How to mirror images locally
This page explains how to create and use a local mirror of MAAS images:
Install SimpleStreams
Start by installing SimpleStreams:
sudo apt install simplestreams
Define helper variables
Define these variables for cleaner CLI commands:
IMAGE_SRC=https://images.maas.io/ephemeral-v3/stable
IMAGE_DIR=/var/www/html/maas/images/ephemeral-v3/stable
Mirror your kernels
Mirror your kernels with these commands:
sudo sstream-mirror --keyring=$KEYRING_FILE $IMAGE_SRC $IMAGE_DIR 'arch=amd64' 'release~(bionic|focal)' --max=1 --progress
sudo sstream-mirror --keyring=$KEYRING_FILE $IMAGE_SRC $IMAGE_DIR 'os~(grub*|pxelinux)' --max=1 --progress
Use --dry-run to preview your selection. Remove it to begin the download.
MAAS saves images to the directory defined by ‘IMAGE_DIR’. The new boot source URL will be http://<myserver>/maas/images/ephemeral-v3/stable/.
You should verify image availability at the URL above. Regularly update your mirror with cron to fetch the latest images.
