How to configure controllers
A rack controller joins multiple VLANs from different interface. Racks connect to one MAAS instance at a time, which must match the rack’s major and minor MAAS version. This configuration provides a scaling factor that can help as a network architecture grows in size.
By contrast, a region controller manages communication with the user, via the Web UI/API, as well as managing the rack controller(s) in your system. The MAAS postgres database is also managed by the region controller. Typical region-level responsibilities include requesting that a rack controller boot a machine, and providing the ephemeral Ubuntu image needed to commission or enlist a machine.
This page will explain how to manage and configure both controller types.
Add a new rack
  • To install and register a rack controller with MAAS using the Snap version:
    sudo snap install maas
    sudo maas init rack --maas-url $MAAS_URL --secret $SECRET
    The $SECRET is stored in file /var/snap/maas/common/maas/secret on the API server.
  • To install and register a rack controller with MAAS:
    sudo maas-rack register --url $MAAS_URL --secret $SECRET
    The register command is not required when you are adding a rack controller to a system that already houses an API server. The $SECRET is stored in file /var/lib/maas/secret on the API server.
The UI has complete instructions for adding a rack controller under the “Controllers” tab. Select Add rack controller and choose the instructions relevant to your build model (snap or packages). The presented commands embed the correct MAAS URL and secret, so you can cut and paste them at the command line.
List racks (CLI)
You can list and confirm all registered rack controllers with the CLI
Remember that high availability requires multiple rack controllers. If you are using VM nodes, you must ensure that the new rack controller can communicate with the VM host.
Delete a rack (UI)
To delete a rack controller:
Select Controllers > > Delete > Delete controller.
MAAS will do the right thing if the controller is used for DHCP HA; that is, the DHCP HA needs to be disabled. Unless you also remove the software on this deleted rack, rebooting it will cause the machine to re-instate itself as a rack controller. This behaviour may change with future versions of MAAS.
Move a rack controller
Moving a rack controller may generate errors, get you into a non-working state, or cause you significant data loss:
  • Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behaviour. It is not a supported configuration.
To move a rack controller, you must first delete the rack controller from one MAAS instance and reinstantiate it on another one. To delete a rack controller:
  • Using the MAAS UI, select Controllers > choose controller to remove > Take action > Delete > Delete controller.
  • Via the CLI, execute the following steps:
    There is no confirmation step.
Having deleted the previous rack controller, you must register a new one, which is always done from the command line:
  • For snap installs, use the following command:
  • For package installs, use this command instead:
    where the secret is found in /var/lib/maas/secret.
Region PostgreSQL
Note that the primary database and API servers often reside on the same host.
New region host
sudo systemctl restart bind9
Check the following log files for any errors:
Snap versions
  1. /var/snap/maas/common/log/regiond.log
  2. /var/snap/maas/common/log/maas.log
  3. /var/snap/maas/common/log/rsyslog/
Package versions
  1. /var/log/maas/regiond.log
  2. /var/log/maas/maas.log
  3. /var/log/syslog
Region performance
Increasing the number of workers will also increase the number of required database connections by 11 per extra worker. This may required PostgreSQL to have an increased number of allowed connections; please see the high availability article for more information on increasing the connections.
num_workers: 8
