MAAS 2.7 release notes
MAAS 2.7.3 released
On 24 August 2020, MAAS 2.7.3 was released, replacing the 2.7/stable
channel in snap and the ppa:maas/2.7. You can update your 2.7 release to 2.7.3 by with:
snap refresh --channel=2.7/stable
or by using the aforementioned PPA. The focus for this release has been bug-fixing – there were no changes to MAAS since RC1.
Thanks to everyone who reported the issues with previous 2.7 releases and helped us with the logs.
MAAS 2.7.2 released
On 30 July 2020, MAAS 2.7.2 was released, replacing the 2.7/stable
channel in snap and the ppa:maas/2.7. You can update your 2.7 release to 2.7.2 by with:
Upgrading from MAAS 2.6 snap
If you are using the MAAS 2.6 snap, which had to be installed with --devmode
, you can update to 2.7 with the following parameters:
snap refresh maas --devmode --channel=2.7
Be aware that you will still be in --devmode
, which means the snap won’t automatically upgrade. You’ll have to check manually for updates (via snap refresh
). Once you’re upgraded to MAAS 2.7 using this method, future snap updates won’t require the devmode parameter. So, for example, when a later version of 2.7 (or even 2.8) is released, you will be able to snap refresh
to those channels and get out of devmode. Once refreshed out of devmode in this way, you’ll get updates for point releases automatically.
An alternative to avoid devmode would be to do a clean install of MAAS 2.7, that is, removing 2.6 with snap remove maas
and reinstalling MAAS 2.7 with:
snap install --channel=2.7 maas
Note that you can check the devmode status of your snap with:
snap list maas
MAAS 2.7 released
Following on from MAAS 2.6.2, we are happy to announce that MAAS 2.7 is now available. This release features some critical bug fixes, along with some exciting new features:
CentOS 8 image support
Users can now deploy CentOS 8 images in MAAS. The Images page in the MAAS UI will now offer a choice to select and download CentOS 8. Note that users of previous versions may see CentOS 8 as an available option, but cannot download or deploy it.
Network testing features
MAAS 2.7 brings a slate of new network testing and link detection features, as detailed below.
Network link disconnect detection
MAAS 2.7 can check whether links are connected or disconnected. Previously, when commissioning, you couldn’t detect unplugged cables. Now you can. You will have to take a couple of steps for existing MAAS deployments: First, you will have to upgrade to 2.7, then run commissioning again to see if a link is disconnected. But you no longer have to puzzle over what’s broken when this happens.
MAAS will report disconnected network cables, and users will receive a warning when trying to configure a disconnected interface. Administrators will be able to change cable connection status through both API and UI after manually rectifying the situation.
Slow network link detection
MAAS 2.7 makes sure you’re getting the most out of your link speed. As servers and hardware get faster — 10G, 40G, even 100G NICS — the chances increase that you might plug your 10G NIC into a 1G switch, for example. Previously, with MAAS, you’d be stuck with the speed of the slowest link, but there wasn’t a way to verify your link speed without recommissioning. Depending on your physical hardware, that might still be an issue, but the MAAS UI can now warn you if your interface is connected to a link slower than what the interface supports. And all information shown in the UI is available via the API, as well. You can still replace a slow switch without recommissioning.
MAAS will automatically detect link and interface speed during commissioning and report them via the API/UI. Administrators will be able to change or update the link and interface speeds via the API/UI after manual changes to the connection. MAAS 2.7 will also report link speed, allowing users to filter and list machines by their link speed in the UI. Users can also employ this information to allocate machines by their link speed in the API.
Network validation scripts and testing
MAAS 2.7 allows you to configure network connectivity testing in a number of ways. If you’ve used MAAS, you know that if it can’t connect to the rack controller, deployment can’t complete. Now MAAS can check connectivity to the rack controller and warn you if there’s no link, long before you have to try and debug it. For example, if you can’t connect to your gateway controller, traffic can’t leave your network. MAAS can now check this link and recognise that there’s no connectivity, which alleviates a lot of annoying (and sometimes hard-to-detect) network issues.
In addition, Internet connectivity testing has been greatly expanded. Previously, MAAS gave a yes/no link check during network testing. Now you can give a list of URLs or IP addresses to check. In the ephemeral environment, standard DHCP is still applied, but when network testing runs, we can apply your specific configuration for the duration of the test. While all URLs / IPs are tested with all interfaces, we do test each of your interfaces individually, including breaking apart bonded NICS and testing each side of your redundant interfaces. You can also run different tests on each pass, e.g., a different set of URLs, although each run would be a different testing cycle. For testing individual interfaces, you can use the API.
Of course, the main network feature available in 2.7 is improved — and customisable — network testing. You can now create your own commissioning scripts and tests related to networking. You can create your own network tests (e.g., a network throughput test) and run them during the network testing portion of the MAAS workflow. There are no particular restrictions on these scripts, so you can test a wide variety of possible conditions and situations.
Administrators can upload network tests and test scripts, as well as create tests which accept an interface parameter, or scripts which apply custom network configurations. Users can then specify (unique) parameters using the API, override machines which fail network testing (allowing their use), and suppress individual failed network tests. All users benefit from enhanced reporting, as they are now able to see the overall status of all interfaces via the API, the UI Machine list, and the UI Interfaces tab; review the health status from all interface tests; and view the interface test results by interface name and MAC.
Live IP address detection to prevent address conflicts
In some cases, MAAS connects with subnet which are not empty. Normally, the user has to tell MAAS about IP addresses which are already assigned on that subnet, and if that step is skipped, MAAS may assign and in-use IP address to one of the machines under its control, leading to an IP conflict.
MAAS 2.7 alleviates this problem by detecting IPs in use on a subnet, so that it can avoid assigning that IP to a MAAS-managed machine. The system is not perfect; for example, if NIC on a subnet-connected machine is in a quiescent state – or turned off – MAAS may not detect it before duplicating the IP. Note that at least one rack controller must have access to the previously-assigned machine in order for this feature to work. MAAS 2.7 will also recognise when the subnet ARP cache is full and re-check the oldest IPs added to the cache to search for free IP addresses.
Introductory NUMA / SR-IOV support
NUMA (Non-Uniform Memory Access) is a useful way of achieving high-efficiency computing, by pairing a CPU core with a very fast connection to RAM and PCI buses. Typically the CPU socket and the closest banks of DIMM constitute a NUMA node. Obviously, if you’re deploying a MAAS machine under NUMA to get maximum performance, you would like for that machine to be confined to a single NUMA node. MAAS 2.7 introduces this capability.
MAAS will display the NUMA node index and details. Users can also see the count of available NUMA nodes, along with CPU cores, memory, NICS, and node spans for bonds and block devices (although node-spanning may not produce suitable performance). From a reporting standpoint, users can filter machines by CPU cores, memory, subnet, VLAN, fabric, space, storage, and RAID.
Similarly, the SR-IOV (Single Root I/O Virtualisation) allows a PCIe device (e.g, a NIC) to appear to be multiple separate devices. A network adaptor can be subdivided into multiple adaptors by adding a Virtual Function (VF). MAAS 2.7 supports the use of multiple VF adaptors to intelligently use SR-IOV edge clouds, by allowing users to see that a NIC supports SR-IOV, along with the supported VF counts.
The goal of this feature is to help users choose the right machine to deploy an edge cloud.
Settings and user preferences redesign
As part of our efforts to make the UI faster and more responsive, we have completely redesigned the Settings and User preferences within the MAAS UI.
Strictly-confined Snap support
With 2.7, MAAS is fully confined within the Snap container. No need for installation qualifiers (such as “–devmode”) to permit use of external resources, i.e., outside the Snap container. This means that we will begin to transition to recommending the Snap install as the default (and primary) MAAS install method. This also means that MAAS now gains the benefit of confined snap security features.
Update to hardware information gathering methods
MAAS has switched hardware information gathering from lshw/lsblk to lxd output during commissioning, because it more easily provides the information needed to complete resource discovery. Note that this information may not be particularly reliable for your use, so you may need to create your own commissioning scripts if you need something more detailed or specific.
Bug fixes
A number of bug fixes (see the list in Launchpad).
Cumulative summary of new features in MAAS 3.0
- PCI and USB devices are now modelled in MAAS
- IBM Z DPM partition support
- Proxmox support
- LXD projects support
- PCI and USB device tabs in machine details
- Workload annotations
- Fixed status bar
- Registering a machine as a VM host during deployment
- Improvements to MAAS CLI help UX
- Disabling boot methods
- Consolidation of logs and events
MAAS 3.0 bug fixes
MAAS 3.0 incorporates a large number of bug fixes, summarised in the sections below. Please feel free to validate these fixes at your convenience and give us feedback if anything doesn’t seem to work as presented in the bug request.
One particular bug, #1916860, involves failures in the IPMI cipher suite in MAAS 2.9.2 and up, on the Lenovo x3650 M5 (and others). This particular bug is a not a MAAS bug, but a firmware issue with the subject machines. While the MAAS team can’t fix this (hence the assignment of “Won’t Fix”), the team did provide a easy workaround which helps circumvent this issue.
