Report Issues
Errors or typos? Missing topics? Let us know.
MAAS allows machine customization before provisioning using Curtin or cloud-init.
Curtin pre-seeding
You can customize Curtin via the curtin_userdata template or by adding a custom file. Curtin supports early and late hooks for pre/post-installation customization.
- Early Command Example:
early_commands: signal: ["wget", "--no-proxy", "http://example.com/", "--post-data", "system_id=&signal=starting_install", "-O", "/dev/null"] - Late Commands Example:
late_commands: add_repo: ["curtin", "in-target", "--", "add-apt-repository", "-y", "ppa:my/ppa"] custom: ["curtin", "in-target", "--", "sh", "-c", "/bin/echo -en 'Installed ' > /tmp/maas_system_id"]
Cloud-init pre-seeding
To customize cloud-init:
MAAS 3.4+ UI:
Machines > machine > Actions > Deploy > Cloud-init user-data > enter customizations > Start deployment. -
Other versions UI:
Take action > Deploy > > Cloud-init user-data > enter customizations > Start deployment. -
CLI:
Set default minimum kernel
To set the default kernel for all machines:
MAAS 3.4+ UI:
Settings > Configuration > Commissioning > Default minimum kernel version > Save. -
Other versions UI:
Settings > General > Default minimum kernel version > Save. -
CLI:
Set minimum kernel per machine
To set a minimum deployment kernel for a specific machine:
MAAS UI:
Machines > machine > Configuration > Edit > Minimum kernel. -
CLI:
Set specific kernel during deployment
To set a kernel during deployment:
MAAS UI:
Machines > machine > Take action > Deploy > choose kernel > Deploy machine. -
CLI:
Set global kernel boot options
To set global kernel boot options:
MAAS 3.4+ UI:
Settings > Kernel parameters > enter options > Save. -
Other versions UI:
Settings > General > enter options > Save. -
CLI:
maas $PROFILE maas set-config name=kernel_opts value='$KERNEL_OPTIONS'
Kernel option tags
To create a tag with kernel options:
maas $PROFILE tags create name='$TAG_NAME' comment='$TAG_COMMENT' kernel_opts='$KERNEL_OPTIONS'
View tags:
maas admin tags read | jq -r '(["tag_name","tag_comment","kernel_options"] |(.,map(length*"-"))),(.[]|[.name,.comment,.kernel_opts]) | @tsv' | column -t
Enable hardware sync (MAAS 3.2+)
To enable hardware sync:
MAAS 3.4+ UI:
Machines > machine > Actions > Deploy > Periodically sync hardware > Start deployment. -
Other versions UI:
Take action > Deploy > Periodically sync hardware > Start deployment. -
CLI:
maas $PROFILE machine deploy $SYSTEM_ID osystem=$OSYSTEM distro_series=$VERSION enable_hw_sync=true
View Hardware Sync Updates
View updates in the MAAS UI or CLI:
Configure Hardware Sync Interval
Configure the sync interval in MAAS settings.
Set default layout
To set the default storage layout for all machines:
MAAS UI:
- Settings > Storage > choose default layout.
- Enable Erase machinesâ disks prior to releasing to force disk erasure.
CLI:
maas $PROFILE maas set-config name=default_storage_layout value=$LAYOUT_TYPEExample for setting layout to flat:
Set per-machine layout
Set a storage layout for a âReadyâ machine:
Example with LVM layout:
Erase disks
To erase a disk when releasing a machine:
- Use
machine release(singular) instead ofmachines release(plural).
Example:
maas $PROFILE machine release $SYSTEM_ID comment="some comment" erase=true [secure_erase=true || quick_erase=true]
- Secure erasure uses the driveâs secure erase feature, if available.
- Quick erasure wipes 2MB at the start and end of the disk. Not secure but faster.
- If no options are specified, the disk will be overwritten with null bytes (slow).
Set conditional erasure
To perform secure erasure if available, or quick erasure otherwise:
