Many MAAS users maintain their data centres in an air-gapped environment that does not have an external Internet connection. MAAS runs well in this configuration, though keeping MAAS supplied with updates and images requires a bit of extra effort.
- Snap updates (via the snap proxy)
- Packages (via a local repo, possibly with a transparent proxy)
- MAAS-maintained images (via local mirror, possibly with a transparent proxy)
- Other OS images (various methods)
- About using the snap proxy
- About air-gapped package updates
- About local image mirroring
- About non-MAAS images
- About transparent proxies
About the snap proxy
Using snaps in an air-gapped environment is possible with the Snap Store Proxy, which can be deployed in networks that are disconnected from the Internet. Currently, the features required to use this proxy in an air-gapped↗ mode are part of a password-protected internal Beta.
Client devices connect to the air-gapped proxy and never contact the general Snap Store nor the Internet. Proxy operators will need to side-load all needed snaps and updates into the proxy. To use this proxy, you must:
- Register an offline Snap Store Proxy on an Internet-connected machine.
- Set up HTTPS access to ensure adequate security.
- Fetch the necessary snaps as needed by your MAAS environment (on the Internet-connected machine).
This proxy requires a properly configured PostgreSQL database – see the setup instructions↗ for the Snap Store Proxy for more details.
The simplest way to use local package repos is via the reprepro↗ command. There is an older command, apt-mirror, which is no longer maintained; it’s not recommended.
MAAS has an established process for mirroring images locally. In general, you must:
- Install the
simplestreamspackage. - Define some variables to simplify CLI usage.
- Create the desired mirrors, specifying where you want your images stored.
- Set up a new boot source on your local server, referring to the local mirror.
Use
user_data. A user can create customuser_datawhich will configure CentOS or RHEL to use a specific mirror. Check out the machine customisation page for details on how to make this work. -
Create custom images and store them in your local mirror. You can also create custom images and store them in your local mirror. Once you have the image built, consult the page on local image mirrors to see how to incorporate your newly-built image into the local stash.
- Configure Ubuntu to get packages via HTTP.
- Configure MAAS to get packages via HTTP.
- Create a local mirror repo for
archive.ubuntu.com. - Create a local image mirror for
images.maas.io. - Configure DNS to point to the local mirrors for both of those URLs.
