Give me an example of MAAS (snap/2.7/CLI)
An evolving example may be useful to introduce you to MAAS, and it doesn’t have to be comprehensive – just coherent and plausible. This example will continue to expand and update over time.
FQDN               POWER  STATUS     OWNER  TAGS     POOL       NOTE     ZONE
52-54-00-15-36-f2  off    Ready      -      Orders   Prescrbr   @md-all  Medications
52-54-00-17-64-c8  off    Ready      -      HRMgmt   StaffComp  @tmclck  Payroll
52-54-00-1d-47-95  off    Ready      -      MedSupp  SuppServ   @storag  Inventory
52-54-00-1e-06-41  off    Ready      -      PatPrtl  BusOfc     @bzstns  BizOffice
52-54-00-1e-a5-7e  off    Ready      -      Pharm    Prescrbr   @rxonly  Pharmacy
52-54-00-2e-b7-1e  off    Allocated  admin  NursOrd  NurServ    @nstns   Nursing
52-54-00-2e-c4-40  off    Allocated  admin  MedAdmn  NurServ    @rxonly  Nursing
52-54-00-2e-ee-17  off    Deployed   admin  Charts   ProServ    @md-all  Physician
Be aware that newly-created machines will only have default settings for tags, resource pools, zones, and notes, and will probably all be in the “Ready” state, with no owner.
So imagine that you’re the IT administrator for a new, 100-bed hospital that’s under construction, intended to serve a suburban community of 5,000 people. Call it “Metaphorical General Hospital” (MGH). Your job is to design a flexible data centre for this facility. You’ve decided to start with MAAS as your tool of choice, and for this planning exercise, you’ll use VMs in a VM host.
Machines
You’ll need to start with a little network thinking (and design). Talking through requirements with the staff, you come up with a random list of functions:
Charts Provider orders Provider documentation
Pharmacy Narcotics control Insurance collections
Housekeeping Nursing orders Med reconciliation
Timeclock Patient collections Med/surgical supplies
Office supplies Patient registration Insurance reconciliation
Payroll Medication admin Continuing education
Food service Instrumentation Information technology
You can handle this lowest level with individual machines. With MAAS, you’ll be able to modify how many machines are performing which functions, somewhat on-the-fly, but let’s assume that you start by creating (at least) one VM for each function. Since you can reassign machines at will, you aren’t going to name them for their functions; instead, you’re just going to use the MAC address of each machine to uniquely identify it.
Try it!
Creating some sample VMs
Assuming you’ve installed libvirt on the machine where you’ll be running MAAS, you can create virtual machines like this:
Open the Virtual Machine Manager application. You’ll see a screen that looks something like this:
Choose File --> New Virtual Machine, which brings you to a corresponding dialog:
Select the “Network Boot (PXE)” option and click the “Forward” button:
Choose the “Generic…” operating system by typing the first letters of “Generic” in the text box and selecting the relevant choice when it becomes available, then go Forward:
For CPU and memory, you can usually accept the defaults:
The storage values have a noticeable effect on local disk usage, so note that, generally, a VM only requires about 5.0 GiB, given an example exercise like this:
In the next screen, you’ll have the chance to set a name; here, we’ve used a pseudo-MAC address, although you can name the machine whatever you want (and then return later to set the name to match the MAC address, if desired):
Selecting “Finish” will create the virtual machine and attempt to boot it – which will fail, since no device currently knows about this VM (and hence can’t boot it). Not to worry; you’re not done yet:
Select the “information” button (blue circle, white lowercase “i”) to switch to the VM configuration screens, then select the “Boot Options” choice from the left-hand menu:
Turn off the “IDE” item under “Boot device order:”
When you select “Apply,” a dialog will pop up to remind you that you need to restart this VM for changes to take effect:
Switch to the “NIC…” option and set the “Network source” and “Device model” as shown, then select “Apply” and respond to the dialog:
You’ll next select the drop-down arrow next to the “on/off” menu bar option and select “Force reset,” then answer the prompt in the affirmative:
You now have a VM that you can add to MAAS. If you want more than one, you can simply right-click on the one you’ve just created and select “Clone:”
Pro Tip: Cloned VMs tend to use considerably less host disk space than newly-created ones.
