from one version to another, but it is possible, using these instructions:
    sudo pg_dump -U maas -h /var/snap/maas-test-db/common/postgres/sockets \
	sudo snap stop maas
Manually export the MAAS database
sudo snap stop maas
sudo -u postgres \
  • update the database config in /var/snap/maas/current/regiond.conf with the proper database_host and database_pass
  • change the content of /var/snap/maas/common/snap_mode from all to region+rack
Network boot IBM Power servers
Some IBM Power server servers have OPAL firmware which uses an embedded Linux distribution as the boot environment. All the PXE interactions are handled by Petitboot, which runs in the user space of this embedded Linux rather than a PXE ROM on the NIC itself.
If you get into a situation where MAAS and LXD are both managing DNS on your MAAS network, there’s a simple fix. You can turn off LXD’s DNS management with the following command:
You should also disable DHCP on IPv4 and IPv6 withing LXD:
lxc network set $LXD_BRIDGE_NAME ipv4.dncp=false
Once you’ve done this, you can check your work with the following command:
lxc network show $LXD_BRIDGE_NAME
Use jq to make CLI output more readable
Basic machine list
#!/bin/bash
 #!/bin/bash