MAAS 3.0 bug fixes
Here are the bugs that were ‘Fix Released’ for the MAAS 3.0 release:
Number | Description | Importance |
#1932136 | interface with a warning is not configured properly | Critical |
#1896771 | interfaces that are not connected are detected as ‘connected to slow interface’ | Medium |
MAAS 3.0 RC2 bug fixes
Here are the bugs that have been ‘Fix Released’ in MAAS 3.0 RC2:
#1929552 | Deb-based controller fails to run machine-resources | Critical |
#1929576 | Machines fail to commission using the 3.0 snap due to possible? DNS issue | Critical |
#1930227 | Failure to commission when interfaces has a /32 IP | Critical |
#1930554 | vm-host CLI command is now named vmhosts | Critical |
#1930587 | Different disks with same LUN detected as multipath | Critical |
#1931215 | [.0~rc2-10023 testing] two IPs assigned to one interface | Critical |
#1931838 | Reverse DNS lookup fails for subnets smaller than /24 | Critical |
#1835292 | UI should add button to download curtin-logs.tar on deployment failure MAAS | High |
#1908552 | maas init fails; ‘relation “maasserver_routable_pairs” does not exist’ | High |
#1929086 | LXD VM hosts can’t be refreshed if VLANs interfaces aren’t named $parent.$vid | High |
#1929643 | MAAS often fails and and returns a Pickled object if request header is set to Accept: / | Medium |
#1924820 | Trying to edit a disconnected NIC, then cancelling the edit and connecting the NIC via its drop-down menu, many drop-down menu options then disappear | Undecided |
MAAS 3.0 RC1 bug fixes
Here are the bugs that have been ‘Fix Released’ in MAAS 3.0 RC1:
#1774529 | Cannot delete some instances of model ‘Domain’ because they are referenced through a protected foreign key | High |
#1919001 | Unable to network boot VM on IBM Z DPM Partition | High |
#1925249 | MAAS detects 0 cores, RAM available for KVM host, reports negative availability on pod compose | High |
#1927292 | Updating controller has vlan_ids error | High |
#1927657 | Global kernel command line options not passed with tags | High |
#1928098 | If a workload annotation has a key with spaces in it, filtering doesn’t work | High |
#1926140 | maas_url not returned to the UI | Medium |
#1926171 | Failure processing network information when adding a rack | Medium |
#1927036 | Incorrect value “accept_ra” in interface definition | Medium |
#1927340 | Deb to snap migration script should support remote Postgres | Medium |
#1928104 | New workload annotations don’t show up without a reload | Medium |
#1928115 | API still refers to “owner data” rather than “workload annotations” | Medium |
#1922891 | MAAS configures nodes with incorrect DNS server addresses when using multiple IP addresses | Undecided |
#1923268 | grubnet default grub.cfg should try /grub/grub.cfg-${net_default_mac} before /grub/grub.cfg | Undecided |
#1926164 | VLAN page shows odd “Rack controllers” value | Undecided |
#1926510 | dhcp subnet snippets are NOT inside the pool block | Undecided |
#1927559 | Default logical volume size too big in UI | Undecided |
#1928024 | UI states commissioning/testing scripts were never uploaded | Undecided |
#1928226 | Information “not available” indicates that it’'s an error of some sort | Undecided |
#1928235 | notes field won’t update properly: MAAS 3.0 RC]() | Undecided |
#1928324 | updating a machine zone or resource pool doesn’t refresh details | Undecided |
MAAS 3.0 Beta 5 bug fixes
Here are the bugs that have been Fix Released
in MAAS 3.0 Beta 5:
#1925784 | Processing LXD results failure with loopback | Critical |
#1923871 | LXD vmhost project usage includes usage for other projects | High |
#1815084 | MAAS web ui should perform Save action when Enter/Return is pressed | Medium |
#1923867 | Commissioning fails if NIC gets different PCI address | Medium |
MAAS 3.0 Beta 4 bug fixes
in MAAS 3.0 Beta 4:
#1923246 | Unable to compose LXD VM with multiple NICs | High |
#1918963 | Controllers page out of sync with nodes | Undecided |
#1923685 | Unable to deploy LXD VM host on S390X | Undecided |
#1923687 | LXD VM host refresh failure is ignored | Undecided |
#1914762 | test network configuration broken with openvswitch bridge | High |
#1917963 | Add chassis lowers the case of added machines | Low |
#1915087 | 2.9 UI is broken, seems to loop between user intro and machines pages endlessly | High |
#1923842 | Can’t use action menu on machine details page | High |
#1917667 | Commissioning/testing scripts no longer show ETA or progress | Undecided |