Another VM will instantiate, using the name of the cloned VM with an added “-clone” suffix:
You can create VMs as desired, remembering to mind your overall disk usage on your host system.
Let’s assume that once you’re done adding VMs, you have around 20 up and ready, all named after their assigned MAC address:
No need to create a lot of VMs for this example (unless you just want to do so).
Manually adding machines
Once you’ve created the necessary VMs, you’ll want to manually add machines to MAAS that correspond to your VMs.
52-54-00-15-36-f2  off    Ready   -      virtual  default  -     default
52-54-00-17-64-c8  off    Ready   -      virtual  default  -     default
52-54-00-1d-47-95  off    Ready   -      virtual  default  -     default
52-54-00-1e-06-41  off    Ready   -      virtual  default  -     default
52-54-00-1e-a5-7e  off    Ready   -      virtual  default  -     default
52-54-00-2e-b7-1e  off    Ready   -      virtual  default  -     default
52-54-00-2e-c4-40  off    Ready   -      virtual  default  -     default
52-54-00-2e-eke-17  off    Ready   -      virtual  default  -     default
52-54-00-2f-6d-3c  off    Ready   -      virtual  default  -     default
52-54-00-4a-2a-30  off    Ready   -      virtual  default  -     default
52-54-00-4e-60-b2  off    Ready   -      virtual  default  -     default
52-54-00-52-93-10  off    Ready   -      virtual  default  -     default
52-54-00-5d-b5-a1  off    Ready   -      virtual  default  -     default
52-54-00-60-1e-6f  off    Ready   -      virtual  default  -     default
52-54-00-60-8d-4b  off    Ready   -      virtual  default  -     default
52-54-00-62-22-e3  off    Ready   -      virtual  default  -     default
52-54-00-65-2e-20  off    Ready   -      virtual  default  -     default
52-54-00-6a-ac-23  off    Ready   -      virtual  default  -     default
52-54-00-6f-b4-af  off    Ready   -      virtual  default  -     default
52-54-00-71-0c-53  off    Ready   -      virtual  default  -     default
52-54-00-77-4e-53  off    Ready   -      virtual  default  -     default
52-54-00-98-42-ef  off    Broken  -      -        default  -     default
52-54-00-9b-e4-9a  off    Ready   -      virtual  default  -     default
52-54-00-9c-51-00  off    Ready   -      virtual  default  -     default
Try it!
Creating a machine from a VM requires six pieces of information:
  1. the machine architecture (e.g., amd64)
  2. the machine’s MAC address
  3. the power type (in this case, “virsh”)
  4. the power ID
  5. the power address (which also contains a username)
  6. the power password
Once you’ve collected this information, you’ll want to create a new KVM like this:
maas admin machines create \
architecture=amd64 hostname=52-54-00-15-36-f2 \
power_type=virsh power_parameters_power_id=f677a842-571c-4e65-adc9-11e2cf92d363 \
Here, we’ve assigned a variant of the MAC address as the machine name. Note that the machine name cannot include colons (":"), we’ve substituted dashes. You can gather most of this information from the KVM itself:
For default configurations, the Virsh Address is “qemu+ssh://[your-login-id]@192.168.122.1/system;” replace “[your-login-id]” with your username or login ID on the machine where you’re hosting MAAS and the Virtual Machine Manager. Likewise, the password is your normal login password for the same host. Finally, you can retrieve the Virsh VM ID from the “Overview” screen of the VM itself:
As you add machines, they automatically commission.
