Block devices (snap/2.7/UI)
Physical
Virtual
List Block Devices
Output:
        "id": 10,
        "serial": "",
        "block_size": 4096,
        "available_size": 0,
        "filesystem": null,
        "id_path": "/dev/vda",
        "size": 5368709120,
        "model": "",
        "type": "physical",
        "uuid": null,
        "used_size": 5365563392,
        "partitions": [
                "bootable": false,
                "id": 9,
                "size": 5360320512,
                "type": "partition",
                "filesystem": {
                    "mount_options": null,
                    "label": null,
                    "fstype": "lvm-pv",
                    "mount_point": null
        "tags": [
            "rotary"
        "name": "vda"
        "id": 11,
        "serial": null,
        "block_size": 4096,
        "filesystem": {
            "label": "root",
            "fstype": "ext4",
            "mount_point": "/"
        "id_path": null,
        "size": 3221225472,
        "partition_table_type": null,
        "model": null,
        "type": "virtual",
        "used_size": 3221225472,
        "partitions": [],
        "tags": [],
        "name": "vgroot-lvroot"
Read Block Device
    "name": "vgroot-lvroot",
    "type": "virtual",
    "filesystem": {
        "mount_point": "/",
        "fstype": "ext4",
        "label": "root"
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
Create Block Device
    "name": "vdb",
    "used_for": "Unused",
    "type": "physical",
    "used_size": 0,
    "filesystem": null,
    "id_path": "",
    "id": 12,
    "block_size": 4096,
    "tags": [],
    "uuid": null,
    "serial": "QM00001",
    "partitions": [],
    "size": 21474836480,
    "model": "QEMU"
Update Block Device
    "block_size": 4096,
    "filesystem": null,
    "model": "QEMU",
    "name": "newroot",
    "partitions": [],
    "tags": [],
    "used_size": 0,
    "id_path": "",
    "uuid": null,
    "id": 12,
    "type": "physical",
    "serial": "QM00001"
Delete Block Device
Format Block Device
    "block_size": 4096,
    "size": 3221225472,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
        "mount_point": null
    "model": null,
    "partitions": [],
    "tags": [],
    "id_path": null,
    "id": 11,
    "type": "virtual",
    "serial": null
Unformat Block Device
    "available_size": 3221225472,
    "type": "virtual",
    "used_size": 0,
    "filesystem": null,
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
Mount Block Device
    "type": "virtual",
    "filesystem": {
        "mount_point": "/srv",
        "mount_options": "",
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
Unmount Block Device
    "type": "virtual",
    "filesystem": {
        "mount_point": null,
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
Set as Boot Disk