#1917669 | No way to view previous commissioning or testing script results | Undecided |
#1917670 | Storage and interface tests not assoicated with a device | Undecided |
#1917671 | Commissioning/testing scripts not updated after starting commissioning or testing | Undecided |
#1917794 | Unable to view full history of events in UI | Undecided |
#1918964 | UI shows action unavailable after performing action | Undecided |
#1918966 | Tabs aren’t always underscorred | Undecided |
#1918971 | UI does not autofill size on storage tab | Undecided |
#1923524 | Unable to delete LXD composed machine on KVM page | Undecided |
MAAS 3.0 Beta 3 bug fixes
in MAAS 3.0 Beta 3:
#1922569 | Create KVM fails in MAAS 3.0 Beta with a project error | High |
#1923251 | Creating an LXD VM host now requires a project name | High |
#1809939 | dhcp snippet create fail when dhcp subnet is relayed | Medium |
#1913460 | Add option to pick whether to keep or decompose machines in a VM host | Undecided |
#1922787 | make “LXD” the default VM host in MAAS UI (rather than virsh) | Undecided |
#1922876 | Deploy KVM hosts with LXD by default | Undecided |
#1922972 | MAAS 3.0 Beta2 UI says “machine cannot be deployed” while successfully deploying machine | Undecided |
#1923719 | MAAS 3.0 : snap refresh maas from 3.0.0~beta2-9826-g.13cc184d5 | Undecided |
MAAS 3.0 Beta 2 bug fixes
in MAAS 3.0 Beta 2:
#1922107 | Hugepages/pinning available for virsh and lack validation | High |
#1922433 | Machine resources path set incorrectly in rackd when using snap | High |
MAAS 3.0 Beta 1 bug fixes
in MAAS 3.0 Beta 1:
#1896199 | API docs link is not offline | Critical |
#1904245 | MAAS Snap fails to build on PPC64 on Launchpad | Critical |
#1912727 | KVM Page Fails to load with error “An unexpected error has occurred, please try refreshing your browser window.” | Critical |
#1915869 | maas snap cli renders SyntaxWarning in the stderr | Critical |
#1916093 | Unable to add more than 3 Promox VMs | Critical |
#1883824 | Support LXD projects in power control | High |
#1884276 | Terrible user experience adding existing LXD host | High |
#1902425 | Failed to allocate the required AUTO IP addresses after 2 retries | High |
#1908087 | Reverse DNS for non-maas RFC1918 zones fails inside maas | High |
#1908356 | Owner data websocket methods are not working | High |
#1908434 | Can’t delete LXD VM in offline state | High |
#1913323 | /MAAS/docs/ leads to 404 page | High |
#1914588 | Enabling debug from snap traceback | High |
#1915021 | Mapping subnet doesn’t work from the MAAS snap | High |
#1915022 | The MAAS snap doesn’t include nmap | High |
#1915715 | LXD VM additional disks all show 10Gb size | High |
#1915970 | Facebook Wedge BMC detection fails on non-x86 architectures | High |
#1918997 | MAAS does not set snap proxy | High |
#1919000 | Unable to connect MAAS to an LXD VM host | High |
#1887797 | Impossible to delete zombie LXD VM | Medium |
#1894116 | Machines can’t be deployed after deselecting all archs in the “Ubuntu extra architectures” package repo | Medium |
#1897946 | hi1620-based ARM Servers are shown as “Unknown model” | Medium |
#1906212 | timeout in testing scripts ignores the days if set to greater than 24 hours | Medium |
#1911825 | Unable to use FQDN as power_address | Medium |
#1914165 | Proxmox does not allow custom port | Medium |
#1917652 | 30-maas-01-bmc-config failing on commissioning Cisco UCSC-C220-M4L | Medium |
#1335175 | maas does not combine kernel_opts when nodes have multiple tags with kernel options | Low |
#1915359 | make sampledata can’t find machine-resources | Low |
#1916844 | Removing a machine that is a vm host tells you to remove the “pod” | Low |
#1920019 | maas_remote_syslog_compress is unnecessarily chatty | Low |
#1887558 | Multipath JBOD storage devices are not shown via /dev/mapper but each path as a single device. | Wishlist |
#1901944 | tags field in machine edit page overtakes other fields | Undecided |
#1909985 | Add commission timestamp to machine websocket api | Undecided |
#1913464 | Drop RSD pods UI | Undecided |
#1914590 | Support composing LXD VMs with multiple disks in the UI | Undecided |
#1915970 | Facebook Wedge BMC detection fails on non-x86 architectures | Undecided |
#1916073 | MAAS should install qemu-efi-aarch64 on arm64 KVM pods | Undecided |
#1916317 | UI is using API to request scripts with full content | Undecided |
#1919381 | typo “veryiying” in info message in smartctl-validate | Undecided |