Tags
Assigning machines to specific functions is something you can do after you commission and deploy them. (Later on, we’ll discuss ways to load user apps and data onto the machines using the MAAS API.) Once you’ve got machines running apps, you want to keep up-to-date about which machine is doing what, when you’re looking at the machine list. You’ll want to assign tags to machines.
52-54-00-15-36-f2  off    Ready   -      Orders   default  -     default
52-54-00-17-64-c8  off    Ready   -      HRMgmt   default  -     default
52-54-00-1d-47-95  off    Ready   -      MedSupp  default  -     default
52-54-00-1e-06-41  off    Ready   -      PatPrtl  default  -     default
52-54-00-1e-a5-7e  off    Ready   -      Pharm    default  -     default
52-54-00-2e-b7-1e  off    Ready   admin  NursOrd  default  -     default
52-54-00-2e-c4-40  off    Ready   admin  MedAdmn  default  -     default
52-54-00-2e-ee-17  off    Ready   admin  Charts   default  -     default
Try it! Adding a tag to a machine is simple. First, you must create the tag:
Next you add the tag to a machine with the following command:
If you need to find the $SYSTEM_ID of your machines, you can use this command:
maas admin machines read | jq -r '(["HOSTNAME","SYSID"]
Tags can will help you keep up with which machine(s) are covering which functions as you apply your apps. You can search and filter by tags, and you can utilise tags from within the API, as well.
Resource pools
As you look at the list of functions you’ve created, and talk more with the staff, you discover that some of these functions fit together more closely than others. With some effort, you work out the following update to your network design:
Provider services
Nursing services
Nursing orders Continuing education
Nursing meds
Medication administration Narcotics control
Prescriber controls
Pharmacy Narcotics control Medication reconciliation
Staff compensation
Timeclock Payroll
Supplies & services
Medical and surgical supplies Office and general supplies
Business office
Collections
Patient collections Insurance collections
Patient support
Housekeeping Food service
Staff support
You’re aware that the number of machines you’ll need use for each of the individual functions with vary according to real-world events in the hospital. Still, you’d prefer to budget machines for these different functions, so that you know you can meet the needs of each. The easiest way to handle this? Creating resource pools and naming them after the (new) top-level headings in your outline. That way, you can reserve some number of machines for those functions, learning over time the right number of machines to allocate to each activity.
Try it!
Just like tags, you must first create a resource pool before assigning a machine to it.
Here’s an example that demonstrates how to create a new resource pool named “myresource” in a single command; note that the description field is optional, but often very helpful:
Once you’ve created the pool you want, you can add a machine that pool with the following command:
Here’s a snippet of the updated machine list, with all machines added to the appropriate resource pool:
52-54-00-15-36-f2  off    Ready   -      Orders   Prescrbr   -     default
52-54-00-17-64-c8  off    Ready   -      HRMgmt   StaffComp  -     default
52-54-00-1d-47-95  off    Ready   -      MedSupp  SuppServ   -     default
52-54-00-1e-06-41  off    Ready   -      PatPrtl  BusOfc     -     default
52-54-00-1e-a5-7e  off    Ready   -      Pharm    Prescrbr   -     default
52-54-00-2e-b7-1e  off    Ready   admin  NursOrd  NurServ    -     default
52-54-00-2e-c4-40  off    Ready   admin  MedAdmn  NurServ    -     default
52-54-00-2e-ee-17  off    Ready   admin  Charts   ProServ    -     default
Resource pools are mostly for your use, helping you to budget servers within a given category. Untagged servers can be in a pool, so if you’ve got five servers in the “Prescriber controls” resource pool, you can tag them with “Pharmacy,” “Medication reconciliation,” etc., as you use them. It will also be obvious when you’re running low on servers for that pool, and need to either provision more or move some unused ones from another pool.
Notes
Another optional identifier for machines is the “Note” field. While it can be long, a portion of it shows up on the machine list, which makes it useful for adding special identifiers or groupings. In this example, we’ve added a vague identifier which might help an IT admin remember server locations or access rights.
52-54-00-15-36-f2  off    Ready   -      Orders   Prescrbr   @md-all  default
52-54-00-17-64-c8  off    Ready   -      HRMgmt   StaffComp  @tmclck  default
52-54-00-1d-47-95  off    Ready   -      MedSupp  SuppServ   @storag  default
52-54-00-1e-06-41  off    Ready   -      PatPrtl  BusOfc     @bzstns  default
52-54-00-1e-a5-7e  off    Ready   -      Pharm    Prescrbr   @rxonly  default
52-54-00-2e-b7-1e  off    Ready   admin  NursOrd  NurServ    @nstns   default
52-54-00-2e-c4-40  off    Ready   admin  MedAdmn  NurServ    @rxonly  default
52-54-00-2e-ee-17  off    Ready   admin  Charts   ProServ    @md-all  default
Try it!
To add a note to a machine, you’ll first need to determine its system ID (see above). Once you have that, you can add or change a note like this:
maas $PROFILE machine update $SYSTEM_ID description="note"
It helps very much to keep your notes short, since only a few characters are visible on the machine list.
VLANs
Looking over your design, you notice that some of these resource pools must have their network traffic “fire-walled” from others – for example, Provider services and Nursing services shouldn’t be readily visible to Staff compensation or Food service. Likewise, the relevant monitoring agencies require that facilities manage medications as a separate activity. The traditional way to separate these networks (other than creating entirely separate networks) would be a VLAN. Luckily, MAAS supports multiple VLANS. Adding one higher level to your design, you find yourself with this updated network topology:
Caregiver services
Provider services Nursing services
Medication management
Nursing meds Prescriber controls
Accounts payable
Staff compensation Supplies & services
Accounts receivable
Business office Collections
Patient support
Staff support
Each of these higher-level groupings is ideal for a VLAN, so you create six of them, one for each division:
FABRIC    VLAN                   DHCP
fabric-0  Accounts_Receivable    false
fabric-0  Staff_Support          false
fabric-0  Patient_Support        false
fabric-0  Accounts_Payable       false
fabric-0  Medication_Management  false
fabric-0  Caregiver_Services     false
fabric-0  untagged               false
You can generate this list with the command:
maas admin vlans read $FABRIC_ID | jq -r '(["FABRIC","VLAN","DHCP"] | (., map(length*"-"))), (.[] | [.fabric, .name, .dhcp_on]) | @tsv' | column -t
Try it!
Adding a functional VLAN requires some additional (common) networking aspects, which we’ll cover later. In the meantime, though, here’s the short version of adding and naming the VLAN itself.
To create additional VLANs, choose the fabric where you want them to be added, and enter the following command, once for each new VLAN:
maas admin vlans create $FABRIC_ID name=$VLAN_NAME vid=$VLAN_ID
For example, to create the “Caregiver Services” VLAN with VID 100 on fabric 0, enter the following command:
maas admin vlans create 0 name="Caregiver_Services" vid=100
Ignoring the networking aspects (for now), these VLANs should help isolate major functions and provide a level of data integrity and access control for your new hospital network.
Fabrics
Considering your network design so far, you notice that some of the VLANs need to be able to communicate with each other some of the time. In fact, you decide on three pairs of VLANs to cover this new networking situation:
Patient management
Caregiver services Medication management
Accounting
Accounts payable Accounts receivable
Facilities
Patient support Staff support
You want to incorporate these highest-level groupings into your network, but how? MAAS provides the answer with fabrics. A fabric is a set of interconnected VLANs that can communicate, so you simply create three fabrics, each covering one of these top-level categories.
FABRIC              VLAN                   DHCP
Accounting          Accounts_Receivable    False
                    Accounts_Payable       False
Facilities          Patient_Support        False
                    Staff_Support          False
Patient_Management  Caregiver_Services     False
                    Medication_Management  False
