Prior to deployment, MAAS machines can be customised in a number of ways, including:
- machine storage.
- commissioning and deployment configurations (known as “pre-seeding”).
- custom Ubuntu kernels.
- kernel boot options.
- resource pools.
Machines can also be customised post-deployment, while running, either by changing out the physical hardware, or by altering the VM from the VM host side. This will allow you to:
- add or remove disks
- add or remove network interfaces
- add or remove PCI devices
- add or remove USB devices
You cannot update these parameters from within MAAS on a deployed machine.
While deploying a machine, you can configure that machine to periodically sync its hardware configuration. Deployed machines will passively update changes to the BMC and tags for that machine, on-the-fly, as these changes are made.
In short, this article will explain these possible customisations, and provide detailed instructions on how to customise your own machines as desired.
This article will help you learn about customising machines
About customising machines prior to deployment
In this section, you’ll learn:
- About customising machine storage
- About pre-seeding (customising commissioning and deployment)
- About Ubuntu kernels
- About kernel boot options
- About resource pools
About UEFI booting
UEFI must be enabled or disabled for the lifespan of the machine. For example, do not enlist a machine with UEFI enabled, and then disable it before commissioning. It won’t work!
About block devices
Physical
Virtual
About partitions
About storage restrictions
- An EFI partition is required to be on the boot disk for UEFI.
- You cannot place partitions on logical volumes.
- You cannot use a logical volume as a Bcache backing device.
About VMFS datastores
About disk erasure
About disk erasure types
- Standard erasure - Overwrites all data with zeros.
- Secure erasure - Although effectively equivalent to Standard erase, Secure erase is much faster because the disk’s firmware performs the operation. Because of this, however, some disks may not be able to perform this erasure type (SCSI, SAS, and FC disks in particular).
- Quick erasure - Same as Standard erase but only targets the first 1 MB and the last 1 MB of each disk. This removes the partition tables and/or superblock from the disk, making data recovery difficult but not impossible.
If all three options are checked when the machine is released, the following order of preference is applied:
- Use ‘secure erase’ if the disk supports it
- If it does not, then use ‘quick erase’
It is very important to pay close attention to your selections when erasing disks.
About pre-seeding
During machine enlistment, deployment, commissioning and machine installation, MAAS sends Tempita-derived configuration files to the cloud-init process running on the target machine. MAAS refers to this process as preseeding. These preseed files are used to configure a machine’s ephemeral and installation environments and can be modified or augmented to a custom machine configuration.
Preseeding in MAAS can be achieved in two ways:
Curtin, a preseeding system similar to Kickstart or d-i (Debian Installer), applies customisation during operating system (OS) image installation. MAAS performs these changes on deployment, during OS installation, but before the machine reboots into the installed OS. Curtin customisations are perfect for administrators who want their deployments to have identical setups all the time, every time. This blog post contains an excellent high-level overview of custom MAAS installs using Curtin.
Cloud-init, a system for setting up machines immediately after instantiation. cloud-init applies customisations after the first boot, when MAAS changes a machine’s status to ‘Deployed.’ Customisations are per-instance, meaning that user-supplied scripts must be re-specified on redeployment. Cloud-init customisations are the best way for MAAS users to customise their deployments, similar to how the various cloud services prepare VMs when launching instances.
About templates
The Tempita template files are found in the /var/snap/maas/current/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
The Tempita template files are found in the /etc/maas/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
| Phase | Filename prefix |
| Enlistment | enlist |
| Commissioning | commissioning |
| Installation | curtin (Curtin) |
The enlist template, for example, contains only minimal variables, whereas enlist_userdata includes both user variables and initialisation logic.
Tempita’s inheritance mechanism is the reverse of what you might expect. Inherited files, such as enlist_userdata, become the new template which can then reference variables from the higher-level file, such as enlist.
About template naming
Some earlier versions of MAAS only support Ubuntu. If the machine operating system is Ubuntu, then filenames without {os} will also be tried, to maintain backward compatibility.
{prefix}_{os}_{node_arch}_{node_subarch}_{release}_{node_name}or{prefix}_{node_arch}_{node_subarch}_{release}_{node_name} -
{prefix}_{os}_{node_arch}_{node_subarch}_{release}or{prefix}_{node_arch}_{node_subarch}_{release} -
{prefix}_{os}_{node_arch}_{node_subarch}or{prefix}_{node_arch}_{node_subarch} -
{prefix}_{os}_{node_arch}or{prefix}_{node_arch} -
{prefix}_{os} -
{prefix} -
generic
The prefix can be either enlist, enlist_userdata, commissioning, curtin, curtin_userdata or preseed_master. Alternatively, you can omit the prefix and the following underscore.
For example, to create a generic configuration template for Ubuntu 16.04 Xenial running on an x64 architecture, the file would need to be called ubuntu_amd64_generic_xenial_node.
To create the equivalent template for curtin_userdata, the file would be called curtin_userdata_ubuntu_amd64_generic_xenial_node.
- General availability kernels
- Hardware enablement kernels
- Hardware enablement kernels (pre-release)
- Low latency kernels
About low latency kernels
hwe-x-lowlatency: the Xenial low latency HWE kernel for Trusty -
ga-16.04-lowlatency: the low latency GA kernel for Xenial -
hwe-16.04-lowlatency: the low latency HWE kernel for Xenial
About choosing a kernel
- globally (default minimum enlistment and commissioning kernel)
- per machine (minimum deploy kernel)
- per machine during deployment (specific deploy kernel)
MAAS can specify kernel boot options to machines on both a global basis (UI and CLI) and a per-machine basis (CLI-only). A full catalogue of available options can be found in the Linux kernel parameters list at kernel.org.
Administrators can manage resource pools on the Machines page in the web UI, under the Resource pools tab, or with the MAAS CLI. Also note that all MAAS installations have a resource pool named “default.” MAAS automatically adds new machines to the default resource pool.
About customising deployed machines
MAAS 3.2 provides the capability to customise deployed machines, in that you can update hardware for a running machine on-the-fly. Specifically, MAAS will update a deployed machine’s data when you do any of the following things:
You can find the procedure here.
While deploying a machine, you can configure that machine to periodically sync its hardware configuration. Deployed machines will also passively update changes to the BMC and tags for that machine, as these changes are made.
About updating hardware
Updating hardware on a deployed machine works by installing a special binary on the deployed machine. This binary is configured at a given interval and push hardware info to the MAAS metadata endpoint. By setting “enable_hw_sync” to true on a machine prior to deployment, MAAS will add configuration to install a systemd service and timer that will download the hardware sync binary. This binary then authenticates the machine, reads the hardware info from the machine and pushes it to MAAS. The interval is set globally in the MAAS settings.
Any changes in hardware are written to the machine’s configuration. Physical hardware changes will be preserved upon release, while virtual changes, such as a SR-IOV interface, will be dropped.
When deploying a machine from the UI, there is a new “enable_hw_sync” flag available for each machine. This flag marks a machine to be configured with live hardware updates.
When deploying from the CLI, there is an additional enable_hw_sync flag on maas $PROFILE machine deploy. This flag also marks a machine to be configured with live hardware updates.
When using the API, there are two additional fields in the request:
- enable_hw_sync: (Boolean) - indicating whether hardware sync should be enabled on the machine,
- sync_interval: (Int) - indicating the interval, in seconds, that should be set at time of deployment
With respect to machine.read, both the RESTful API and Websocket API add the following fields to a response:
- enable_hw_sync: Bool indicating whether hardware sync is enabled on the machine,
- last_sync: Timestamp of the last time MAAS received hardware sync data for the machine,
- next_sync: Timestamp of the computed estimation of when the next sync should happen,
- sync_interval: Int the interval, in seconds, that was set at time of deployment
- is_sync_healthy: Bool indicating the sync is working normally when true, false when a sync is late or missing,
With respect to config.list, there is a new WebSocket Response result (new “hardware_sync_interval” option):
value: String in systemd time span format e.g. “15m”
(only hours, minutes and seconds are recognised)
- hardware_sync_interval is set to `15m` by default
config.update
WebSocket Request params - new “hardware_sync_interval” param
params: {
value: String in systemd time span format, e.g. “15m”
The API does not throw errors when an invalid string is provided for these parameters.
About hardware sync
Hardware sync updates the machine’s blockdevice, interface and device sets. BMC configuration and tags can also be updated on the machine itself. The timestamps of the last sync and the next scheduled sync can be seen in the machine’s data.
The capability to customise deployed machines is available starting with MAAS version 3.2.
