How to enable DHCP
*Errors or typos? Topics missing? Hard to read? Let us know.
This page explains how to manage DHCP for MAAS. If you’re new to the subject, you might find it helpful to first read an overview of MAAS DHCP.
Enable MAAS DHCP (UI)
To enable MAAS-managed DHCP via the MAAS UI:
  1. Select Subnets > > Reserved ranges > Reserved dynamic range.
  2. Enter a Start IP address and an End IP address.
  3. Select Reserve > Configure DHCP. You will see a new screen.
  4. The options MAAS provides DHCP and Provide DHCP from a rack controller will be pre-selected.
  5. If you accept these options, you may need to choose a Rack controller.
  6. If you choose Relay to another VLAN, you will need to choose the target VLAN.
  7. Under Reserved dynamic range, you may have to select a subnet from the drop-down.
  8. Select Configure DHCP for your changes to be registered with MAAS.
Create an IP range (UI)
To create an IP range:
  1. Select Subnets.
  2. In the SUBNET column, choose the subnet for which you want to create an IP range.
  3. Scroll down to Reserved ranges.
  4. Select Reserve range and choose either Reserve range or Reserve dynamic range. Note that if you choose a dynamic range, MAAS will automatically provide DHCP for enlistment and commissioning provided that the associated VLAN has DHCP enabled.
  5. A window will appear, allowing you to enter a Start IP address and *End IP address
  6. If you didn’t select a dynamic range, you may optionally enter a Purpose for the range.
  7. Select Reserve to register your choices with MAAS.
Edit an IP range (UI)
  1. Select Menu at the far right of the row corresponding to the subnet in question.
  2. Select Edit reserved range from the menu that appears.
  3. Edit the fields as desired.
  4. Select Save to register your changes.
Delete IP range (UI)
To delete an IP range, select Menu at the far right of the subnet row; then choose Remove range > Save.
Extend IP range (UI)
To extend a dynamic IP range, select Subnets > subnet > Reserve dynamic range. DHCP will be enabled automatically.
Enable DHCP (CLI)
To enable DHCP on a VLAN in a certain fabric, enter the following command:
Pro tip: You must enable DHCP for PXE booting on the ‘untagged’ VLAN.
You will also need to set a default gateway:
Set up a DHCP relay
Via the MAAS UI, you can set up a DHCP relay from one VLAN (source) to another VLAN (target) as follows:
  1. Ensure the target VLAN has DHCP enabled.
  2. Set up the external relay. This relay is set up independently from MAAS. See DHCP relay for software suggestions.
  3. Configure MAAS-managed DHCP as normal.
  4. Navigate to the source VLAN page.
  5. Select the Relay DHCP action.
  6. Fill in the fields in the resulting form. Note that the crucial setting is the target VLAN (Relay VLAN).
  7. Select Relay DHCP to finish.
To use the MAAS CLI to relay DHCP traffic for a VLAN (source) through another VLAN (target):
Managing DHCP snippets (UI)
To manage snippets via the MAAS UI as an administrator, select Settings >> DHCP snippets.
Search snippets (UI)
To search DHCP snippets, enter the text to match in Search DHCP snippets. MAAS will progressively update the list of snippets as you type your search terms.
Add snippets (UI)
To add a snippet:
  1. Select Add snippet.
  2. Enter the Snippet name.
  3. Optionally, check Enabled to enable the snippet now. Note that MAAS will not apply the snippet unless it is enabled.
  4. Optionally, enter a Description for the snippet.
  5. Optionally, choose a Type for the snippet from the drop-down (defaults to Global). This parameter sets the scope of the snippet. Note that if you choose a type other than global, you may need to choose the specific scope. For example, if you choose the Subnet type, you must identify the specific subnet to which this snippet applies.
  6. Enter the DHCP snippet. This is not validated on entry.
  7. Select Save snippet to register your changes with MAAS
Edit snippets (UI)
To edit a snippet, select the pencil icon to the right of the snippet row and edit the fields as desired.
Delete snippets (UI)
To delete a snippet, select the trash can icon to the right of the snippet. You will be asked to confirm; be aware that once confirmed, this action cannot be undone.
Create global DHCP snippets (CLI)
To create a global snippet:
    global_snippet=true
Create subnet snippets (CLI)
To create a subnet snippet:
    subnet=$SUBNET_ID
Create node snippets (CLI)
To create a node snippet:
    node=$NODE_ID
List snippets (CLI)
To list a specific snippet:
Update snippets (CLI)
To update a DHCP snippet attribute:
Toggle a snippet (CLI)
Enabling and disabling a snippet is considered a snippet update and is done via a Boolean option (‘true’ or ‘false’). You can disable a snippet like this:
Delete a snippet (CLI)
To delete a snippet:
Create an IP range (CLI)
Protect a range (CLI)
Protect an IP (CLI)
Edit a range (CLI)
To edit an IP range:
  1. Find the ID of the desired IP range with the command:
maas admin ipranges read
  1. Edit the range with the command:
maas admin iprange update $ID start_ip="<start ip>" end_ip="<end ip>" comment="freeform comment"
This command will update the IP range associated with $ID.
Delete a range (CLI)
You can delete a range of IP addresses by deleting the addresses one by one. To remove a single reserved IP address:
Create A/AAAA DNS records (CLI)
An administrator can create an A record when creating a DNS resource with an IPv4 address:
An administrator can also create an AAAA record when creating a DNS resource with an IPv6 address:
Set CNAME DNS records (CLI)
An administrator can set a DNS Alias (CNAME record) to an already existing DNS entry of a machine:
Set ME DNS records (CLI)
An administrator can set a DNS Mail Exchange pointer record (MX and value) to a domain:
Set a DNS forwarder
To set a DNS forwarder:
