MAAS is only useful once it has images available to provision its nodes. Therefore, one key post-install task is to select and import images from the boot source. Once MAAS imports images, it will update them on an hourly basis, via a default sync mechanism. This page explains how to select and import the images that MAAS requires to provision its nodes.
- How to use image streams
- How to import standard images from maas.io
- How to use other image mirrors to download images
- How to import and provision non-Ubuntu images
You can also mirror images locally, build your own custom images, or even work with VMWare images. And there’s some background info on images available if you need it.
How to use MAAS image streams
Canonical provides two SimpleStreams for MAAS images: candidate and stable. Both streams contain Ubuntu images, CentOS images, bootloaders extracted from the Ubuntu archive, and release notifications. Either stream can be used in any version of MAAS greater than 2.1 – but not all images are supported in older versions.
How to change the stream with the UI
To switch to the candidate stream:
Select Images.
Select Change source.
Select Custom.
Set the URL to
http://images.maas.io/ephemeral-v3/candidate. -
Select Connect.
MAAS uses the stable stream by default. To switch back to it, simply repeat the above procedure, but set the URL to maas.io.
How to change the stream with the CLI
The Images page shows what images and architectures have been selected and downloaded. By default, MAAS will automatically grab the most recent Ubuntu LTS releases (and amd64 architecture).
You can tell MAAS to sync images hourly, at the region level, using a toggle switch in the top-right corner of the screen. See Boot image sources) for more details. We highly recommended syncing images hourly. Syncing at the rack controller level (from regiond) occurs every 5 min and cannot be disabled.
To remove an image, simply un-select it and click Save selection.
You can also host Ubuntu images on a mirror. To use these mirrors:
Select Images.
Select Custom.
Enter the mirror URL.
Select Connect to bring the mirror online.
Advanced options, such as using a GPG key or keyring to validate the mirror path (snap installation location: /snap/maas/current/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg), are revealed by Selecting Show advanced options.
It is also possible to import and provision images other than Ubuntu. Images supported and provided by MAAS will appear in Images >> Other Images. These images can be imported and used just like the Ubuntu images above.
You can tell MAAS to sync images hourly, at the region level. See Boot image sources) for more details. We highly recommended syncing images hourly. Syncing at the rack controller level (from regiond) occurs every 5 min and cannot be disabled.
- How to get started with the MAAS CLI
- How to list boot sources
- How to select images
- How to list image selections
- How to import newly-selected images
- How to list currently available images
- How to delete a boot source
- How to edit a boot source
subarches="*" labels="*"
Hardware enablement (HWE)
subarches="hwe-x" labels="*"
Update the boot source:
How to add a boot source
Presented below are a couple of use cases for adding a boot source:
- Use a local image mirror (official images)
- If you deleted the default image, recreate it
The general syntax is:
How to use a local image mirror
- URL=https://$MIRROR/maas/images/ephemeral-v3/stable/
- KEYRING_FILE=/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg
How to recreate the default boot source
- URL=https://images.maas.io/ephemeral-v3/stable/
How to configure agent caching
The MAAS agent cache size can be tuned to optimise performance for your workload. A larger cache can improve speeds for repeated deployments of resource intensive images. But large caches waste space if they contain rarely used images.
To configure agent caching:
- Open /etc/maas/agent.yaml on the agent with sudo permissions
- Update image_cache_size parameter to desired value in bytes
- Save changes and restart agent for new size to take effect
- Monitor cache metrics and tune further if needed
Be sure to monitor caching metrics before and after sizing changes to validate improvements. Cache tuning is an iterative process.
How to monitor resource performance
Proactive monitoring helps detect and diagnose performance issues with boot resource distribution early. Sync failures and slow transfers impact cluster-wide availability. Here are some pointers to key metrics:
- Check region sync status and fix failures
- Review sync speed metrics for issues
- Analyse cache hit/miss rates and tune cache
- Inspect deployment logs for resource download times
- Verify migrations completed on all regions
- Ensure agents have adequate disk space
Address any metrics deviations or failures quickly to minimise disruption. Resource distribution is critical for smooth MAAS operation.
How to import custom resources
Importing custom boot resources requires careful preparation and testing to avoid conflicts. Resources should be validated before use in production deployments. Here’s a thumbnail sketch of the import processes:
- Clone MAAS Packer templates as base for custom images
- Build and test resources before import
- Import into MAAS via CLI with unique name/title
- Check logs to validate successful import
- Deploy test nodes and validate functionality
Don’t assume imported resources will work without testing. Eliminate issues beforehand to avoid production disruptions.
